08-27-2015, 09:36 PM | #1 |
Drives: Chevy Camaro Join Date: Aug 2015
2016 SS Goodyear Runflat Tires
Are these the same size of tire on the SS 5 gen?
Also anyone have any idea on the mile life expectancy on the tire? 12,000? |
08-27-2015, 09:56 PM | #2 |
Drives: 2016 Garnet Red Camaro 2SS Join Date: Jul 2015
Yes they are the same size...12,000, they better be a lot more than that. The last pair of Goodyear Eagle F1's I had on my 4th gen SS, non-runflats, had a lot more miles than that on them. Not sure how long these will last.
2SS Camaro, Garnet Red, Adrenaline Red, NPP, MRC, A8, 5 Split Spoke Bright Silver Wheels (56W)
1100 Status - 7/24/15 (Ordered) 3800 Status - 10/13/15 (Built) 6000 Status - 12/22/15 (Delivered) |
08-27-2015, 11:24 PM | #3 |
Drives: 13 Camaro Join Date: Aug 2015
Well the tire is Goodyear Eagle F1 Asymmetric 3 run flat summer tires. Seeing how
Eagle F1 Asymmetric 2 run flat has 45k mile warranty I would expect at least 45k. Seeing the price of the tires I would hope something would warrant a warranty exchange on about 42k. |
08-28-2015, 06:29 AM | #4 |
They are not the same size, 5th gen had 245/45/20 front, 275/40/20 rear. The 6th gen SS comes with 245/40/20 front and 275/35/20 rear. Makes them about an inch smaller in diameter, which is a big difference, and will remove some weight where it will definitely help. I don't have high hopes for the runflats as far as performance or tire life though.
08-28-2015, 09:21 AM | #5 |
Moderator.ca
Moved to wheels & tires
-DG
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
08-28-2015, 09:21 AM | #6 | |
08-28-2015, 09:22 AM | #7 |
I checked Goodyear's website for the Asymmetric 2's, they say that they have NO tread life warranty on them, not sure about the 3's yet.
09-15-2015, 09:17 AM | #8 |
So if these tires won't be good performance wise, what would be the best tires to put on a ss once it gets here?
Ordered: 2016 2SS A8 Red Hot w/ Adrenaline Red Interior;
NPP, MRC, 6 Piston Upgrade, Black Split Spoke, Black Bowties 3800 Status - 10/14 |
09-15-2015, 09:50 AM | #9 |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
Michelin Pilot Super Sport's are considered the gold standard by many. About $1300 for a set. #1 rated tire on TireRack in the segment (max perf summer)
I hope the 6th gen Camaro has a melodious horn trumpet. I'll tootel it at the ladies, yelling out "Hi hi." - RenegadeXR
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
09-23-2015, 09:09 AM | #10 |
Any updates guesses on tire life? Driving normal and not burning up the tracks leavings mustangs in the dust. Haha
09-23-2015, 09:17 AM | #11 | |
09-23-2015, 01:33 PM | #12 |
Drives: 2016 2SS Convertible Join Date: May 2012
I haven't been able to find any data on the new Goodyear tires for the Camaro, but I found a few internet discussions about other performance tire warranties. I found a few discussions where the tire company Rep said they only stand behind the treadlife warranty if you have a square tire setup and do a 4-wheel rotation as recommended. As we all know the Camaro has a staggered tire size so we can't do the normal 4-wheel rotation. I guess we will have to get the magnifying glasses out and read the fine print to see what Goodyear and the dealers will actually do for us under warranty. I guess we will also have to read the fine print to see if there are any temperature limits on the Goodyear warranty like there were with the P-Zero tires.
09-24-2015, 05:16 AM | #13 |
GM repeat offender...
Drives: 16 2SS Join Date: Dec 2014
I am of the belief that if you have a tire with a 45K mile warranty on a car like this, and you actually GET 45K miles out of them....then you bought way to aggressive a car for your driving style. These cars are meant to DRIVE. When doing so, 30k miles is great. I dont ever look at treadlife warranties on Z+ rated tires or mud tires. I look at traction and handling attributes.
'16 2SS, Summit White. A8. MRC. NPP.
Ordered:09/03/15. Received 12/22/15 INCOMING: ‘22 ZL1, Satin Steel. A10. PDR. Ordered: 03/02/22. |
02-16-2016, 03:47 PM | #14 |
Drives: going to buy 2016 camaro v6 2lt Join Date: Jan 2016
Hello can you 1lt rs vs with regualer tires instead of run flat
