Old 09-05-2009, 10:56 PM   #1
ADM PERFORMANCE
Drives: 2016 CAMARO SS
3" Magnaflow Installed with ARH Headers - BEST SOUND EVER!
The 3" MagnaflowExhaust System I got in last week,got installed at my shop today and connected directly up to the AMERICAN RACING headers without a hitch.This system by far the BEST FITTING,BEST SOUNDING ,EASIEST TO INSTALL on the market today.
Magnaflow must have had a Camaro with ARH Headers to mock this one up on...I swear they did.I was sceptical on what I wanted to keep in the middle....ARH OR MAGNAFLOW.The choice was use all the magnaflow up to the cats.It made more since because you get better clearance than ARH has in the middle of the car...everybody knows that area.We had plenty of room everywhere.
The sound that magnaflow came up with is just perfect..a little rumble at idle,and a tiny bit(very tiny) of rasp mixed with very strong deep tones.On a stock car with all 4 cats it could possibly be to quiet.With this being said I will probably recommend this system for HEADER GUYS ONLY.
Audio -
Here are some pics:
I had to TIG weld the cats from the ARH Center (16" for those that want to know the numbers)
Good job Magnaflow....I will never sell another 2.5 system for as long as I live.
Dyno results coming soon on a bone stock 6spd manual.
Andy
www.admperformance.com
ADM PERFORMANCE is offline   Reply With Quote
Old 09-05-2009, 11:02 PM   #2
ADM PERFORMANCE
Pics of my 427 Camaro exhaust built a couple months back
I am glad I took these pics:
Old 09-05-2009, 11:14 PM   #3
GJG
GJG's Avatar
Drives: 2SS
I wanna hear it!!!
btw....when will you have the Pfadt coil overs ?
Sleep well America.....my MARINE has your back......
GJG is offline   Reply With Quote
Old 09-05-2009, 11:25 PM   #4
ADM PERFORMANCE
Originally Posted by GJG View Post
I wanna hear it!!!
My little video camera is at the shop with the video -
I will call monday and see how far out they are.
Andy
Old 09-05-2009, 11:30 PM   #5
Melson
Melson's Avatar
Drives: Wild Cherry
I can tell you it sounds GREAT!........it was my car! I am so glad that I waited on the 3 inch magnaflows...................
2010 RJT 2SS/RS L99 CAMARO
ARH 1 7/8" LT HEADERS W/ HF CATS
MAGNAFLOW 3" COMP EXHAUST
ADM PERFORMANCE CAI
ADM PERFORMANCE CUSTOM TUNE
ADM PERFORMANCE PORTED THROTTLE BODY
ADM PERFORMANCE TRANS COOLER
3.45 GEARS
BMR TRAILING ARMS
Melson is offline   Reply With Quote
Old 09-05-2009, 11:32 PM   #6
DTM
DTMphotography
DTM's Avatar
Drives: 10' Camaro SS
Sound clips!!!
2010 2SS/RS: 12.77 @ 111mph (muffler delete) - SOLD
DTM is offline   Reply With Quote
Old 09-05-2009, 11:41 PM   #7
_GTO_
_GTO_'s Avatar
Drives: holden commodore
I saw the magnaflow system for the camaro but this one is different cuz this one has a tru x-pipe not like the normal one which is mufflerd !!!
And BTW you've got the perfect choice , just what I want to have :-)
I'm waiting for the Dyno results , ThanX .
_GTO_ is offline   Reply With Quote
Old 09-06-2009, 12:51 AM   #8
Li0nel1234
What should I name my car
Li0nel1234's Avatar
Drives: 2010 Camaro 2SS RS IOM
Send a message via AIM to Li0nel1234
What does the Xpipe do?
Performance: ARH 2"/"3 headers + ARH 3" HF catback system, SS brake lines, hawk HP+ pads, motul RBF 600 fluid, K&N CAI (w/custom insulation), plug wires, air scoop, Hurst STS, Pedders Track II suspension, 18x10 wheels, 295/45/18 Nitto NT05s
Looks: powder coated iom calipers, LED foglights w/ always on harness, custom painted bowties, window tint, smoke tinted tail lights etc, oem gfx w/ custom outlets, painted taillight bezels, all weather trunk mat
Li0nel1234 is offline   Reply With Quote
Old 09-06-2009, 12:54 AM   #9
Kilo-9
Dog Is My Copilot
Kilo-9's Avatar
Drives: 2011 2SS/RS LS3
This setup looks sweet. I like the true X setup vs. joining the two pipes in the middle design. Can't wait to hear this setup and see the numbers.
Can you buy just the headers and cats without the x-pipe from ARH?
Andy, do you think there would be any problem having the inlet pipes of the true-x flared out to slip over the pipes exiting the ARH cats in lieu of TIG welding them together?
Kilo-9 is offline   Reply With Quote
Old 09-06-2009, 01:04 AM   #10
Kilo-9
Dog Is My Copilot
Kilo-9's Avatar
Here is a good explanation from a Car Craft article:
For any performance exhaust system, some type of crossover connecting the two sides of a dual exhaust system is important because it acts to balance the two banks of the engine. The common H-style crossover is good at balancing sound pulses between the two halves, but does little to promote scavenging because the exhaust gases tend to follow the path of least resistance, which is straight through each pipe rather than taking the 90-degree turn through the H-pipe into the other half of the system. In an X-pipe system, however, where the two sides of the system intersect, the gasses have no choice but to intermingle as they pass through the junction. This promotes improved scavenging effects by smoothing out uneven exhaust pulses from the engine’s firing order.
Old 09-06-2009, 01:46 AM   #11
MaroSS
ZL1
MaroSS's Avatar
Drives: 10' SS/RS - Sold; 15' White ZL1
Where did you get the true X-Pipe that thing is SICC!!!
MaroSS is offline   Reply With Quote
Old 09-06-2009, 08:41 AM   #12
ADM PERFORMANCE
Yes you can buy Headers Only!
Yes we will have slip fit cats and offroad pipes.
Andy
Old 09-06-2009, 10:15 AM   #13
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
I have a question about the exhaust tips. In the one picture the exhaust doesn't have any exhaust tips. Are the tips not welded to the exhaust? How are the tips installed on the exhaust?
Thanks,
The exhaust looks great.
Old 09-06-2009, 11:27 AM   #14
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Thanks,
The one Andy is talking about (first set of pics) does have tips .. the 2nd set of pictures is something custom Andy did on his 427 Camaro before the 3inch Magnaflow system was available
Crowley
Crowley is offline   Reply With Quote
Magnaflow V6 Street Series Sound File* JDP Motorsports Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 26 10-03-2016 05:49 PM
Magnaflow Competition Series VIDEO SOUND CLIP!! #16580 linkwpc Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 58 12-21-2011 11:29 AM
Doug Thorley Shorty Headers for 2010 Camaro Installed -WOW! Rallyman6 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 64 03-13-2011 01:36 PM
Magnaflow Exhaust 2010 Camaro JDP Motorsports Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 95 05-24-2010 01:17 AM
Exhaust sound bulldog Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 07-07-2009 03:43 PM
