Cold Air Inductions
Old 09-05-2009, 12:22 AM   #1
markssylver
markssylver's Avatar
Drives: 95 bbb impala ss
went to the track tonight
took my m6 ls3 to the track tonight and the best time i could get was a 13.13 @ 110.46 mph my problem is off of the line launching it i either spun the tires or had wheel hop how can i launch it and avoid wheel hop or spinning i was launching it in comp mode i was gonna try with t/c off butt after the burnout with it off seeing how easily the tires woud spin i turned comp mode bac on any suggestions on launching ?
10.56@134mph
ADM BUILT AND TUNED CGM 2SS RS
ADM/LPE 417 with ported heads/inconel vavles gt11 cam
ADM ported maggie with 14 rib rear 10 rib front pulleys
ADM fuel system and race air intake
ADM/LPE ZR1 clutch /pedalreturn spring
ADM billet aluminum valve covers /RPM LEVEL 6 TR6060
LPE HD 241mm diff with 3:45 gears HD axles and d/s
ADM widened wheels with 315nitto nt05s Bogart 17 dragwheels CTS-V front 6 piston brakes
Pedders HD subframe/differential bushings alignment kit 27/32mm sways Supercar coilovers
683RWHP/650RWTQ
markssylver is offline   Reply With Quote
Old 09-05-2009, 12:25 AM   #2
flyinglow57
Drives: rumble bee,2SS 6sp
leave it off.. ok end of thread
blk 2ss 6spd with sunroof.
intake,tsp cam,full exhaust,pcmforless tune,trailing arms,toe rods. hopeing for 11.9 because my g/f said she will take the cam and the suspension back if not.
flyinglow57 is offline   Reply With Quote
Old 09-05-2009, 12:26 AM   #3
7CAMARO7
7CAMARO7's Avatar
Drives: Slow 4th gen
lower your rpm and repeat. make sure you're not side stepping the clutch too. jumping straight back off it at a low enough rpm allows for maybe a chirp but then you'll hook and book
oh yea, if comp mode works best for you record those times and go again and try a lot with comp mode off and get good at it. It takes practice
7CAMARO7 is offline   Reply With Quote
Old 09-05-2009, 10:22 PM   #4
Red2010ss
Drives: 2015 1 SS, Black
hey went to the track on fri, I have a 09 cobalt ss and a 10 camaro, I raced a 10 camaro, but traction at the track was bad, I ran a 13.7 he ran a 13.5, I had him by 2 cars off the lin
Red2010ss is offline   Reply With Quote
Old 09-05-2009, 10:24 PM   #5
Red2010ss
I was almost 106 mph he ran 111, no traction no matter what i did, the cobalt is bad ass but i do love my camaro, Its going to the track on Oct 16th for all day rent a track with friends, Need to know if 18 inch vette rims will work, want drag radials, any help would be nice thanks
Old 09-06-2009, 11:20 AM   #6
OrangeChevyII
Drives: 2010 RS/SS2
This should answer your question
OrangeChevyII is offline   Reply With Quote
Old 09-06-2009, 12:16 PM   #7
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
You should post your time slip in the fastest 1/4 mile thread so it can be added. That's a good time with a real good trap speed.
Old 09-06-2009, 02:02 PM   #8
big dave
Drives: 2017 ZL1
I was able to see you make a couple passes at capitol. Traction definitely wasn't the best on friday but you seemed to do the best with what you had. You fared a little better than the other '10 that was there.
Your car had a nasty snarl coming from the exhaust but your exhaust looked stock. Did you change the headers?
I was having issues hooking on street tires myself with my '99 SS.
big dave is offline   Reply With Quote
Old 09-09-2009, 02:06 PM   #9
markssylver
i think that was me at capitol the 13.50 was my 2nd run
10.56@134mph
683RWHP/650RWTQ
Old 09-09-2009, 02:17 PM   #10
markssylver
i know you have the 18x 10.5 zo6 wheels but when i went to the mickey tompson website the 315 18 dr said it needed at least an 11 in wide wheel do you have the 315 or 305 dr
10.56@134mph
683RWHP/650RWTQ
Old 09-09-2009, 02:24 PM   #11
S8ER01Z
Drives: Camaro Z28
Hey did you get that New Era OTR intake yet? I saw you were on the list.
Nice times...post your slip!
2001 Camaro Z28 M6 (MTI Lid/FRA, LS6 Cam, BBK LTs)
S8ER01Z is offline   Reply With Quote
Old 09-09-2009, 04:54 PM   #12
markssylver
I didnt get it because it would not fit a maggie i dont have the maggie on yet but knew i was putting one on so i decided not to get it until they come out with one for a maggie
10.56@134mph
683RWHP/650RWTQ
Old 09-09-2009, 05:40 PM   #13
S8ER01Z
Drives: Camaro Z28
Oh I was going to ask for a before and after comparison. Good luck with the maggie!!!
Old 09-10-2009, 05:06 PM   #14
jmjackso
jmjackso's Avatar
Drives: 2014 2SS/RS Camaro
Get some track tires. A set of slicks from Nitto's, BFGoodrich, or MT. Best mod you can get if you are going to be running at the track often.
Then: 2010 Camaro M6 2SS/RS: Stroked, Blown and then some 783rwhp/834rwtq = SOLD
Now: 2014 Camaro L99 2SS/RS: TSP Headers, No Cats, NPP.
jmjackso is offline   Reply With Quote
Went to the track with my stock Auto 2ss tonight mike@newera Dragstrip and Launch Techniques Discussion 93 07-07-2010 02:02 PM
Heading to the track tonight! OrangeChevyII Dragstrip and Launch Techniques Discussion 1 08-02-2009 02:34 PM
What should I expect at the track tonight.... Bowtie Guy Z28 4th Generation Camaros 5 05-28-2008 04:20 PM
Hitting the track tonight! TAG UR IT Off-topic Discussions 9 01-05-2007 11:57 AM
