| Camaro Issues / Problems | Warranty Discussions | TSB and Recalls Report, discuss and diagnose any issues and problems with your Camaro, including warranty discussions. |
Thread Tools |
![]() ![]() Drives: IOM V6 RS 38808 Join Date: Jan 2007
HUGE problem with warped rear bumper fascia!!!
I have a HUGE problem with my rear bumper being warped!!! (Well actually it's a minor problem that's no big deal and I probably shouldn't have even noticed it.) But when I did I was very shocked and thought that someone had hit me or maybe hated my mudflap so much they kicked it or tried to pull it off or something. Or maybe that putting the mudflaps on or taking the taillight rings off had caused stresses on the plastic that had caused it to warp or something. But I examined old pictures of my car from when I got it a few weeks ago and it has always been like this from the day I picked it up. I can't believe I never noticed it because now it's super obvious to me and I can't look at my car (or even think about it) without seeing it. I'm thinking if anyone sees it they'll think I was in a crash or that GM quality sucks, neither of which I want at all!
It's warped in two ways, mostly on the drivers side but even a little on the passenger side. The leading edge of the bumper right by the tire is warped in and out causing the wheel opening to not appear smooth and round in most views and the bumper is also warped away from the fender itself for 6 or 8 inches behind the wheel flare. Is anyone else's car like this? Does anyone else know why mine is? I don't know if I should try to forget about it, or take it back to the dealer and see if they can un-warp it or if I can un-warp it or if I should have them order me a new bumper or what? ![]() ![]() ![]()
I've known how to spell Camaro since before you were born. |
Would rather be riding
Drives: 2012 SS LS3 Join Date: Jul 2009
New bumper needed, the car is new so a repaired bumper would never do.
See dealer. |
Thank You GM
Drives: Sky Redline & Camaro 2SS/RS Join Date: Mar 2009
I wonder if it is just the way it is mounted. The simple act of taking it off and remounting it may be fine. Maybe the bumper is torqued a bit where it mounts and needs to be relaxed.
ITS HERE! : 2010 Camaro 2SS / 6 Speed Manual (No other way) / Silver Ice Metallic / Inferno Orange Interior Accent / RS Package / Polished Wheels / SOLO MACH X CAT BACK
"El Dictator"
Drives: 08 HHR SS, 2010 Camaro SS/RS #16429 Join Date: Sep 2006
I think you hit something. But didn't feel it.
But I looked at the pictures I took of it a half hour after I picked it up and it was that way even then. Of course the dealer or the transport company might have hit it with something. (whoever has the VIN after mine should check and see if your front bumper is warped)
#6 |
![]() Drives: Custom CGM/Pearl White 2010 Camaro Join Date: Sep 2009
Sorry to hear about the warped bumper. If it was mine, I would visit with the dealer and ask them to find and fix the problem. Seems almost like it is pulled up too tight and that dismounting and remounting might allow it to sit the way it was designed. And if not, then it may just be a "bad" bumper fascia and need replacing. Either way, your new car wasn't designed to look like that and shouldn't. No factory is perfect 100% of the time, and this is why you have a warranty.
CGM w/ Pearl White and Kandy Kopper FlexPaint wrap, matching bow ties and brake covers, amber halos & fogs" Awesome image by: Hazman |
#7 |
I think there is or was stress on the rear cover or facia (its not a bumper) maybe from a minor impact. If I were you I would return those tail lamps to stock so the dealer doesn't know you were goofing around back there.
#8 |
![]() Drives: 2012 Camaro SS Convertible Join Date: Jun 2009
I first noticed this a few weeks ago on mine, and have looked at every Camaro around here (~10) and they all have the same "oddity". The driver-side is worse than the passenger-side. So, it's not just you.
#9 |
1LT Victory Red V6 Manual
Drives: 2010 1LT 6 speed manual #117 Join Date: Apr 2009
Rear Bumber Bulge Fix
Hey, I had the same thing on my car. The problem is that it was not assembled correct. Jack up the car, remove the wheel, then remove the three screws and one bolt in the wheel well. Pull the bumper away from the wheel well far enough to see the tabs. One or two of the tabs are not seated properly, they need to be bent back forward to line up, and then the bumper just pops right into place. I had to fix both sides, left side had one tab bent, the right had two.
1st Car-77 Type LT Rally Sport, Manual 3 speed, Inline 6, 3rd-94 Red & Black Z28, 6 Speed Manual V8 4th-2010 1LT, Manual V6, Injen CAI, RX Catch Can, Flowmaster American Thunder & Magnaflow Resonated "X" |
#10 | |
High on "The Camaro Life"
Drives: 2010 2SS, IOM, LS3, Vortech, LG cam Join Date: May 2009
I had the same problem and the above is 100% correct, that is how I fixed mine also.
