Solo Performance
Old 09-06-2009, 10:59 AM   #1
halo8hkk
Drives: 2000 Z28. 2010 1SS IMB.
Ring Gear Size
maybe this has been answered and i cant find it. does any one know the diameter of the ring gear (example 8.8in, 7.625, ect) Ive tried Google it and i cant seam to find it. i know its not a common size i was just curious about how strong it is.
1990 RS = First Car -SOLD
2000 Z28 = SOLD
2010 1SS/RS = Mysstique
Whipple Supercharger
Dyno= 618hp 555tq at the wheels
IMB Silver Stripes
VIN#44025
Born: 9/9/09 Delivered: 9/28/09
halo8hkk is offline   Reply With Quote
Old 09-06-2009, 02:42 PM   #2
halo8hkk
i take it no one knows????????????????
2000 Z28 = SOLD
IMB Silver Stripes
VIN#44025
Old 09-06-2009, 05:13 PM   #3
Rummel Autosport
Drives: 92 Skyline GTR, 89 240SX
I believe it is the same rear end casing as a GTO, or pontiac GXP (the 4-door not the solstice).
I don't remember what it is off hand, but it shoudl be the same one from what I remember, so look it up for a GTO for now.
Rummel Autosport is offline   Reply With Quote
Old 09-10-2009, 07:31 PM   #4
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Ask Robin Lawrence on this site. He is from GM Powertrain. I believe he told me that the ring gear is 8.6" and the center section has a 2 pinion positraction unit.
Old 09-10-2009, 07:36 PM   #5
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
Why don't you call the manufacture.
http://www.aam.com/index.php?s=199
Old 09-11-2009, 12:26 PM   #6
Robin Lawrence
Robin Lawrence's Avatar
Drives: 2010 Camaro 69 Nova
I am not from GM Powertrain. I work with GM Performance Parts.
We compared the Ring and Pinion to a G8 setup and they are close but not close enough.
It is a 8.6" plus a little bit from what I am told. American Axle supplies the assembly with components from several vendors.
From what I have observed the center section is made by ZF. The half shafts are made by Delphi.
I have had issues with "one wheel peel" during burnouts at the track.
I had contacted some people at Eaton about making a True Track diff but they have a lot of other priorities at this time.
I have sent a 3.27 R&P to my buddy at Motive in the hopes that they will develop a gear for the Camaro. The center section is aluminum so there is a limit to how much power that will hold.
I noticed that someone talked about building drop in center sections. IMHO this would be the best way to get the gears and diff that we need.
Robin
Holley Performance Products
Robin Lawrence is offline   Reply With Quote
Old 09-11-2009, 01:21 PM   #7
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
Robin
I hope somebody will do it!! Hopefully this winter. I have a serious build that you all will love to see, but my only concern is the rear diff and gears. I have everything else covered already! and yes this whole build will be documents, and available as several packages.
But yes I think a driveline company should make drop in rears that can handle real power.
ZZcamaro is offline   Reply With Quote
Old 09-11-2009, 04:12 PM   #8
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
if no one has a ring and pinion kit by spring im just going to buy a LS3 rear diff for my L99 car and gain a little from the 3.27 to a 3.45,,id really like a 3.73-3.90,, the complete rear diff can be purchased for around $1100 from gm
Old 09-11-2009, 06:40 PM   #9
Becustom
ProCharged 600 + RWHP
Becustom's Avatar
Drives: 2SS/RS White/Hugger Orange
So there is nobody making a 3.90 or 4.10 for these rear ends yet ?
They really need a gear.
Becustom is offline   Reply With Quote
Old 09-11-2009, 06:48 PM   #10
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2010 2SS/RS/M6
NY5thgen.com
POWERFREAK is offline   Reply With Quote
Old 09-12-2009, 08:17 PM   #11
PoleCat2SSRS2010
R6P Marketing Lab Rat
PoleCat2SSRS2010's Avatar
Drives: 2015 ZL1 for weekends mostly
Robin
Is there anyone brave enough to take the pioneer route and get with Currie to get a 9 inch made into a IRS that will bolt right in and have the same wheel bolt pattern? At least that way there is room for power and an almost infinite selection of gear ratios. I have seen things like that before in other cars.
What about the Corvette guys? What are they doing to support high power?
Just wondering but it seems frustrating to feel stuck in a box for now and not have any choice.
PoleCat2SSRS2010 is offline   Reply With Quote
Old 09-12-2009, 09:26 PM   #12
Kenny
Kenny's Avatar
Drives: 2010 SS RS IOM M6
Delivered July 30 2009
Kenny is offline   Reply With Quote
Old 09-12-2009, 09:32 PM   #13
ZZcamaro
Old 09-12-2009, 09:57 PM   #14
rodimus prime
Drives: Cargo van.
Vengence Racing is trying to get some done by January.
rodimus prime is offline   Reply With Quote
L99, A6 (1st gear discussion?) SGOS252382 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 31 07-26-2015 10:56 AM
Piston to Valve Clearance? My First Camaro! Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 08-18-2009 07:26 PM
Using 6th gear? ladysman07 5th Gen Camaro SS LS LT General Discussions 33 08-17-2009 07:35 PM
Do you think it was right that the mustang got to use the trackpack in the comparison perfxn Chevy Camaro vs... 91 03-30-2009 09:44 PM
Camaro Manual Transmission LSxcellent 5th Gen Camaro SS LS LT General Discussions 17 08-01-2007 05:11 AM
