Rover City Camaro Customs
Camaro DIY & HOW-TO instructions & discussions All DIY projects & discussions
Old 09-22-2009, 06:24 PM   #1
fatvit0
Drives: 2010 camaro 2SS w/RS
bowtie replacement
does anybody know how to take off the front and rear bowtie to replace them w the defenderworx bowties
fatvit0 is offline   Reply With Quote
Old 09-22-2009, 06:27 PM   #2
MSG'
MSG''s Avatar
Drives: 2010 1SS Camaro
you can remove the front by just pulling it off, it has pressure tabs on all 4 corners of it, just be gentle with it, and pull on each corner, and it will come off, the rear one is held on with 3m tape (i believe) you can use some fishing line to cut it loose, then some bug/tar remover to take the rest of the residue off.
MSG' is offline   Reply With Quote
Old 09-24-2009, 08:31 AM   #3
MLCrisis
Drives: 82 camaro/97 f150
Here is a very detailed description of what you want to do. I followed these instructions myself and replaced bowties with polished aluminum ones. It was a very strait forward procedure but not as easy as it looks.With some persistence you will get them off.
http://www.mylrs.com/blogs/lrs/archi...mblem-kit.aspx
MLCrisis is offline   Reply With Quote
K&N Replacement Air Filter Kahdir Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 38 01-17-2012 08:52 PM
Colored rear bowtie and truck blackout Tonka Camaro Photoshops / Renderings Forum 2 07-27-2009 12:38 PM
How is the rear bowtie attached? VenomZ302 Cosmetics and Lighting Modification Discussions 4 07-10-2009 10:03 PM
18, 19, & 20" replacement tires ... dougmac Wheels and Tires Talk Sponsored by The Tire Rack 3 03-29-2009 05:27 PM
Dale Jr heritage grill & Chevy bowtie. Silver Streak Cosmetics and Lighting Modification Discussions 32 02-13-2009 01:08 PM
