Old 09-13-2009, 12:43 PM   #1
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
My Pedders Xa coilovers
On my car i put on Pedders xa coilovers it was a Easy job for me i did it in my garage, This is the install papers from Pedders.
Old 09-13-2009, 12:43 PM   #2
2SSRS@Gen5diy
The first thing you need to do is buy a MM tape measure from some one like home depot, As long as it will give you up to 750 mm it will work, So to start get some painters tape and put on the front and rear of your car over the center of the 4 wheel opening , I used blue Tape as it comes off easy, Now measure from the bottom of the rim on the tire side to the fender lip and put it on the tape.
This pic is after.
The reason for measuring the 4 sides is that your car is NOT the same in the front from side to side (my car was off 5 mm from one side to the other)
So i started the work and this is pics for you.
This is the sway bar link.
This is the strut on the ground.
You need to put some anti-zeize on the treads of the struts.
Then you set you gap in between the two adjusters
You need to set your coilovers to your set up height you want, And add or remove mm for the side that is high, On my car the drivers side was 675 mm and the other side was 679 mm so it was 4 mm higher, So when i did my front i set up the driver side at 12 mm between the two adjusters and the other side at 8mm to get the ride at the same side.
Ther is more to come.
Old 09-30-2009, 08:45 AM   #3
WICKEDSS
Dan
WICKEDSS's Avatar
Drives: THE BEAST
VERT NICE!!!!....im only doing a 1.5 drop. What was the drop on yours?
WICKEDSS is offline   Reply With Quote
Old 09-30-2009, 08:54 AM   #4
2SSRS@Gen5diy
The max at 2 1/2 in the rear and 2 in the front.
Old 09-30-2009, 09:08 AM   #5
WICKEDSS
Dan
WICKEDSS's Avatar
Drives: THE BEAST
Man that sucker is low...how does it drive??
Old 09-30-2009, 09:48 AM   #6
2SSRS@Gen5diy
I like it, As it got the body roll down more the 1/2 and if you like a firm ride you will like it a lot.
Old 10-01-2009, 05:12 PM   #7
general23cmp
Drives: 2010 RS SS
Being totally ignorant of suspensions, I have a couple questions...
1. Do you have to get a realignment after this install?
2. With a common floor jack and basic mechanic tools (non-pneumatic), can this be done by the average guy?
general23cmp is offline   Reply With Quote
Old 10-01-2009, 06:08 PM   #8
2SSRS@Gen5diy
Yes you do need an alignment after this install, Yes if you look at the pics i did it on my ASS on the floor in my garage with hand tools and it was easy.
Old 10-03-2009, 09:16 AM   #9
WICKEDSS
Dan
WICKEDSS's Avatar
Drives: THE BEAST
That why i love working at a dealership i can use the lifts when even i need...But the car looks great that low
Old 10-03-2009, 10:23 AM   #10
2SSRS@Gen5diy
And it drives great too, If you can do it you will be happy as it makes the car handle better.
Old 11-17-2009, 09:13 AM   #11
xtreme industries
Drives: 2010 Camaro 2lt RS
is there a reason for the difference in height on the suspension? why would you not make it equal on both sides? is it to compensate for driver weight?
xtreme industries is offline   Reply With Quote
Old 11-17-2009, 09:18 AM   #12
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Originally Posted by 2SSRS View Post
Could you do me a HUGE favor and measure the diameter of the widest point at the top of the coil? i.e. It should be around 3" compared to the factory 5" coil diameter at the top.
Thanks a bunch !!
Old 11-17-2009, 09:30 AM   #13
2SSRS@Gen5diy
It's the car, It is not 100% the same and that is why you need it on a flat floor and then do what i did to set up the car at the same ride height, Hoop that helps.
Thanks a bunch !!
Are you asking ME and if so do you need the front or the rear or the 2 let me know and i will do it for you.
Old 11-17-2009, 09:48 PM   #14
JusticePete
VIR Specialist
JusticePete's Avatar
Drives: Camaro Justice
Thank you for placing your trust in Pedders for your Camaro. We appreciate your business. Welcome to the PEDDERS NATION!
Pedders coilovers request? Cruz-lo Wheels and Tires Talk Sponsored by The Tire Rack 5 09-07-2009 09:24 PM
Pedders December Dollar Days for the 2010 Camaro and Brand X Vehicles JusticePete Wheels and Tires Talk Sponsored by The Tire Rack 85 07-26-2009 05:20 PM
Pedderizing the Nickey Camaro! Pedders coilovers / suspension fitted & tested. DallasMike Wheels and Tires Talk Sponsored by The Tire Rack 57 06-15-2009 04:36 PM
Free Pedders Xa coilovers for someone willing to provide test car JusticePete Wheels and Tires Talk Sponsored by The Tire Rack 64 06-09-2009 04:39 PM
SEMA, Pedders Conference, GS Camaro, New Products JusticePete Wheels and Tires Talk Sponsored by The Tire Rack 25 12-01-2008 01:25 PM
