JUICEDMOTORSPORTS
Old 09-06-2009, 02:08 PM   #1
tradosaurus
Drives: 2010 F150 Lariat, Candy Red
Oil Filter - Owners Manual
The owners manual calls out a GM#12593333 or AC # PF4596 for an oil filter.
O'Reilly's could not cross reference that number although someone said they used a AC# PF2129.
The 2129 looks awfully small. Will the PF4596 be the same size?
tradosaurus is offline   Reply With Quote
Old 09-06-2009, 03:34 PM   #2
markssylver
markssylver's Avatar
Drives: 95 bbb impala ss
i got a mobile 1 filter it was m-1 113
10.56@134mph
ADM BUILT AND TUNED CGM 2SS RS
ADM/LPE 417 with ported heads/inconel vavles gt11 cam
ADM ported maggie with 14 rib rear 10 rib front pulleys
ADM fuel system and race air intake
ADM/LPE ZR1 clutch /pedalreturn spring
ADM billet aluminum valve covers /RPM LEVEL 6 TR6060
LPE HD 241mm diff with 3:45 gears HD axles and d/s
ADM widened wheels with 315nitto nt05s Bogart 17 dragwheels CTS-V front 6 piston brakes
Pedders HD subframe/differential bushings alignment kit 27/32mm sways Supercar coilovers
683RWHP/650RWTQ
markssylver is offline   Reply With Quote
Old 09-06-2009, 04:45 PM   #3
LS/V6
LS/V6's Avatar
Drives: 1LT
have them cross reference a Pennzoil filter number PZ-55. if u have a V6
LS/V6 is offline   Reply With Quote
Old 09-07-2009, 10:15 PM   #4
fee5fofum
fee5fofum's Avatar
Drives: 2012 CTS-V Coupe & 2SS/RS
AC-Delco PF-2129 is the right oil filter for the V6 .
Here's the best place to find any part for your 2010 Camaro:
http://www.rockauto.com/catalog/shoppingcart.php
Also if you want to cross reference this with others like the K&N HP-7003 and others , here is the chart to confirm that the PF-2129 is the right filter for the V6:
http://www.knfilters.com/search/kn_c...x?part=HP-7003
Hope this helps ...
fee5fofum is offline   Reply With Quote
Owner's manual in PDF form mikenmar 5th Gen Camaro SS LS LT General Discussions 3 06-16-2010 07:50 AM
Need Opinion on Oil Change 68blk/yel396 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 22 06-22-2009 12:02 PM
