Old 09-23-2009, 09:19 PM   #1
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
Virtual VE tuning
this program is a must have for anyone with hptuners tuning a ls3/l99 ecm with its virtual ve setup, the newer gm pcm's dont have a typical VE table for fuel control, you now have a virtual ve and maf to tune fuel.
this program is from the hptuners forum, it took me a while to get it figured out, my car would not run on the factory ve settings, when i would disconnect the maf it would just die and i couldnt even hardly keep running, after about an hour with this software i can now unplug my maf and drive away with no issues, the enigne fuel trims stay real close to what they were with the maf on.
Old 09-23-2009, 10:06 PM   #2
E85LSX
E85LSX's Avatar
Drives: 2010 Camaro
Whats the advantage of running both MAF and VE. Can you feel the difference? Is the car more responsive? I'm just wondering, right now I have the MAF dialed in perfectly and the car feels great (dynamic airflow is off), I really don't believe tuning the VE table and turning them back on will result in any noticeable differences. . . but i could be wrong
Mods: TVS2300, 3.2 pulley, American Racing Headers, Custom Cam, Coil Overs, Tuned for E85, 610RWHP* 570RWTQ
Follow me on Twitter
www.e85lsx.com
E85LSX is offline   Reply With Quote
Old 09-23-2009, 10:17 PM   #3
camaro1
camaro1's Avatar
what if you are driving along and your maf fails and you dont have the ve tuned your car will probly run like crap. my setup would not run on the factory ve, but a car with just a few bolt-ons may be fine
give it a try, un plug your maf and see how it runs, log your fuel trims and see how far off they are
Old 09-24-2009, 08:11 PM   #4
E85LSX
E85LSX's Avatar
Drives: 2010 Camaro
Well since my VE is tuned out I don't think the car will run at all when I unplug the maf lol. Besides from having the backup if the MAF fails while driving I am wondering if tuning my VE will give me any benifits. I'll going to try tuning my VE just for fun but was just wondering if I should expect to see any differences. Thanks
www.e85lsx.com
Old 09-24-2009, 11:24 PM   #5
66DeuceLS1
66DeuceLS1's Avatar
Drives: 2010 2SS/RS SIM M6 Hockey Kit
E85LSX - what other mods have you done to get to 420RWHP? Also, what all was required to tune for E85? I am planning to purchase HPT to tune my car....so I am in the uphill side of the learning curve. Thx
2SS/RS SIM M6 Polished 20's, Hockey Strips,
GFX, Kooks LT's, High flow CATS, Magnaflow x-pipe, Vararam CAI
66DeuceLS1 is offline   Reply With Quote
Old 09-25-2009, 12:17 AM   #6
2Tightwads
Banned
Drives: 2002 LS1 swapped into a 1994 Z
Skip the VE tune crap and run MAF only. Eliminate the VE table imo. Yes the software works to tune the virtual VE but its still alot of extra un-needed work. LS3 sensors are terribly accurate and can handle ALOT of boost!
2Tightwads is offline   Reply With Quote
Old 09-25-2009, 11:51 PM   #7
E85LSX
E85LSX's Avatar
Drives: 2010 Camaro
I agree with you 2tightwads but as am experiment I will tune my VE and run both MAF and SD to see if it makes a difference. I will keep you guys posted as to what i find.
I will pm you so we don't hijack this thread but my current mods are in my sig, headers and tuned. I did just finish putting a cam in her though so hopefully I'm closer to 500rwhp now! After I tune it in I'll dyno again and post the results in a new thread.
www.e85lsx.com
Old 09-26-2009, 10:23 AM   #8
camaro1
camaro1's Avatar
are you using hptuners,can you post you e85 tune up, id like to look
Old 09-26-2009, 08:14 PM   #9
E85LSX
E85LSX's Avatar
Drives: 2010 Camaro
here you go, knock yourself out lol
www.e85lsx.com
Old 10-07-2009, 07:42 AM   #10
Meister@Torq
Drives: 2001 Crown Vic
Send a message via AIM to Meister@Torq Send a message via MSN to Meister@Torq
The VE tables are used for speed density calculations. Anytime you are changing the airflow requirements (beyond a cold air intake such as a blower, cam, heads, etc) using and tuning the VE table will help with transient fueling predictions (quick throttle changes). That being said you can still 100% disable the VE and run just the MAF
Meister@Torq is offline   Reply With Quote
Old 10-08-2009, 05:19 PM   #11
Bmble_B
Bmble_B's Avatar
Drives: 2SS Rally Yellow LS3/Maggie
Which tables are used for ve with this pcm?
Bmble_B is offline   Reply With Quote
Old 10-08-2009, 06:40 PM   #12
camaro1
camaro1's Avatar
use the program from my first post and it will run you through which tables to load into it to create your virtual ve table, you can then modify the table and send the data back to the hp tuner file tables
Old 10-09-2009, 12:29 PM   #13
Bmble_B
Bmble_B's Avatar
Cool, thanks for the help. I have skipped from earlier models with tunable ve tables to a 2010 camaro ss with a maggie, so I'm back in the learning curve again!
Old 10-09-2009, 12:42 PM   #14
2Tightwads
Banned
Sh!t you start tuning the MAF/new virtual VE tables and your WAY ahead of the learning curve. There are still shops out there who still rape the IFR/PE tables to get results, never even once touching the MAF/VE! Post you results okay!
Diablosport Predator *In Stock* $369 Shipped BMC Performance V8 Bolt-Ons & Tunes 36 11-16-2009 01:53 PM
Livernois Motorsports Custom Tuning Information Chris@Livernois V8 Bolt-Ons & Tunes 61 11-13-2009 09:49 PM
New flash tuner - ?old to 'Stang - new to 'Maro? radz28 Tuning / Diagnostics -- engine and transmission 0 08-26-2009 02:10 PM
