SDTW Custom Wheels & Tires
Old 09-10-2009, 11:06 AM   #1
Fastlane
Drives: 2010 Silver 2SS
Send a message via Skype™ to Fastlane
2010 ZL1 Turbo Camaro
We just wanted to drop in and show you pictures of a customers car with our ZL1 Turbo kit. The 5th generation Camaro features a potent is LS3/L99 engine that puts down anywhere from 310 to 340 hp to the rear wheels. This leaves a large margin for improvement with all of the Challengers and Shelby Mustangs roaming the streets these days. At only 6 lbs of boost, a L99 Camaro that started its life with only 313 RWHP with 333 ft-lbs of torque has gained a an astonishing 200 RWHP to 528 RWHP with 528 ft-lbs of torque. All of these gains were accomplished on an Automatic with 93 octane premium fuel. The drivability of the Camaro remains the same, but once the Camaro reaches boost there is more than enough power to shred the tires as you go through the gears!
Fastlane’s ZL1 Single Turbo kit is built around a BorgWarner extended tip turbo with a 71.5 mm compressor wheel. The turbo is high-mounted in the engine bay to a custom stainless steel exhaust manifold featuring a stout 3/8” flange with 1.75” primary tubes. The primary tubes flow into a 2.5” common manifold with a 2.5” crossover pipe to equalize pressure. Spent gas is vented through a 3” downpipe to a high flow 3” 304 stainless steel exhaust system. The turbo features a custom turbo blanket and all exhaust side plumbing is heat wrapped to keep under hood temperatures down. Air is drawn in through a cold air setup through a lifetime oil-free dry flow filter.
Hot air is cooled to a dense charge through an 18 x 18, 3 core air-to-air intercooler that tucks behind the front bumper with no modification or cutting whatsoever. This leaves unsuspecting drivers in wonder of the true capabilities of this potent platform. The entire turbo kit is plumbed with 3” mandrel bent intercooler piping, promoting flow to the stock engine. To relieve pressure between gears every time the throttle plate closes, pressurized air is vented through a 50mm Tial blow off valve.
Side view of the car...
Engine bay with the Borg Warner Turbo...
24" Wheels anyone...
Truth in the numbers...
Fastlane is offline   Reply With Quote
Old 09-10-2009, 11:08 AM   #2
Andro
NOICE!!! ™
Andro's Avatar
Drives: Force Fed 427
I like everything but the wheels, there to big for my taste
Old 09-10-2009, 11:42 AM   #3
talwell
talwell's Avatar
Drives: 1969 LS1 Camaro
Just a quick opinion - it is really a bad choice of name for that package to call it ZL1. The ZL1 name should not be used by anyone other than GM in reference to a package they offer on a production car.
talwell is offline   Reply With Quote
Old 09-10-2009, 02:01 PM   #4
Kyle2k
LVL 50 Troll Stomper
Kyle2k's Avatar
Drives: 2010 Camaro
I love how big that turbo is! Can we get more engine bay pictures please ?
Kyle2k is offline   Reply With Quote
Old 09-10-2009, 02:48 PM   #5
Fastlane
I will get more pics up later today of the engine bay.
Old 09-10-2009, 02:51 PM   #6
1320junkie
Drives: The Imperial Army
Pretty nice and do you have any videos? What are the specs on those rims? 24x??
Old 09-10-2009, 11:44 PM   #7
HOLSUM 1
HOLSUM 1's Avatar
Drives: 2010 camaro ss
looks great! How is drivablity when your not pushing and hows turbo lag?
HOLSUM 1 is offline   Reply With Quote
Old 09-11-2009, 03:16 AM   #8
LSX-80MM
Ghostly Unknown
LSX-80MM's Avatar
Drives: Silver Ice 2010 SS/RS A6
6lbs of Boost?Man turn that bioch upyall just tickling itBet that thang rides good wid delm twanky furs
TS416,GMPPLSX-LS3 6 Bolt Heads,Custom 80mmComp Turbo,ID850 Injectors, Lonnies Twin Pump Setup,Level 3 4L80E,DSS,3in Magnaflow Exhaust,CoolingMist Meth,RX Dual Catch Can,InnovateWB,Aeroforce Interceptor,AEM Truboost Controller,matte black CF5 Forgestars.700rwhp/712rwtrq
LSX-80MM is offline   Reply With Quote
Old 09-11-2009, 03:26 AM   #9
2003vette
Drives: 2003 black corvette ls1
bigger turbo.. more turbo lag... :|
2003vette is offline   Reply With Quote
Old 09-11-2009, 06:22 AM   #10
Z/28orSs
Z/28orSs's Avatar
Drives: 2000 ss
KINDA risky using the "ZL1" name plate dont ya think?
Z/28orSs is offline   Reply With Quote
Old 09-11-2009, 07:02 AM   #11
tsnow
tsnow's Avatar
Drives: 12' ZL1, AGM 6M
looks like a sweet setup, interested to hear more details. I agree with above though.
tsnow is offline   Reply With Quote
Old 09-11-2009, 01:26 PM   #12
Fastlane
As requested, some more pictures of the engine bay.
All the best.
Old 09-12-2009, 05:56 AM   #13
salohi
salohi's Avatar
Drives: 90 Black Camaro, 02 Sable
can we get more of the setup pictures and some vid for the sound
2SS/RS
Black/Black
6Spd. Aut.
salohi is offline   Reply With Quote
Old 09-14-2009, 09:48 AM   #14
Fastlane
Here is a link to a video of the Turbo Car.
I will post up the video of the 6 speed car soon.
Take a look at the Dyno Sheet, minimum lag. Driveablity is as you would expepect, but with a lot more the farther you depress the pedal.
Please let me know if you have any questions.
08 Cobalt Turbo Compared To 2010 Camaro V6? SilverCamaroSS Chevy Camaro vs... 114 12-07-2010 10:16 AM
10 Camaros that should be built SSOOCH 5th Gen Camaro SS LS LT General Discussions 47 11-03-2009 06:46 PM
Tom Henry Racing Announces a Special Edition 2010 Camaro! TAG UR IT 5th Gen Camaro SS LS LT General Discussions 72 04-30-2009 01:57 PM
Camaro (concept) Press Release!! Pencil.Fight 5th Gen Camaro SS LS LT General Discussions 4 07-21-2008 04:33 PM
