Old 09-05-2009, 07:00 PM   #1
old motorhead
Drives: Maggie blown LS3 vette
L99 needs blower job....
...but not quite yet. Car is on the way. SSRS. I'd like to do things in two stages. Cam and exhaust and then the blower. For the cam, I'm thinking somehting along the lines of 212/224 with .580 lift on both sides with a 115LSA. Want all the power I can get without drivability issues (wife's car). Stock converter stays, but will consider a shift kit and extra cooling if needed. I don't know anything about what's available for Camaros exhaust wise. Hoping someone makes a 1.875 set that will bolt in and connect to the stock exhaust without too much hassle. I want to keep the cats, but don't mind changing to better flowing muffler(s). Will probably do all work except the tune in my shop.
For the blower, I'm set on a TVS2300. I have one on my vette and it's a pleasure every time I get to drive it. 672 at the wheels with very few issues. Just finished a 400 mile trip and it averaged 24mpg with quite a bit of city driving mixed in. I'd like her Camaro to run almost as good with a more female friendly setup. Your help appreciated! Not set on anything except the blower. Wanting your thoughts.
old motorhead is offline   Reply With Quote
Old 09-05-2009, 07:02 PM   #2
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Keep us posted Sounds like you know what you want to do !!
Crowley
Crowley is offline   Reply With Quote
Old 09-05-2009, 07:14 PM   #3
old motorhead
Crowley
I know just about enough to be dangerous. I'm trying not to make any mistakes. Have made plenty before and I realize the value in getting it right the first time. That's the reason for asking for help. Looking to learn from those that have been there.
Old 09-06-2009, 01:20 PM   #4
old motorhead
I still have the stock LS3 cam from my vette. Would adding that to the L99 be enough of an upgrade to be worth the trouble?
Thanks to the mods for cleaning up the title to this thread. It was a little off color.
Old 09-06-2009, 03:02 PM   #5
Mike TexaSS
Drives: 454 LS7 Camaro SS
Give us a call. We are doing 2 TVS installs right now. I have a few L99 stealth blower grinds that would be perfect. It could idle at the stock rpm.
Mike TexaSS is offline   Reply With Quote
Old 09-06-2009, 04:43 PM   #6
hot ss
hot ss's Avatar
Drives: aqua 2ss l99
as in retain vvt?
the wife wants a cam that makes it sound lumpy and hot....while the blower is in bypass.
May your exhaust note, sing in harmony with your blower.
hot ss is offline   Reply With Quote
Old 09-06-2009, 07:54 PM   #7
old motorhead
Please elaborate on what you'd recommend cam wise. PM if you'd rather. I won't do the secret stuff. If I don't know the specs, it's not going in my motor.
Old 09-06-2009, 08:11 PM   #8
pharmd
Master of Medicine
pharmd's Avatar
Drives: 4th Gen
Honestly it sounds like you'd be a good candidate for an ADM setup. Andy takes pride in making sure his setups (especially cams) are almost transparent (like stock), yet still make good power. He works with Lingenfelter, so he draws from their knowledge base, plus applies what he knows to create a killer mix of products and services that perform. I'd at least PM him and tell him what you want and see if you like what he has to stay.
2002 Camaro SS. 408 LS2. 500+RWHP/480RWTQ. Full UMI RR suspension. Koni/Strano. 295F/315R. 3500#(55/45)
pharmd is offline   Reply With Quote
Old 09-06-2009, 08:34 PM   #9
600hp-lpe
Drives: 2010
You are in TX.. I agree with pharmd. you need to talk to andy at ADM.
600hp-lpe is offline   Reply With Quote
Old 09-06-2009, 09:09 PM   #10
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
If you are going to do the installs....I would be happy to do my best and hook you up on the parts.
Comp Cams is coming out with a few really cool cams that will work well with the VVT...as well as a blower.
I have some great ideas, of things we could do for you...feel free to get int ouch if you would like to discuss further.
ZZcamaro is offline   Reply With Quote
Old 09-06-2009, 10:09 PM   #11
mike@newera
mike@newera's Avatar
Drives: 2016 Camaro SS
You don't do a shift kit in the 6l80e, it is all in the TCM tune.
mike@newera is offline   Reply With Quote
Old 09-07-2009, 05:34 AM   #12
rpepka
rpepka's Avatar
Drives: 2013 ZL1 # 2195
There is nothing like getting blown!
rpepka is offline   Reply With Quote
GM High Tech Performance Magazine's L99 Tune - +81 ft lbs at 3500 rpms! SGOS252382 Tuning / Diagnostics -- engine and transmission 52 10-01-2009 12:31 AM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 02:00 PM
Best job in the WORLD!!! TFord Off-topic Discussions 18 01-14-2009 02:04 PM
L99 engine specifications Tran Wiki 0 10-19-2008 12:40 PM
