| V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) Driveshafts | Differentials | Gears | Rearends | Clutch | Shifters |
Thread Tools |
NEW Driveshaft shop High output axles!
Having worked along with the driveshaft shop guys for a while now, and using their products in our 160 mph+ 1/4mi C6Z, there shafts just don't break!
They recently just released a level 5 axles for the 2010 and up cars, and it couldn't have come any sooner, with all the reports of heads/cam, spray, blower, turbo car breaking the axles ect. So check it out "Description:The Level 5 axles for the new Camaro SS are designed to handle up to 1000HP. Using our chromoly center bars, 108mm Porsche-style CV's and bolt-on chromoly inner and outer stubs, these are a direct bolt-on that fit the stock hubs and come complete with all the necessary hardware. Not only will these axles handle the horsepower, we have used different diameter chromoly axle bars on each side which will eliminate wheelhop. Wheelhop at launch which can be extremely damaging to the drivetrain and makes getting traction very difficult. By allowing the axle bars to torsionally twist at different rates the result is traction, not wheelhop. These axles are priced as a set and have a 1-year warranty" ![]() Feel free to ask questions and we will do our best to answer them asap. Regards -Brandon |
LVL 50 Troll Stomper
Drives: 2010 Camaro Join Date: Feb 2008
Damn those are expensive
That's Right 478whp450tq!
Drives: 2010 2SS/RS Rally Yellow Join Date: Mar 2009
Not in the grand scheme of things, if someone has spent the money to get their car anywhere near 1000hp then this would be just another expense.
I would like to apoligize ahead of time if any of my posts bother you, I am quite a large smartass and very expressive of my opinion!
![]() I came here to chew bubble gum and kick ass and I'm all out of bubble gum! ![]() Ordered Feb. 13 2009: 2SS/RS/M6/Sunroof/ Rally Yellow built 8/7 Vin# 33534, Delivered 8/26/09! |
Yes but if your one of those people pushing 600 and still breaking things...it kind of sucks...
gotta pay to play. running with the big boys is never cheap.
2010 Camaro SS-758rwhp, 664rwtq STOCK BOTTOM END!!! 10.52@134mph 1.63 sixty foot.... 93OCTANE!
06 Cummins- 466whp 940wtq EFI LIVe |
#6 |
SST...
Drives: SST Camaro 2010 Join Date: Oct 2008
Cool stuff Brandon...
Nice axles. |
#7 |
![]() Drives: 2010 CGM 2SS 6spd Join Date: Apr 2009
I can see these going into a lot of cars in the near future with all these cars shafts/axles going out!
#8 |
After we snapped two axles and a drive shaft in just one car, we figured we should work on a solution! We are offering free shipping to help a little, but these axles just use expensive components that will yield great strength and reliability!
-Brandon |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: fanboys and ass kissers crazy. Join Date: May 2008
"BBOMG - More than just a car show.... It's an experience!" |
#10 | |
#11 |
R6P Marketing Lab Rat
Drives: 2010 2SSRS for weekends mostly Join Date: Feb 2009
This subject has everything in it and it is the result of what some have been concerned with from the onset. Now we are finding out that even with the non-modded engines that the current axle design is causing wheel hop (as always suspected and known) which causes the CV boot to come loose and then the grease and then the joint failure. If the IPS design is truely sound it will cure the ailment but the other contraversy not yet mentioned here is the instant loss of any drivetrain warranty from GM since this is a non GM part. Truely the definition of mixed emotions.
The other thing to consider, IF one is lucky enough to get GM to warrant a replacement, it will most likely be the same part or slightly bigger and that person will most likely be going back more times for the same thing. Had I known and if it were even possible, I would have negotiated OUT the warranty cost all together and just take the 90 day mandatory and leave the rest to my own accord. But that was not an option. grrrrrr. |
#12 | |
High on "The Camaro Life"
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam Join Date: May 2009
The joint fails first, causing the pieces to fly apart, which blows the boot off, resulting in grease all over the place. If the boot came off first it would take quite a while before the joint failed, usually in this scenario you would hear the joint making all kinds of noise as the grease washes away from the joint. Which would take quite a few days of driving.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
#13 | |
These axles are very similar in design to others we have used, they will hold up as good as anything available currently. Regards |
#14 |
![]() ![]() Drives: Getting 2010 Camaro Join Date: Jul 2008
looks good. I'll more than likely be grabbing a set of these for my soon to be everyday driven Procharged Camaro. I like things bullet proof. Not half @$$ed.
Since you guys obviously play with allot of Camaros and vettes. Once these axles are replaced, how is the rest of the camaro diff strength wise? What about the stock driveshaft? Should that be replaced as well? Carbon Fibre or aluminum for a replacement? Thanks.... |
#15 |
The camaro diff itself we haven't had trouble yet, and we are racing weekly a 630 wheel prochargerd car like your build. We have however snaps the bolts that hold the rubber carrier to the rear diff and driveshaft. We are working on some sort of option here, but nothing yet, and honestly we not sure just yet if this is going to be a common problem like the axles yet.
Regards |
#16 | |
#17 | |||
It is the frustration that we wish we all can avoid. I can't wait to hear about my inquiry. Glad you guys are on the front end of this and already working the bugs. |
#18 |
![]() Drives: Only Bowties! Join Date: Jan 2009
Still cheaper than a 12 bolt for a 4th gen.
#19 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Off Into The Sunset Join Date: Mar 2008
Or even stock horsepower under certain conditions it seems. So I need $2500 w/ installation axles, and a beefier TR 6060 output shaft. Or just never smoke the tires. Of course, GM will jump at the opportunity to void your warranty for these pieces as well.
| Thread Tools | |
