Old 09-08-2009, 10:22 PM   #1
tommygun6644
tommygun6644's Avatar
Drives: 2010 Camaro 2SS/RS & 2006 Cobalt LT
Launch Control problems
Hey guys, I did a search and couldn't find my exact problem, but forgive me if I missed it.
Anyways, I HAVE gotten launch control to work in my car before (when I first got it back in June), but am recently having problems using it.
So, I hit that button twice, put it in competition mode while the car is not moving, put it in first gear, floor it and dump the clutch, correct?
Well, when it works, the RPMs hover around 4-5k (?) I believe.
But recently it will just red line, making it so the ass end kicks out when I launch it (yikes).
Has anyone else had this problem, or has it been addressed?
tommygun6644 is offline   Reply With Quote
Old 09-08-2009, 11:20 PM   #2
Dan3
Captain of the Failboat
Dan3's Avatar
Drives: 2010 IBM Camaro 2SS/RS
I have heard rumors that having it in "competitive mode" is supposed to optimize your RPMs... but my car's optimum launch seems to be around 7k RPM if it's working. All that pushing the button twice has ever done for me is limit the rear wheel slippage on takeoff.
2010 Camaro 2SS - Imperial Blue w/Black Leather Interior
Ordered - 22 June 2009
Produced - 10 August 2009 : #34143
Delivered - 25 August 2009
Dan3 is offline   Reply With Quote
Old 09-08-2009, 11:50 PM   #3
macula
Drives: 1ss cgm rs
I've found that if you push the pedal to the floor slowly it will not recognize launch control and simply rev to redline. When I mash the pedal fast, it holds at around 4600 rpm.
macula is offline   Reply With Quote
Old 09-09-2009, 12:55 AM   #4
tommygun6644
Will try next time I'm out, thanks
Old 09-09-2009, 01:03 AM   #5
c0rsa180
c0rsa180's Avatar
Drives: 2010 Camaro SS/RS IOM
This is the issue when using launch control, you have to put the pedal to the floor in order for it to limit the rpm's, if you do it slowly it wont recognize this and wont engage the launch control
Inferno Orange Metallic
2SS
RS
M6
ordered 2/17/09
c0rsa180 is offline   Reply With Quote
Old 09-09-2009, 05:55 AM   #6
Scott@Bjorn3D
Scott@Bjorn3D's Avatar
All the magazines said they got better times without launch control and launch control has been helping blow apart transmissions. If #230 was a LS3 I would not use launch control, but thats just me.
Scott@Bjorn3D is offline   Reply With Quote
Old 09-09-2009, 07:34 AM   #7
Dan3
Dan3's Avatar
Where does the engine get ~4600rpm for an optimum launch? Launching at 3k I still get a bit too much wheel spin on some surfaces... 4k+ is just for leaving pretty black lines on the pavement, and wreaking havoc on your drivetrain.
Old 09-09-2009, 06:15 PM   #8
tommygun6644
So it is not wise to use launch control is what you guys are saying?
Old 09-09-2009, 06:30 PM   #9
ShnOmac
ShnOmac's Avatar
Sounds like you got to get the pedal to the floor pretty quick.....
Some info in here...
http://www.camaro5.com/forums/showthread.php?t=30849
ShnOmac is offline   Reply With Quote
Old 09-09-2009, 07:22 PM   #10
bolteon593
Drives: 2011 GT500
while in neutral, turn on comp mode, floor the gas, clutch in, shift to first; dump clutch and go weeeeeeee!
bolteon593 is offline   Reply With Quote
Old 09-09-2009, 10:48 PM   #11
djsnoflake
Faith Keeper
djsnoflake's Avatar
I used Launch Control at the local strip, and I still got tons of wheelspin, I found that launching at about 2700 RPM, then proceeding to hold the gas pedal about 3/4 of the way down for about a second before you completely floor it was working the best for me
2010 Camaro Launch Control = Transmission Failure camaroguy Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 140 07-06-2013 12:27 AM
Camaro SS Launch Control jdpickering Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 35 12-23-2009 10:29 AM
Please EXPLAIN Stabilitrak/Traction Control, Launch Control! drtwo Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 9 09-29-2009 12:54 PM
Launch Control Problems.... 20 Camaro 10 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 6 07-15-2009 06:50 AM
COMPETITIVE MODE AND LAUNCH CONTROL (V8) DIRECTIONS CamaroScotty 5th Gen Camaro SS LS LT General Discussions 80 05-02-2009 01:20 PM
