RDP Motorsport
V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) Driveshafts | Differentials | Gears | Rearends | Clutch | Shifters
Old 09-04-2009, 09:04 PM   #1
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
rear diff moan on slow turns
just started to notice a slight "moan" noise from the rear diff when doing slow sharp turns/ backing out of the driveway or tight parking
anyone else??
Old 09-08-2009, 12:35 PM   #2
camaro1
camaro1's Avatar
noise was very loud today, just changed rear diff fluid with gm synthetic and friction modifier, hopefully this does the trick
Old 12-02-2009, 10:42 AM   #3
PnCRedJwl2SS
Howdy! Pete here...
PnCRedJwl2SS's Avatar
Drives: 2SS/RS RJT/Sun Roof/Gray Seats
Hi...please let me know if changing the rear diff fluid works for you. I get this same moan when backing out.
Many thanks!
PnCRedJwl2SS
2SS / RS, L99 AT, RJT, Black w/Gray Interior, Power Sun Roof, & Polished Aluminum Wheels!
___________________________________________
1100, Preliminary order accepted 08-06-09 NMRJ0X
3800, Produced - Built 9-09-09 VIN A9144011
5000, Delivered to the dealer and home! 9-16-09
PnCRedJwl2SS is offline   Reply With Quote
Old 12-02-2009, 10:54 AM   #4
camaro1
camaro1's Avatar
no more noise, changing the fluid with gm synthetic and some gm additive fixed it,
after you change the fluid take the car to an empty parking lot and do some figure-8 driving to work the new fluid into the clutch packs
Old 12-02-2009, 12:19 PM   #5
ffrcobra_65
good info. Thanks for sharing!
Old 12-02-2009, 01:19 PM   #6
94guy
94guy's Avatar
Drives: 99 Camaro; 2010 Camaro 2SS/RS
camaro1, what was in the diff before? stock gear oil?
94guy is offline   Reply With Quote
Old 12-02-2009, 03:11 PM   #7
BigMatt
2010 Camaro 2 SS/RS M6
BigMatt's Avatar
Drives: 2010 Camaro SS/RS
Send a message via AIM to BigMatt
There are clutch packs in the rear end? I'm pretty sure that is not true somebody correct me if im wrong.
LS3, JRE Smooth Idle cam, CAI Inc, ARH 1 7/8, Corsa, MSD Wires, MGW Shifter, Street slayer clutch, Tick braided clutch line & speed bleeder, DSS 1000hp ds & 1400hp axles, BMR Split drop, Sway Bars, Trailing Arms, Toe Rods, Pro bushing kit, Spohn lcas, Whipple, LPE dual fuel pumps, Rx catch can, Id850s, Powerhaus Performance tuned.
BigMatt is offline   Reply With Quote
Old 12-02-2009, 08:42 PM   #8
camaro1
camaro1's Avatar
how do you think a posi/limited slip rearend works, yes there are clutch packs in your rear end if you have a posi/limited slip diff
this will give you an idea how the posi works:
http://www.eaton.com/EatonCom/Produc...iLSD/index.htm
Old 12-02-2009, 08:52 PM   #9
camaro1
camaro1's Avatar
yes and with only a few thousand miles on it,, it was very bad looking and came out like water
Old 12-02-2009, 09:12 PM   #10
nemosgt
Drives: 2006 Ford Mustang GT
Send a message via ICQ to nemosgt
Yes, that is the correct answer. Had to change fluid every six months on my "95 and '98 Camaros to keep the rear quiet. Just a slight low moan on slow turns such as in a parking lot. However, I did autocross both cars. Maybe heavy duty useage?
Don't forget to add the friction additive.
Check your manual and see if it is not mentioned in maintenance requirements. Seems to me there was a note tucked away somewhere in mine where it was easy to miss.
Cheers.
nemosgt is offline   Reply With Quote
Old 12-02-2009, 10:37 PM   #11
UCI CamaroFan
Zot!
UCI CamaroFan's Avatar
Drives: Toyota 4Runner
Cheers.
It's in there, but not under maintenance.. It says to change the oil if you plan to race/be hard on the car.
It's under the break-in section.
UCI CamaroFan is offline   Reply With Quote
Old 12-03-2009, 02:16 AM   #12
Revo1
Camaronogamous
Revo1's Avatar
Drives: 2010/2002 Camaro SS!
Hey man, I'm likin the IOM on AW, any other pics?
CAMARO WIKI Tran Wiki 42 05-18-2013 09:32 AM
V8 Camaro Performance Upgrades List Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 79 03-04-2013 09:25 AM
Zeta (Camaro/Commodore/G8) suspension details Gatecrasher Wheels and Tires Talk Sponsored by The Tire Rack 66 04-16-2009 01:11 PM
Corvette C6 GTR TFord General Automotive + Other Cars Discussion 3 08-06-2008 09:26 PM
rear diff nfamous209 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 5 08-03-2008 02:49 PM
