12-30-2015, 07:05 PM | #15 | |
Drives: '16 C7 Z51 Join Date: May 2012
If the car feels too lazy during turn ins, I can then add a bit of negative toe up front. The recommendations mentioned above have too much toe for my taste. Once a car starts dancing in brake zones due to too much toe, I start braking early, negating all the gains that toe would allow in turn in. For someone who only does autocross, though, more toe would make sense. There is also different alignment targets for rain/wet, but let's keep that out of scope
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD) '13 Mazda MX-5 Club (Build Thread) '17 RAM 1500 Crew Cab 4x4 Night Edition '15 Nissan Rogue S AWD |
12-30-2015, 11:00 PM | #16 |
Drives: 14 1LE Join Date: Mar 2013
X25, I think your on the right track. Toe is definitely a tire killer and with the added caster I'm sure it will have good on center feel. I have a very slight amount of negative toe -0.10 a side which hasn't been too bad since it basically puts the tire at the same angle as the OEM just on the negative side of the scale, but like you I'm not too inclined to go much more extreme than that since I do see more street miles
LMS Engineering
12-31-2015, 11:15 AM | #17 |
Drives: 2013 Camaro 1LE 1SS Join Date: Aug 2012
I would think that -3 camber is overkill but X keep in mind we dont have z/28 bearings on our 1LEs, the Zs are stiffer and a different PN. That could add to your issue vs guys who own z/28s. To me camber adjustments been very simple by using a tire temp gauge like the longacre one. Check outboard, middle and inboard of tire on all 4 and write it down. This gives you the answer of how much camber you need and also if your pressures are too high or too low. I go for slightly hitter inside and then even drop to outboard. This tells you your tire is flat in corners and in straight line the inboard is hotter. If your midd of tire is hotest your pressures are way too high.
I always ran 0 toe too but always see guys run positive camber on all 4 as GM recommends and the cars drive nice. It helps with turn in and gives you better toe when suspension is compressed in corners I believe. As far as pressure, if you are close to 40 psi you are not using the tire in my opinion, you are past the best grip. On the 1LE once I am past 36psi car is all over the place.
I work for General Motors and am not an official spokes person for General Motors. My views and opinions are my own and not those of General Motors.
12-31-2015, 12:43 PM | #18 | |
Drives: 2013 ZL1 M6 Join Date: Oct 2013
This, start gathering tire temp data and you will be well on the road to your perfect set up. |
12-31-2015, 08:54 PM | #19 | |
Drives: '14 1LE Join Date: Nov 2013
12-31-2015, 10:34 PM | #20 | |
Mgizzle, by bearing, do you mean the hubs? Hubs are a wear item, and if they are different part #, I can just replace them with Z/28 hubs when they start giving up Considering the weight of these cars, though, I can't imagine having too much of a difference (deflection) between hubs. My '13 Z06 came with ZR1-spec (SKF) hubs from factory, and even though they were much more stout, I did not feel any difference between those hubs and what came with my '06 Z06 and '12 Grand Sport. Well, I'm not good at feeling subtle differences, though, so it might just be my numbness, too : )
12-31-2015, 11:35 PM | #21 |
I would start with Justice Petes specs then. I know he checks tire temperatures, so.I would trust his info as your start point.
Off to google Oregon Raceway Park. Might have to check it out. |
12-31-2015, 11:48 PM | #22 | |
Fyi, I also saw a few very good infra red sensors that easily mount to our plastic wheel liners if you want to monitor tire temps during actual driving. I saw them for 150 bucks and it read one tire. Again, if somebody really wants to go serious.
01-01-2016, 12:11 AM | #23 | ||
Himm, such a sensor array would be amazing to play with! I could slowly go around all tires during the day if they're easy to switch to the next tire. Yet another toy to play with..
01-01-2016, 09:22 AM | #24 |
I would at least try jp's set up. Looks less expensive than your destroyed tires to adjust the tow to -.25 and back if it you don't like it. Personally I think his specs look like a great starting point for track use. If nothing else you need at least -.5 more negative camber minimum to start baselining the tire temps.
01-02-2016, 10:39 AM | #25 |
I'm pretty sure the 1LE, ZL1 and Z28 all use the same hubs. There was much discussion and literature about it, specifically regarding the 1LE using the ZL1 bearings. It should be noted that the more stout variant is only about load capacity and longevity not tolerance accuracy. Anyone seeing more than a few thousands in deflection should replace them regardless of type.
LMS Engineering
01-02-2016, 10:45 AM | #26 |
Here is a list of parts and numbers to bring your car to The ultimate track car spec for the various C5 models
LMS Engineering
01-02-2016, 02:45 PM | #27 |
This is a great list; thanks for sharing!
01-02-2016, 07:44 PM | #28 | |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Z/28 and ZL1, same bearing front and rear, # 25954415, $250 each 1LE front, #23103115, $135 each 1LE rear, #23103121, $188 each SS front, #13580685, $174 each SS rear, # 13589510, $174 each
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
