Emblempros
Old 09-23-2009, 03:48 AM   #1
TC
TC's Avatar
Drives: 2010 VR 2SS-RS
ET Drags vs ET Drag radials
If I go with the 18" corvette wheels should I still get the drag radials or the regular ET's. These would be used at the track only. Wondering tho if a regular slick would hook up to hard and break something?
TC is offline   Reply With Quote
Old 09-23-2009, 05:11 AM   #2
boostedyards86
boostedyards86's Avatar
Drives: Cummins 3500
interested in seeing opinions on this. need to figure out a decent rim tire combo for the shootout.
85 Buick TType - 5.3l GT4202r 10.86 at 126
boostedyards86 is offline   Reply With Quote
Old 09-23-2009, 06:25 AM   #3
freemaSSon
Pat @ ADM PERFORMANCE
freemaSSon's Avatar
Drives: CGM SS/RS M6
I had the new 305/45 18 MT Drag Rad's on my Trailblazer SS and managed to yank A wheel with them MANY TIMES at the track.
If you plan to use the tire ONLY on the drag strip then the wrinkle wall tire may be the best bet, if you plan to do a mixture of street and strip then the Drag Rad is the winner hands down.
"old age and treachery will always overcome youth and ambition"
author unknown
"There are two types of racers: cheaters...and losers."
Smokey Yunick
freemaSSon is offline   Reply With Quote
Old 09-23-2009, 11:08 AM   #4
DTM
DTMphotography
DTM's Avatar
Drives: 10' Camaro SS
I had a 305 ET street on my MS4 Z06 and they hooked up amazingly!
2010 2SS/RS: 12.77 @ 111mph (muffler delete) - SOLD
DTM is offline   Reply With Quote
Old 09-23-2009, 01:55 PM   #5
SK360
Drives: 2005 Pontiac GTO
The ET DRAG, ET STREET and ET STREET RADIAL are 3 different tires, the DRAG is a full slick and not DOT approved, the ET Street is a DOT approved version of the ET DRAG and the ET Street radial is a normal drag radial
I run 255/50/16 ET Street Radials on my GTO and have cut 1.71 60's on them with no wheel spin.
I am going to buy them again when I need them, it is nice to be able to drive home from the track on them when I am too tired to swap them out.
SK360 is offline   Reply With Quote
Old 09-23-2009, 05:02 PM   #6
TC
TC's Avatar
I know the difference in the tires, what I was asking is if running a full slick tire with stock rear-end and suspension would cause problems if the tires were really hooking up. These will only be used at the track.
Old 09-23-2009, 05:15 PM   #7
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
One note that you probably know:
ET Street and Street Radial max out with a 17" rim. Most 17" rims do not clear the Camaro brakes. The ET Street Radial II goes up to a P345/35R18 size.
If you hook up with any of these you have a high probability of toasting your rearend. At least the half shafts. The rear is an 8.6" with a 2 pinion diff.
Old 09-23-2009, 05:33 PM   #8
TC
TC's Avatar
thanks for the info. I looked on their website and noticed 17's were as big as they went, thought maybe that was just a partial listing
Smaller rims with drag radials??? Gary B Wheels and Tires Talk Sponsored by The Tire Rack 6 07-02-2012 10:25 PM
Goodyear jumps into Drag Radials radz28 Dragstrip and Launch Techniques Discussion 4 09-30-2009 08:36 PM
Rims and Drag Radials RickyTheStorm Wheels and Tires Talk Sponsored by The Tire Rack 17 09-10-2009 08:15 PM
Drag Radials TC Wheels and Tires Talk Sponsored by The Tire Rack 12 08-11-2009 07:38 AM
