Old 09-10-2009, 01:16 PM   #1
Kripp
Drives: 2010 LS3 SS Aqua Blue
LS3 Camshaft swap
I am doing a camshaft change (replacing it with another single bolt camshaft) on an LS3 motor. Does anyone know if the bolt can be reused? Also, the torque spec for reinstalling. Is it just a torque spec or is it like the cranshaft bolt.... torque and tighten another "X" amount of degrees afterwards. I have the new camshaft and looked it over. The threads are very fine threads. Comp Cams wasn't much help. The GM dealer wasn't much more help either. Thanks in advance!
Kripp is offline   Reply With Quote
Old 09-10-2009, 01:51 PM   #2
rodimus prime
Drives: Cargo van.
Every bolt can be reused except for the Crank/balancer bolt, head bolts and main bolts.
Are you talking about the cam gear to the cam bolts? there should be three.
Its 26 ft lbs on the ls1/2. I would imagine the l99/ls3 are the same. Dont forget locktite.
rodimus prime is offline   Reply With Quote
Old 09-10-2009, 02:20 PM   #3
Kripp
No, it is a single bolt cam.
Old 09-10-2009, 02:24 PM   #4
rodimus prime
Drives: Cargo van.
Yeah I was just coming back here after I looked into it. There are shops using the 3 bolt cam now too. Its all the same junk.
Old 09-11-2009, 02:43 AM   #5
Kripp
I found some info from a GM dealer. The torque spec on the bolt is 55 ft lbs plus 50 degrees. It should be replaced if removed.
Old 09-19-2009, 09:59 AM   #6
Kripp
I have an LS3 and I changed the cam (Comp Cams 146-458-11 227/243 .614/.624), springs and pushrods just last night. I have it running, but it will overheat in a matter of a few minutes. The center (digital) readout will keep going up, but the dial temp gage (under speedo) doesn't get into the hot range. It doesn't even get past the half way mark. Could there be an air pocket in the cooling system or the thermostat is stuck or something of the sort? Also, the power steering is noisy... Does that need to be purged of air or something? Is it too much cam compared to stock, and it needs a tune to run properly (is that causing the overheating)? Any help is greatly appreciated.
Old 09-19-2009, 10:14 AM   #7
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
How did you fill it.
Old 09-19-2009, 10:39 AM   #8
Kripp
I filled the radiator through the filler neck (a couple times & squeeze the hoses, etc).Should it be done a different way? I don't know if there is a specific procedure. Thanks
Old 09-19-2009, 10:56 AM   #9
2SSRS@Gen5diy
Yes you need to add to the radiator after you get it up to temp, stop the car and add after it is cold, it will take like 2-3 time's as it gets all the air out, Hope it helps.
Old 10-01-2009, 02:18 PM   #10
66DeuceLS1
66DeuceLS1's Avatar
Drives: 2010 2SS/RS SIM M6 Hockey Kit
another trick that I use on all my thermostate changes it so drill a 1/8th inch hole in the outer ring with will assist in releasing air trapped in the block.
2SS/RS SIM M6 Polished 20's, Hockey Strips,
GFX, Kooks LT's, High flow CATS, Magnaflow x-pipe, Vararam CAI
66DeuceLS1 is offline   Reply With Quote
Old 02-14-2010, 08:38 AM   #11
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
the single camshaft bolt is a 1 time use only.
also it helps to purge air by removing the upper hose from the radiator and filling the block with coolant from the upper hose
or
if you have a VACUFILL you can fill the entire cooling system in 1 shot without even starting the engine, if you ever use one of these you will never do a cooling system without it.
Old 03-15-2010, 03:05 AM   #12
urr2slo
urr2slo's Avatar
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm
lift the front end, ramps, or on jack stands and let it run, add coolant as needed. it helps get all the air pockets out.
URR2SLO - If you're not going fast enough, get out the way......
urr2slo is offline   Reply With Quote
LS3 engine specifications Tran Wiki 3 10-06-2010 11:56 PM
LS3 Second-Generation Camaro Engine Swap Drsandman2 1st & 2nd Generation Camaros 9 01-21-2010 05:53 PM
LS3 Specs revealed: GM's 436hp Sick 6.2L LS3 TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 07-30-2009 07:02 PM
ls1 to ls3 engine swap questions? Anti-Venom 4th Generation Camaros 2 07-03-2009 06:33 PM
Check your Order here bvonscott Camaro Price | Ordering | Tracking | Dealers Discussions 665 06-29-2009 02:00 PM
