Emblempros
Old 09-06-2009, 06:52 PM   #1
pharmd
Master of Medicine
pharmd's Avatar
Drives: 4th Gen
Washer fluid/tank question
Does anyone know how much volume the washer tank holds?
And does the car have a low washer fluid light?
2002 Camaro SS. 408 LS2. 500+RWHP/480RWTQ. Full UMI RR suspension. Koni/Strano. 295F/315R. 3500#(55/45)
pharmd is offline   Reply With Quote
Old 09-06-2009, 07:19 PM   #2
tradosaurus
Drives: 2010 F150 Lariat, Candy Red
Its in the owners manual which can be downloaded at this site.
It's amazing how much reading I accomplished while in the crapper:party0048:
tradosaurus is offline   Reply With Quote
Old 09-07-2009, 08:46 AM   #3
pharmd
Master of Medicine
pharmd's Avatar
Drives: 4th Gen
I looked in the owners maual that came with the car and it doesn't say anything about that (just oil, tranny, rear end etc fluid types and volumes). I didn't see anything about low washer fluid warning, it just shows what the washer symbol looks like.
Old 09-07-2009, 04:44 PM   #4
tradosaurus
yes, you are right. The manual doesn't specify windshield washer fluid capacity.
You could empty it out and then start filling it with a gallon jug to see how much it would hold.
I don't remember any my cars holding more than a gallon of washer fluid when the reservoir was empty.
Old 09-07-2009, 09:18 PM   #5
pharmd
Master of Medicine
pharmd's Avatar
Drives: 4th Gen
I ask this because I want to use it for a Methanol reservior, and they sell a larger container, I just figured this one has to be a gallon or more...and instead of buying their low meth indicator, if the stock tank has a level indicator, then when(if) if says low washer fluid, I'd know I was almost out of methanol.
Old 09-07-2009, 11:31 PM   #6
crzycicada
crzycicada's Avatar
Drives: 2SS/RS/LS3
I don't see an actual measurement called out. If you really want to know, I'd empty the fluid currently in your washer fluid tank and then put a gallon of whatever in it. If that doesn't fill it up (which I bet it will) then add measured amounts until it is full. A pain in the a$$ way to do it but it's not in the manual and there's nothing on the reservoir itself.
Order date: 7/17/09
3000 TPW: 8/17/09
3400 status on 8/11/09
3800: 8/21/09
4200: 8/24/09 on rail car ETTX850796
5000/6000: 9/2/09
crzycicada is offline   Reply With Quote
Question About Camaro Copre 5th Gen Camaro SS LS LT General Discussions 7 09-06-2009 10:56 PM
Please answer my question... IROCanSS 5th Gen Camaro SS LS LT General Discussions 23 07-16-2009 05:49 PM
LS3 Transmission Question Seawolf 5th Gen Camaro SS LS LT General Discussions 13 06-12-2009 02:16 PM
Question about the After.... Tecca Camaro Price | Ordering | Tracking | Dealers Discussions 1 04-15-2009 04:05 PM
OK WILL SOMEONE PLEASE ANSWER THIS QUESTION OM FINANCING leatherneck Camaro Price | Ordering | Tracking | Dealers Discussions 22 03-26-2009 03:53 PM
