Old 09-13-2009, 02:35 PM   #1
jamesc1123
jamesc1123's Avatar
Drives: CGM 2SS RS w/ white stripes
Differential
So I swapped out the diffferential fluid and both of the bolts had some strange (to me at least) gunk on them. I didn't know what it was for, so I left it on there. Does anyone know what this is for? Should I have gotten rid of it? Also, when I added the LSD additive and refilled the rear differential fluid, it started dripping out (meaning it was full) with about 2 oz left in the bottle. If I had raised the rear end, would it have made much of a difference for accepting more fluid? Should I delve deeper into why it didn't accept a full 32 oz plus 2.5 oz of LSD additive?
jamesc1123 is offline   Reply With Quote
Old 09-13-2009, 08:40 PM   #2
HeavyChevss
Drives: 71 Heavy Chevy SS454
Just a question- why are you changing the differential fluid already?
What kind of gunk was on the bolts, what is metal or debris from the differential or some type of anti-sieze?
HeavyChevss is offline   Reply With Quote
Old 09-13-2009, 10:16 PM   #3
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
i changed mine already,, the fluid looked real bad, came out like water and silver in color
Old 09-14-2009, 04:09 PM   #4
HP junky
ADDICTED TO HORSEPOWER!!!
HP junky's Avatar
Drives: 2004 2500HD twin turbo duramax
new gears are going to have some break in metal shavings on the magnet if it has one on the drain plug bolt.
Chris
2010 Black/Black 2SS/RS M6, Sunroof, Painted GFX, Borla S-Type Cat Back, Barton Black Pistolgrip Shift Handle, Black Lloyds SS mats, Elite Engineering Catch Can
HP junky is offline   Reply With Quote
Old 09-14-2009, 04:17 PM   #5
jamesc1123
jamesc1123's Avatar
The reason behind changing it out was because I plan on taking it to the strip, and maybe some road courses. The manual recommends changing out the fluid if you plan on doing that. I didn't think it was anti-seize because it was on the tip, not the sides (though maybe it's extra for the next time you change it?). I'm wondering if it was some sort of goop to collect up all the little metal shavings. Now I'm thinking I should have cleaned it all off...
Old 09-14-2009, 04:37 PM   #6
camaro1
camaro1's Avatar
it was metal, the drain and fill plug both have magnets in the ends of them
Limited slip differential td2222 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 13 05-09-2014 01:44 AM
LSD (Limited Slip Differential) cutter5002 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 53 08-20-2010 10:42 PM
More torque for V6 auto-change rear differential? bucky1399 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 08-24-2009 11:15 AM
Limited slip differential? LosXC451 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 15 04-29-2009 05:05 PM
Differential Question TheMadHatter99 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 32 02-19-2009 09:16 PM
