Cold Air Inductions
Old 09-17-2009, 02:37 PM   #1
mark_p
Drives: 2010 2SSRS m6
best way to run two tunes....
I need to be able to run my N/A tune and switch to my nitrous tune easily. What is the best way to do this. Does anyone make a simple tune store box that will let me switch back and forth from two custom tunes quickly.
mark_p is offline   Reply With Quote
Old 09-17-2009, 02:47 PM   #2
zebra
just can't seem to leave
zebra's Avatar
Drives: your mom wild!!
maybe tune it into the TC/SC button
many fullsize trucks use the tow/haul (in the automatics) to switch between tunes
Old 09-17-2009, 02:49 PM   #3
mark_p
yeah but i would still need something that would store the tunes.
Old 09-17-2009, 02:54 PM   #4
zebra
zebra's Avatar
i don't know exactly how it works, but the trucks only use one ECM - it has 2 tunes that switch when the 'abuse mode' button is activated/deactivated. i was thinking this principle might be able to be applied to the traction control button because it switches between 4 different settings that are all stored in the computer.
try calling any of these guys - they do this stuff all the time (with the trucks anyway). they might be able to recommend something:
justin @ black bear performance - 530 304 9934
allen @ nelson performance - 210 626 0278
jesse @ wait4me performance - 574 267 3630
Old 09-17-2009, 04:31 PM   #5
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
you can also use a simple toggle(6 terminal) switch/resister to the intake air temp sensor, when you flip the switch the iat sensor see's a set value based on your resistor ,, then in your tune program how much nitrous retard for that same temp reading
or if you need more than just a timing retard, you could get a spare ecm and swap them for track/racing,, they can be swapped in minutes
Old 09-17-2009, 04:34 PM   #6
rodimus prime
Drives: Cargo van.
I would say 2 ecms for the safest route.
rodimus prime is offline   Reply With Quote
Old 09-18-2009, 08:08 AM   #7
mark_p
No, i need to be able to shitch programs on the fly. Not have to stop and change anything out.
Undetectable Tunes - What You Should Know kelley@vectormotorsports V8 Bolt-Ons & Tunes 159 09-18-2009 03:18 PM
Who gives free (or discounted) future tunes in Southeast? Camar0wn3d Tuning / Diagnostics -- engine and transmission 5 09-09-2009 12:42 PM
June 13th Motorgen Meet/Angeles Crest Run! SeanPlunk USA - California 29 06-22-2009 01:48 PM
Motorgen LA Invasion Videos (58) and Pics Thread SeanPlunk USA - California 5 05-31-2009 02:23 AM
