Caryle Racing
Old 09-12-2009, 11:09 PM   #1
ls7camaro
Drives: 2010 camaro
T-56 tranny
My 2010 camaro is going to be about 700whp once im done with it, and recently i saw a 736whp mustang with a t6060 in it. I was just wondering how long you think the t6060 will be able to hold all that power or could a viper spec t-56 or t-56 magnum work better and also fit in the camaro?
ls7camaro is offline   Reply With Quote
Old 09-12-2009, 11:16 PM   #2
zebra
just can't seem to leave
zebra's Avatar
Drives: your mom wild!!
i'd say if you're going for that kind of power, get a zr1 spec tr6060 or get a richmond
Old 09-12-2009, 11:32 PM   #3
ls7camaro
Drives: 2010 camaro
where the hell do i get that
Old 09-13-2009, 07:38 AM   #4
duder4thgen
Drives: Bird
t6060 > t56.
You might need to have the 6060 built to handle the power, but it is stronger than a t56. Might want to do some research and see how these things work before you go throwing money at it...
duder4thgen is offline   Reply With Quote
Old 09-13-2009, 08:45 AM   #5
Robin Lawrence
Robin Lawrence's Avatar
Drives: 2010 Camaro 69 Nova
The 6060 has larger gears and more torque capacity.
It is what they are installing in the higher horspower cars.
ZR1
Shelby GT 500
LS3 Camaro
Challanger
Robin
Holley Performance Products
Robin Lawrence is offline   Reply With Quote
Old 09-13-2009, 08:54 AM   #6
BoostedX2
BoostedX2's Avatar
Drives: VR ZL1 #259/Nissan 370Z NISMO
ZR1
Shelby GT 500
LS3 Camaro
Challanger
Robin
HI Robin, thanks for the info..
Are there any internal differences between the 6060 that come in these cars?
Thanks!
BoostedX2 is offline   Reply With Quote
Old 09-13-2009, 09:24 AM   #7
Indpowr
Drives: Corvette C6
I would go with a Viper built T56. Cheaper and proven to hold all the power you can give it.
Old 09-13-2009, 10:02 AM   #8
PsyDoc
Drives: Soon-to-be 1st Gen
The 6060 is supposed to be "better" than the T56, but right now it does not seem to be the case. Once Tremec irons out the issue(s) with the new synchros, then the benefits of the smoother shifting, higher torque rating, etc. will put it in the top spot. I still sort of hate that manufacturers seem to have to come out with something "better" when it's not really necessary. I believe you can build up a really nice T56 that will still cost a good bit less than a 6060.
PsyDoc is offline   Reply With Quote
Old 09-13-2009, 10:07 AM   #9
ls7camaro
Drives: 2010 camaro
yea the 6060's seemed to been having a lot of issues lately. So would a t-56 fit?
Old 09-13-2009, 10:17 AM   #10
Muscle Master
SS Lightning
Muscle Master's Avatar
Drives: An SRT8
Did I not say the T6060 is a piece of Junk some months ago ...
The first rule of modding something that's not American is to not try to compete with modded V8 cars that are American. Really, they can run insane power with little investment. It's not even a fair fight.
Camaro 2SS RS, IBM, White Rally Stripes, custom fuel door: Status: going to the dealer: soon
Muscle Master is offline   Reply With Quote
Old 09-13-2009, 12:01 PM   #11
PsyDoc
Sure, a T56 will fit...one way or another If you want to know whether it will be a direct bolt-in swap, then you might want to call Tremec. They might have a "beefed" up version of the TR6060 in development or available that should be a direct fit in every respect. The top photo is a T56 and the one below it is a TR6060. As you can see, the shifter location of the TR6060 looks to be a couple of inches in front of the T56 and the tranny looks like it's about 3-5" longer.
The following is out of "Hot Rod" magazine:
"T56 Magnum Tremec
www.ttcautomotive.com
Tremec's new T56 is a T56 six-speed on steroids. The Magnum ups the ante with more preicse shifts and a stronger case,gears, guts, and output shaft to increase the power handling to 700Lb-ft. Rather than forging the gears and clutching teeth all as one unit, for the Magnum, Tremec laser-welded the two together for a much more intricate design of the teeth. On top of that, the Magnum is physically narrower and equipped with wider gears as well as some extra meat to the front and rear of the main case. The T56 magnum will be available in configurations for 4.6 and 5.0 Fords, LS-series engines, and small block Chevys, but custom bellhousings for other applications will be available through most distributors.
Price: $3,000.00"
Old 09-13-2009, 03:32 PM   #12
ls7camaro
Drives: 2010 camaro
thats what i was thinking of getting too, the t-56 magnum
Old 09-13-2009, 04:42 PM   #13
UsedTaHaveA68
UsedTaHaveA68's Avatar
Drives: Hyundai Sonata
T-56 magnum = TR-6060
UsedTaHaveA68 is offline   Reply With Quote
Old 09-13-2009, 05:59 PM   #14
ls7camaro
Drives: 2010 camaro
so how long do you guys think the tr6060 will hold about 700whp
UNOFFICIAL CAUSE OF TRANNY OUT PUT SHAFT ISSUE orangeinfernoman Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 38 04-25-2011 09:25 PM
Got my allocation, but now the SS manual tranny is on constraint, WHAT TO DO??? SS Man Camaro Price | Ordering | Tracking | Dealers Discussions 23 07-29-2009 10:00 PM
Tranny problems Looking Good in Red 4th Generation Camaros 12 04-26-2009 10:28 AM
Challys 6-Speed Tranny only capable of 450 ft. lbs torque, what about the Camaro? Muscle Master General Automotive + Other Cars Discussion 9 10-18-2008 02:28 AM
Camaro V6 tranny 2001ragtop 5th Gen Camaro SS LS LT General Discussions 14 02-03-2008 04:21 AM
