JDP Motorsports
Old 09-16-2009, 09:04 PM   #1
adk46r
PROUD MARINE DAD! OORAH!!
adk46r's Avatar
Drives: 2010 IOM 2SS/RS,1967 Murina Blue RS
Question Ripshift or Hurst????
OK guys (and gals) what do you think should I go with the Ripshift
www.ripshift.com/rip_home.html or should I go with the tried and true Hurst
that Nick has offered us on the group buy? They are both the same price...actually the Ripshift is $349 and the Hurst $359. Just looking for your input! Thanks in advance.
Delivered 6/12/09 VIN#2G1FT1EW3A9112635!!!
adk46r is offline   Reply With Quote
Old 09-16-2009, 09:54 PM   #2
caverman
caverman's Avatar
Drives: '69 SS Convertible
Here is a question....looking at the RipShift install instructions it says you have to lower the trans. From what I remember the Hurst shifter didn't have to do that. Does anyone know if that is the case?
Build Journal
Old 09-16-2009, 10:24 PM   #3
adk46r
adk46r's Avatar
From what jpsuperman81 posted (again) today all you should have to do is loosen up the cross member a bit to make the install a bit easier....
Originally Posted by jpsuperman81 View Post
Let's clear up the confusion here> The shifter thats posted in this thread is HURST's Aftermarket version!. This shifter is made for those customers who bought a camaro and decided not to order the O.E> Hurst shifter with the car. They are (2) entirely different shifters!. To be clear: The hold up on the O.E> version of the Hurst shifter was not their doing, it is due largely in part to the situation at GM, plus some running changes that GM and Hurst had mutually agreed upon to "spice" up the design aspect of the shifter..nothing more!.. A decision was made by GM to move the O.E. shifter from the "accessory" division to the "line installed" division so there has been delay in getting that moved over with all the issues currently going on. The Aftermarket version (shown here) can be installed without removing the trans, only loosening the cross member a little to get better access.. The O.E> version has a complete "casting" as requested by GM and it is believed at this point the trans will need to be dropped to install that particular unit..hence the reason it is to be installed "on the line" or "at the dealer level"...so, that's the story
That was posted by subzero in the install thread
Old 09-17-2009, 02:53 AM   #4
Bentley78
Rice Cooker
Bentley78's Avatar
Drives: Avalanche Z/71, 2010 Camaro2SS
Watched the throws on the ripshift site and they seemed kinda long...
Bentley78 is offline   Reply With Quote
Old 09-17-2009, 06:38 AM   #5
RobertHarriSS
RobertHarriSS's Avatar
Drives: 2SS/RS M6
Neither.
http://www.camaro5.com/forums/showth...&highlight=mgw
RobertHarriSS is offline   Reply With Quote
Hurst T-Handle on my hurst shifter 2SSRS@Gen5diy V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 51 10-07-2009 02:40 PM
Ripshift or Hurst???? adk46r Interior Parts & Accessories 11 10-01-2009 11:17 AM
Hurst Camaro SEMA Showcar-image and details TRooper Camaro Photos | Spyshots | Video | Media Gallery 48 09-25-2009 09:39 AM
Hennessey Performance Releases Shifter Option - RIPShift! Sales@Hennessey V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 39 08-25-2009 11:52 PM
Hurst or Ripshift? bobby35ny V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 14 08-20-2009 08:07 AM
