HeadlightArmor
Old 09-22-2009, 04:13 PM   #43
DSworo9
Original Polish Memeber
DSworo9's Avatar
Drives: 2002 WS6 Trans Am
"Start living or start dying."
“I am a soldier, I fight where I am told, and I win where I fight.”
DSworo9 is offline   Reply With Quote
Old 09-22-2009, 05:44 PM   #44
JANNETTYRACING
PRESIDENT CALIBRATOR JRE
JANNETTYRACING's Avatar
Drives: YELLOW 2013 ZL1 AUTO
Originally Posted by Icntdrv55 View Post
TED
If you purchase a CAI,, is it worth it to get a aftermarket MAF as well? What bennefits would I see?
Aftermarket meters are not needed unless you make enough power to max out the meter should be somewhere around 800+ to max out the meter.
A change in the housing changes how the meter reads, so you could potentially take the same meter to maybe 900+ in a bigger housing.
Ted.
Technical information, Parts Sales, Professional Installation, and Custom Dyno Tuning.
Please vist our web sites for all your performance needs!
Ted Jannetty
Jannetty Racing Ent Inc.
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
tedj@jannettyracing.com
www.jannettyracing.com
www.turboaddictionparts.com
Performance Parts
Old 09-22-2009, 05:46 PM   #45
JANNETTYRACING
Originally Posted by Mike TexaSS View Post
I cant wait til you log fuel trims!
90% of the aftermarket cold air kits require programming to get the trims back in line.
This week Ive tuned a hennesey, rotofab and a ADM. And maf transfer tuning was needed.
Would you mind sharing, PM me or call 203-753-7223
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 09-22-2009, 06:45 PM   #46
ffrcobra_65
Can you please elaborate? I am not trying to be smarta$$, just want to understand this. Thanks.
Old 09-22-2009, 07:57 PM   #47
JANNETTYRACING
OK, A Mass Air meter is calibrated in its original pipe/Air box in a Lab, X mass of air produces X Hz signal, the computer program has this information stored in what we call the Maf Transfer Function or Maf Calibration table.
When ever a Mass air meter is moved to another size, Shape, bend, pipe or exposed to another style air filter, 1 of 2 things happens, X Mass of air produces either less or more of a Hz signal.
The computer inturputes this as Less or More air respectively, and fueling is almost totally reliant on this signal.
Lets say we move more air but produce less Hz signal, this would cause a lean condition that the Fuel trims would have to make up for this by adding fuel initially in the short terms then stored permanately in the Long terms.
So If you look at your Long terms you can pretty much tell by what percent the Maf Transfer function is Skewed.
Now this also affects way more than just the fuel trims, it affects what I call the load calculations, which in turn affect where on the timing table the computer will select the timing cell with a number in it.
If you have ever looked at a timing table they typically have less timing at higher loads and more timing at lower loads.
So if above example would take place the computer would not reach the actual load value and select and higher timing value leading to the knock sensors pulling more timing.
I can't begin to tell you how complex this really is but this is a very short version of what happens when you change out your air box and move the mass air meter.
More air still means more power But the computer must be calibrated to maximize the benefits.
Years ago, the calibrations were no where near as complex and accurate as they are today, and the aftermarket cashed in on this with simple bolt ons to clean up already very rich or lax timing calibrations, and it worked quite well.
The cars and computers today are much more complex and much more accurate than I have ever seen in the past.
It was common to find 20-25 hp in a tune alone, Not today we only see 5-10 available and have to work pretty hard to get it.
Hope this answers your questions.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 09-22-2009, 08:02 PM   #48
JANNETTYRACING
I should also Add,
Just because the mass air meter produces less or more of a Hz signal does not mean you are moving less or more air.
I has to do with location, turbulance, what side of the pipe the air favors, temp, etc.
If you could rotate the maf every clock position you would get different readings because of fluid dynamics.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 09-22-2009, 08:11 PM   #49
Late Model Racecraft
Late Model Racecraft's Avatar
Drives: 98 Camaro Race Car 3.96 @ 202 MPH
Exactly, I am glad someone is deciding to do this. I will make sure one ships out tomorrow.
FIRST C7 Corvette in the 9's
LMR1200HP Twin Turbo C7 Package-9.35@155mph
2 TIME OUTLAW DRAG RADIAL LSX SHOOTOUT CHAMPION 2008/2010
9.47 ZR1 Corvette
FIRST 2010 CAMARO in the 9's
HOME OF THE FASTEST LSx'S IN THE WORLD!!
713-466-9900
WWW.LATEMODELRACECRAFT.COM
Too many PMs, please call or email instead, thanks!
Late Model Racecraft is offline   Reply With Quote
Old 09-22-2009, 08:27 PM   #50
JANNETTYRACING
Originally Posted by Red SS View Post
Ted,
Let me know when you decided to do the testing. I'd love to come by and watch. If you need a car to use, I should have mine next week!! I'll be speaking with you soon.
Jamie
Thanks for Offering your car up, I may have to take you up on that, I will let you know if the other car falls through.
Ted.
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 09-22-2009, 08:29 PM   #51
JANNETTYRACING
Thank you LMR, that is 3 solid commitments, anyone else?
Revolution
ADM
LMR
Ted Jannetty
2984 East Main St.
Waterbury Ct. 06705
203-753-7223
Performance Parts
Old 09-22-2009, 09:04 PM   #52
Mod4SS
Resident Expert
Mod4SS's Avatar
Drives: Supercharged 2010 Camaro SS
Mod4SS is offline   Reply With Quote
Old 09-22-2009, 09:13 PM   #53
Jason 98 TA
Drives: Camaro
When will this test be happening? We would like to send a TSP intake for testing.
Jason 98 TA is offline   Reply With Quote
Old 09-22-2009, 10:01 PM   #54
FirstLSK
Dude, I love my car !!!!
FirstLSK's Avatar
Drives: 2010 Black 2SS/RS white rally
Revolution
ADM
LMR
Sweet. Looks like I have 3 potential suppliers of my upcoming CAI purchase then.
I am soooooo tuned in to this CAI shootout. To me, any producer of a CAI that opts out of this is pretty much admitting to being a farce.
FirstLSK is offline   Reply With Quote
Old 09-22-2009, 10:16 PM   #55
Mike TexaSS
Drives: 454 LS7 Camaro SS
Very nicely said! GM is spot on with their LS3 timing tables! The days of tuning a 02 F-body are dead. We will see which companies have done their homework as far as testing their intakes before selling them.
Waiting on the results.
Mike TexaSS is offline   Reply With Quote
Old 09-22-2009, 11:14 PM   #56
RonC
Drives: 2010 2SS - RS
Ted,
This testing is a great idea. How about posting the MAP at 6000 RPM. The stock intake on my L99 is usually 4 less than atmosphere on my logs. There could be a significant difference between them and might serve as a good airflow indicator for those that tune theirs.
Ron
RonC is offline   Reply With Quote
I want a_______ for my new Camaro (vendors please read!!!) Deeboe Cosmetics and Lighting Modification Discussions 42 07-11-2009 07:08 PM
LS3 goes 11`s Bonestock! GMRULZ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 12-08-2008 10:10 PM
