Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Technical Camaro Topics > Wheels and Tires Talk Sponsored by The Tire Rack
Old 09-07-2009, 09:55 PM   #1
G.E.'s Avatar
Drives: black on black twenty ten ss/rs
Springs or coilovers? Eibach or BWoody?
I've been told that Eibach and BWoody would give me the smoothest ride... i've also been told i should wait for the coilover so i wont have to worry about putting wear on my shocks faster instead of getting springs... however coilovers would be much more exspensive but is supposedly worth it... What would you recommend for someone who just wants simple system with a nice lowered stance (like the eibach pro kit) and wants the smoothest ride on a bumpy surface?
G.E. is offline   Reply With Quote
Old 09-08-2009, 09:07 PM   #2
IPS Brandon
IPS Brandon's Avatar
Drives: 2010 Camaro SS black
Send a message via AIM to IPS Brandon
Coilovers will offer the best ride, and suspension set up for your camaro. A set up like pfadt racings units The coilovers valving is better engineered for high performance and higher rate springs. The coilovers also will have adjustable dampening, which will allow you to set the rides stiffness or softness to your specific liking. So a softer setting around 2-4 will ride smoother over the road then say 14-16 . The coilovers will also allow you to adjust the ride height on the car with out sacrificing suspension travel, which is commonly a problem with lowering springs on stock struts. So in the short summary, coilovers are going to offer you maximum performance, but may be a little over kill.
If I was recommending a set up for your camaro, It sounds on the surface that you looking for a more basic setup, to lower the stance of your camaro and also have achieve a smooth ride. The lowering springs will shorten the life of your stock stuts due to them not being designed to have the proper shock valving for the spring rate upgrades that eibach, pfadt, or H&R offer. They will wear the shocks from our experience 20% faster, and you will notice once the shocks wear out when the car has a much bumpier feel and may travel to the bump stops more often. But don't worry this doesn't happen over night, typically takes about 25-40k miles depending on usage. In short on the lowering springs, yes they will shorten the life of your factory shocks, but the shocks will still last a fair amount of time, they will ride similar to stock, but offer a lower center of gravity, and a better feel.
Good luck, if you have questions feel free
IPS Brandon is offline   Reply With Quote
Eibach ProKit Lowering Springs in Stock | FREE S&H! AJ@ECSMotorsports Suspension / Chassis / Brakes 139 11-17-2010 02:23 PM
Want to Lower Your Camaro? Step Inside! Eibach Springs and Sways Now Shipping! Kris@BMCPerformance Suspension / Chassis / Brakes 20 01-15-2010 09:09 PM
Eibach Lowering Springs and Sway Bars Now Shipping @ BMC Performance Kris@BMCPerformance Suspension / Chassis / Brakes 6 11-14-2009 08:34 PM
My Eibach lowering springs (Pro Kit) newgenss Wheels and Tires Talk Sponsored by The Tire Rack 11 09-08-2009 01:34 AM
