Old 09-16-2009, 03:37 PM   #1
general23cmp
Drives: 2010 RS SS
competition mode in automatic
I am still waiting on my Camaro to come in. It will be an L99 auto. Will it have competition mode, and if so, what would it actually do? I know what it does for a manual.
general23cmp is offline   Reply With Quote
Old 09-21-2009, 11:24 PM   #2
general23cmp
Drives: 2010 RS SS
anyone?
Old 09-22-2009, 01:02 AM   #3
AntiVnm
AntiVnm's Avatar
Drives: '10 IBM Camaro
Originally Posted by general23cmp View Post
anyone?
yes it should have competetive mode...i think its just taping tc button twice. at the dragstrip it didnt prove to be any faster for me.
Dynateck 1 7/8 headers, CAI intake, Nitto DR, 3:73 Richmond gears, Vigilante 2800 stall converter, tune
AntiVnm is offline   Reply With Quote
Old 09-22-2009, 01:21 AM   #4
general23cmp
Drives: 2010 RS SS
How is that different than traction control (which it also has, right?)?
Old 09-22-2009, 01:27 AM   #5
general23cmp
Drives: 2010 RS SS
After reading through the manual (yikes), it appears this is only for manual transmissions...
Old 09-22-2009, 09:29 AM   #6
toehead93
Drives: 2014 2SS/1LE
Competition mode I believe is a part of the Stabilitrack system. To activate it you hit the TC button twice which turns off traction control and lowers the constraints set by stabilitrack by allowing the rear tires to slide out a bit more. Hold the TC button for 7-8 seconds and everything is off, ie. stabilitrack of and TC off.
The only thing the TC button will effect at the track is the launch, it is recomended to press the TC button twice at the track to turn off TC and keep the car in competition mode so the rear tires to don't break loose forcing you into the wall....which has already been done (see youtube).
http://www.camaro5.com/forums/showthread.php?t=344754
Summit White 2014 2SS 1LE
Recaros, NPP exhaust, Nav
2010 2SS A6 - sold.
toehead93 is offline   Reply With Quote
Old 09-22-2009, 09:49 AM   #7
mlee
www.CamaroFest7.com
mlee's Avatar
Drives: 2017 A10 ZL1
I think you may have gotten your TC and ST mixed up there at the end... pressing twice turns off ST leaving TC on... This is Competition Mode and will show as such in the DIC. Pressing and holding will turn both off. (Yes L99s have this mode too)
One point about competion mode is since ST (Stabilitrack) is off and if you hit a wet patch down track you could end up in the wall ... ST is there to help save that slippery situation. If you are sure the track is clean then go for comp mode... this will leave TC on so you don't spin your tires on launch
Old 02-15-2015, 10:02 AM   #8
hamilton2008
hamilton2008's Avatar
Drives: 2016 CAMARO SS/ Frankenstein
the way i do it depends on track conditions. if the track isnt prepped very well... i back in the water box and hold the button down and turn every assist off and do my burn out. then pull up to the line and put the car in competitive mode (push the button twice). if the track is hooking good the i turn every assist off and do my burn out and do my pass with no assist.....thats just me. i cut pretty good 60ft time on a stock converter and street tires.
hamilton2008 is offline   Reply With Quote
Old 03-29-2016, 04:42 PM   #9
SabotAndHeat
SabotAndHeat's Avatar
Drives: 2010 Camaro
Competition mode allows a manual to push the throttle to the floor, but prevents it from red lining. This allows the driver to concentrate on the launch timing and dumping the clutch, and not balancing the needle.
SabotAndHeat is offline   Reply With Quote
Tracking All Currently Known US VIN and Window Stickers - Order Tracking Thread UCF w00t Camaro Price | Ordering | Tracking | Dealers Discussions 4242 02-17-2014 08:57 PM
7 Second Hold For Competition Mode???? jsmith Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 47 05-09-2011 10:21 AM
65 Camaro's to choose from. tony_c Camaro Price | Ordering | Tracking | Dealers Discussions 25 08-29-2009 03:25 PM
Why aren't there any Aqua Blues yet? txcamarogirl 5th Gen Camaro SS LS LT General Discussions 40 08-20-2009 10:05 AM
Competition Mode Question CJ Offshoredude 5th Gen Camaro SS LS LT General Discussions 2 07-16-2009 07:30 PM