"The democracy will cease to exist when you take away from those who are willing to work and give to those who are not."-Thomas Jefferson------Going Strong at 39,250 miles
#11 | |
While I had it apart I took some pictures in hopes that I could help someone else. These pictures were all taken from above looking straight down at the two tabs that are supposed to go into the two slots but were kindof behind them instead forcing the side of the bumper outboard. The top one looks like it got a little nicked by being in the wrong position. ![]() ![]()
#12 | |
Thank You GM
#13 |
كمارو صفرا ^_^
Drives: '10 Camaro LS - M6 Join Date: Mar 2010
Thank you all for the great instructions!!
#14 |
ah well hope its fine now!
#15 |
![]() Drives: 45th Anniversary Convertible 2SS/RS Join Date: Jan 2010
Printed the fix out for my Chevy Dealer they were able to get it back to 95 % original delivery condition. I still have a slight bulge on left rear fender... was told that plastic flexes so there is really nothing they can do abuot it. Also... was in and out of body shop 5 times for this. On two of the occasions they f'ed up my pain where the metal and plastic meet so that had to be repaired as well... f'ing nightmare
#16 |
this is on my passanger side i guess ill be looking into this thanks for the info
#17 |
Born: August 27, 2009
Drives: 10CAMARO SS,12CRUZE RS,07 YAM R6 Join Date: Aug 2009
mine is bad on driver side... right where the bumper meets the quarter panel...it bulges in a bit
Victory Red 2SS/RS
Vin# A9130145 |
#18 |
![]() Drives: 2010 Black on Black Join Date: Oct 2010
Thanks for this thread! My rear bumper/quarter alignment has been buggin' me since I got the car a couple weeks ago.
#19 |
Thank god I found this thread!
I was pulling my hair out trying to reinstall the rear fascia (installing GFX), and I had no idea where those tabs supposed to go. I didn't take the wheels off neither, just jacked the car up to give myself some clearance to work on, pulled the tabs forward and voila, everything fell into place! |
#20 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Chevrolet Camaro SS 6M Join Date: Nov 2010
Both sides on mine have a warp about them and the pointy bumper cover top ends exceed the fender. I'll have to try the same technique. Thanks.
#21 |
SoCal C5 Family Member
Drives: 2010 Camaro SS/RS - Black w/IOM; 6M Join Date: Jul 2009
Great writeup for the fix! My two sides are also out a bit and I guess I can attack this when I pull the rear bumper off for the AAC Backup light install...
2010 Black 2SS/RS; 6M; IOM, GFX, sunroof; ADM Race CAI; Zoomers CB; Viper Alarm; Pdaft F&R sways, Adj Endlinks, Rtrailing arms, Camber kit, strut brace, Front Trailing Arm Bushing; SLP Skip-Shift Elim; Tinted lights/windows; Hurst Short-throw; LoJack; Door & Dash ABL Mods; Subthump; JBA Shorty headers; AACStyle LEDs; Stillen DS rotors, Hawk Ceramic pads; Havoc Blk Chrome wheels: 20x9s; Lingenfelter Blk Al Pedals; RevXtreme Catch Can; Goodridge SS lines; Ported TB; RK Sport hood; Hotchkis chassis brace; KW V3 coilovers; |
#22 |
Two Miles An Hour
Drives: SIM 2LT RS Join Date: May 2010
thanks for the thread, i noticed this a while ago on mine also. Went and checked a bunch of camaros at my dealer and they all had the same issue so i figured it would be hell trying to get them to fix it.
expect nothing, but take everything |
#23 |
![]() Drives: 2LT RS Summit White Camaro Join Date: Jan 2011
Mine is like this also! Thanks for the fix. Should the dealer be able to do this for me? I have no way to jack it up
#24 |
Drives: 2011 Camaro SS Summit White Join Date: Apr 2010
Awesome
#25 |
MOVE!
Drives: 2011 Camaro Join Date: Nov 2010
+1
| Thread Tools | |
| Zeta (Camaro/Commodore/G8) suspension details | Gatecrasher | Wheels and Tires Talk Sponsored by The Tire Rack | 66 | 04-16-2009 01:11 PM |
| Corvette C6 GTR | TFord | General Automotive + Other Cars Discussion | 3 | 08-06-2008 09:26 PM |
| G35 rear bumper stinks | The_Blur | General Automotive + Other Cars Discussion | 2 | 08-03-2008 09:15 PM |
| Camaro tail pipe rear bumper | 2001ragtop | 5th Gen Camaro SS LS LT General Discussions | 17 | 12-27-2007 03:16 PM |
| Independent Rear Suspension a Problem? | Warghost | Wheels and Tires Talk Sponsored by The Tire Rack | 34 | 06-06-2007 03:02 AM |
