Gen5DIY
Forced Induction - V8 V8 Supercharger, turbo, nitrous discussions
Old 09-10-2009, 10:29 AM   #1
mark_p
Drives: 2010 2SSRS m6
nitrous results
I thought I would post my nitrous results here since it is a forced induction section. The first dyno sheet is motor only. Stock and after engine work. The second is with with a small tester shot of nitrous and the second is my set up that I run daily. We pulled 5 degrees out and see no knock at all with 91 octane I am spraying through a HSW plate and it comes in real nice. Went through a couple bottle already and this LS3 loves the juice. If anyone here is thinking about nitrous it really brings this car to life.
mark_p is offline   Reply With Quote
Old 09-10-2009, 11:03 AM   #2
CamaroSpike23
The Jalopy Jedi
CamaroSpike23's Avatar
Send a message via MSN to CamaroSpike23 Send a message via Yahoo to CamaroSpike23
nice.
Originally Posted by Bulldogwinters View Post
Read that link that Spike posted, it'll tell you everything you need to know.
I piss excellence
and fart awesomeness
Old 09-10-2009, 02:27 PM   #3
14pilot
Original Bumblebee Owner
14pilot's Avatar
Drives: 265hp ZX-14, 500hp Silverado, V-ROD
Sweet! Great results there. Tell us more about both the "engine work" that netted you +75rwhp, and tell more about your nitrous setup.
#5 - 2010 2SS/RS MN6 ABM-Silver Rallys-GFX / Med Titanium
My previous Camaros:
#4 - 1994 Z/28 6M Black over Arctic White / Graphite-Red Inserts - traded
#3 - 1981 Z/28 Bright Blue Metallic / Black - sold
#2 - 1970.5 RS Mulsanne Blue / Blue - endo crashed it and parted it out
#1 - 1967 RS Butternut Yellow w/ Black Bumblebee Stripe-RPO D91 / Parchment-Black - sold
14pilot is offline   Reply With Quote
Old 09-10-2009, 02:58 PM   #4
Nick@HSW
Drives: many
Nice results!
Nick
Nick@HSW is offline   Reply With Quote
Old 09-10-2009, 03:19 PM   #5
hot ss
hot ss's Avatar
Drives: aqua 2ss l99
what size shot 150 or 250?
wet, i assume?
May your exhaust note, sing in harmony with your blower.
hot ss is offline   Reply With Quote
Old 09-10-2009, 04:03 PM   #6
mark_p
those are 125 hp jets. We went a little heavier on the fuel than the kits suggested to get the A/F ratio down to a real safe range.
The engine work is
Comp cam (custom grind) 219 229 and .561 .572 113 lobe (small cam)
921 dual springs
hardened pushrods
kooks Long tubes (1-7/8")
GMPP offroad axle back exhaust (left stock mid pipes in)
New Era intake
ZEX nitrous kit with HSW 360 deg spray plate
Custom tune with 5 degrees retarded fot the nitrous
Old 09-10-2009, 06:50 PM   #7
14pilot
14pilot's Avatar
Awesome setup. You are getting 117hp actual from 125hp jets, that's a really good number. Did I miss it? Wet or Dry Kit?
Old 09-11-2009, 07:57 AM   #8
mark_p
this si a wet ZEX competition kit. Not the kit they make for the camaro as it has tiny solinoids and is basically cheap. Th FI competition kit is the real deal. I did use HSW spray plate and the HSW jets though. And yes properly tuned in i would expect ~115 out of a 125 hsw jet as they are rated low and generally produce good numbers.
Nitrous info CamaroSpike23 Forced Induction - V8 58 11-13-2012 10:02 PM
Introducing the Nitrous Outlet 2010 Camaro Nitrous System! Nitro Dave Forced Induction 33 04-17-2010 08:01 PM
Nitrous Express Nitrous Kits Available for the 2010 Camaro V6 & V8! Kris@BMCPerformance Forced Induction 5 11-04-2009 09:46 AM
Nitrous Info Milk 1027 Wiki 0 08-12-2009 06:26 PM
BUDWEISER SHOOTOUT LINE UP CamaroScotty General Automotive + Other Cars Discussion 22 02-07-2009 07:03 PM
