Old 09-17-2009, 08:40 AM   #1
WICKEDSS
Dan
WICKEDSS's Avatar
Drives: THE BEAST
Question Which turbo unit to go for?
Hey guys looking to turbo my car. I can get the tubing and stuff made by a buddy of mine i just dont know what kind of turbo to go with. I dont want to much power maybe 400-450 rwhp i was looking around at some single turbo kits but it seems like it would be cheaper to build a kit. So any input would be helpfull thanks
WICKEDSS is offline   Reply With Quote
Old 09-17-2009, 08:54 AM   #2
IPS Brandon
IPS Brandon's Avatar
Drives: 2010 Camaro SS black
Send a message via AIM to IPS Brandon
If your going to turbocharge your Camaro, I think you have left you power goals a little low and or modest, sure you didnt mean 500-550
Example
With a typical LS3 car in stock from at 4000 rpms moving around 46 lbs/min or air (thats a rough calculation) then VE assuming is around 90% at that range, your really doing about 41 lbs/min you would want a turbo that will be as efficient as possible (which you will need a compressor map to plot against) at that point the turbo is producing the lowest amount of friction or heat into the engine, which means you get maximum power with the right intercooler sizing ect. From doing this so many times, I can tell you that turbo wise, I would look into for your goals around a garret gt37 or gt40, those are going to make more power then you a mentioning but will be efficient at around 6-8 psi which is what I would feel comfortable running on a stock motor.
Here is the thing that irritates me with turbo kit currently, people are just throwing parts together with not enough science or reason. So my advice is to take your time, find out how much power potential you want, at what rpm are you wanting to see full boost or peak torque, how much boost are you willing to run, and then pick a turbo. After that move to the intercooler, ect. There is a method to the madness
Good Luck and feel free to contact myself or our shop for help, we much happier when we give people the right information that allows you to design a proper system, rather then just spending dollars upon dollars on parts that dont work properly.
Regards
IPS Brandon is offline   Reply With Quote
Old 09-17-2009, 10:59 AM   #3
WICKEDSS
Dan
WICKEDSS's Avatar
Drives: THE BEAST
ok say i shoot for 500-550 what all will be needed. I dont want to have to do to much to the bottom end so i would like to run a safe boost. Im not to smart with forced induction. my last car was a 2001 formula N/A heads and cam and such. I know ill need a inercooler and wastegate and injectors. Sorry for all the ?? i just want to make sure i know enough about what im getting in to. One more thing do you know any places that will sell a kit with all the needed stuff besides the tubing
Old 09-17-2009, 06:56 PM   #4
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
www.turboaddictionparts.com
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
Performance Parts
Old 09-18-2009, 09:37 AM   #5
WICKEDSS
Dan
WICKEDSS's Avatar
Drives: THE BEAST
Ok next question!! as you know i dont know much about forced induction....now do i need to tie both manifolds in to the turbo or just run one manifold. A friend of mine was saying i should tie both in...Im going to mount the turbo where the factory air box is, if there is a problem mounting it there please let me know. Most of the kits i see are bottom mounted i just dont like the idea of the air filter being under the car
Old 09-18-2009, 12:39 PM   #6
jnewberr2ssrs
jnewberr2ssrs's Avatar
Drives: 2010 Chevrolet Camaro 2SS RS
Subscribed...
2010 Chevrolet Camaro 2SS RS 6M with sunroof. Black exterior with black leather. Current status = 6000 (produced, delivered to customer VIN 33982 )
jnewberr2ssrs is offline   Reply With Quote
Old 09-18-2009, 02:17 PM   #7
IPS Brandon
You have to tie in both to a cross over pipe to merge the air from both exhaust ports.
Old 09-18-2009, 02:29 PM   #8
WICKEDSS
Dan
WICKEDSS's Avatar
Drives: THE BEAST
Ok cool deal Brandon..Ya as soon as you get the list of what i will need just send it over to me and ill check it out....chevyman919@aol.com
2010 Nickey Super Camaro Twin Turbo edition. NicKey 5th Gen Camaro SS LS LT General Discussions 134 07-03-2010 09:29 PM
2010 ZL1 Turbo Camaro Fastlane Forced Induction - V8 14 02-25-2010 01:04 AM
Fastlane Single Turbo Kit on Sale! Fastlane Forced Induction 1 11-26-2009 10:07 PM
STS Twin Turbo Kits Coming Soon!!! tbyrne Forced Induction 18 10-19-2009 11:06 AM
ULTIMATE PERFORMANCE* TURBO Camaro SS -- 750hp Custom Single Turbo Kit (T04Z) Ultimate Performance Forced Induction - V8 496 10-11-2009 02:29 PM
