| Wheels and Tires Talk Sponsored by The Tire Rack Discuss issues related to wheels and tires |
Thread Tools |
Boost God
Drives: Black 95 Z/28 Join Date: May 2008
Tire Reviews
I didn't see anything like this on this site so i figured it could be helpful.
Rules: State the whole name of the tire Rate the overall tire in 1-5 Give a minimum of one complete sentenced for EACH pros and cons Tell whether you would buy again now i'll start it off i got a few reviews
I wanna go fast!!!
Boost God
Bridgestone Potenza RE760 Sport with UNI-T
I give this tire a 5 The tire had great dry and wet traction, and great longevity even when drifted. Really their are no cons i drifted these tires and drove them down to the belts and still didn't blow out. I would definately buy these tires again!!!
I wanna go fast!!!
Boost God
Firestone Firehawk SZ50 EP RFT with UNI-T
This tire i give a 2 This tire had great dry and wet traction, i beat the crap outta these tires and they held up as good as you could expect them to, but do you wanna know what sucks about them... their only offered in 2 sizes
I wanna go fast!!!
Boost God
Fuzion HRi
Solid 5 in it's category This tire is not a performance tire it's a daily driver tire and it's great at what it does dry wet and little bit of snow this gets me everywhere i need to go and best part i've got 71,000 miles on my set and i'm only at 5/32.. only complaint they have a pretty soft sidewall but their not performance anyways I'll keep buying these tires as long as i have a dailey driver
I wanna go fast!!!
#5 | ||||
The Jalopy Jedi
Drives: anything I can get my hands on Join Date: Sep 2006
BFGoodrich G-force T/A KDW (new tread pattern)
5 + 5 + 5 +5 Superb wet and dry traction with deep wide grooves to disperse water. Has a traction grade of AA. Has reinforced sidewalls. Ive got over 20,000 miles on mine and they hook rain or shine. These are performance street tires and are priced very well for what you get. Also they have rim protector lips built in. I will continue to use these tires only when i replace the current ones i have, i will put the KDWs on the front and the KDW drag radials for the rear.
#6 |
![]() Drives: '03 Monte Carlo SS Join Date: Mar 2008
I really like BFG, had them on most of my cars, the Monte came with GY Eagles and I only have 13k miles so no sense swapping them.
I'd really like to see a set of sticky pirellis and what kind of #s the car could post on the skidpad and slalom |
#7 |
Camaro Fanatic
Summitomo HTR Z (series)
Strong 4 for how much they cost they are great. Ive had Fuzion's BF Goodwrench, etc and they are just as good for less that 100 bucks each. I always get the ultra high performance summer(I lived in SE Georgia) , and used them on chicago roads in mid winter with no issues. in summer theres a noticable difference in handeling which is always welcome. the only con is that once they reach 50% you could end up needing a new set in a hurry if your hard on 'em. Ive bought them for the last 3 sets Ive needed. |
#8 |
Erlkoenig
Drives: 1998 Camaro SS Join Date: May 2008
Nitto 555 RII
5 pros A very sticky tire (DOT legal comp tire) cons wears fast Due to tread design , not very effective in standing water. Toyo RA1 5 pros A very sticky tire (DOT legal comp tire) cons wears fast Due to tread design , not very effective in standing water Falken Azenis RT615 4 pros A sticky tire (DOT legal comp tire) cons wears fast Due to tread design , not very effective in standing water |
#9 | |
err… MEOW!
Nitto NT555 street tires
5 Pros REALLY grabs the road, I do a lot of canyon carving and this is very important Cons I don't have any, but passengers have complained about the rough ride
2005 GTO - Phantom Black Metallic Red A4 1 of 286 ![]() Quote:
#10 | |
Bridgestone Turanza T
4.9 Pros: - Relatively decent traction in all conditions. - Insanely long tread life. Tread on the second set was still good at 80,000 miles when I sold the car, after beating on them the whole time. - Comfortable ride. Cons: - Requires higher pressure. Sloppy handling and uneven wear at the same pressure as other tires. Additional pressure makes them handle every bit as well as any other tire (for example, Toyo Proxes FZ4, which I directly compared them to). Not a problem for me, since I always run higher pressure anyway. - Not on the market anymore. I would definitely buy them again if I had the chance and had a car that I was keeping. I would even put them on my hypothetical Camaro. I'll have to look into those Fuzion HRi tires recommended by Stroker... --------------------------------------------------- Toyo Proxes FZ4 3 Pros: Decent tire. Cons: Expensive but do not stand out from other models. Dry handling was no better than the tires that came stock on my 1997 Grand Am SE V6, which may have been Goodyear Eagle RS, S, or ST (I can't remember, those Eagle models have useless names). --------------------------------------------------- BF Goodrich Long Trail T/A and Rugged Trail T/A 4 Pros: Good truck tires with decent traction, long treadlife and comfortable ride. Cons: Expensive.
Removing weight has surprisingly little effect on fuel economy
Engine break-in procedure | Gear ratios 2002 GMC Sierra 4x4 5.3 (190,000 miles and going strong) 1980 Buick Lesabre family heirloom with 36,000 miles 2008 Volkswagen Rabbit 2 door I5-2.5 5spd DD lease Quote:
#11 | |
Petro-sexual
Drives: Ultra-Grin Join Date: Oct 2006
Pros - Cheap. $100 for a 315 is a steal! No problems in the rain - Never brave enough to drive in the snow Nice ride Cons - Cheap. They don't last too long and dont' grip too well. I can spin the tires on a 3-2 downshift if I'm not careful at 45 MPH. I've had problems in the past with the tread blocks splitting laterally across the tire on a couple sets No bead protectors Overall, if I'm hurtin' for doe, these are sufficient enough to get by on. Just don't try racing on them.
"...What IS true: We anticipated that this would happen - we are never finished - and yes, Ford DOES deserve to win now and then. To think that GM can come out with a car to make ford throw in the towel is simply foolhardy..." - fbodfather
#12 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 10 SIM 2SS/RS LS3 Join Date: May 2008
So do we know what the new Camaro's tires will be? I'm hoping Pirelli P-Zero's
5th Gen Camaros of the Carolinas
SIM, 2SS/RS LS3 5/7/11 453.9 RWHP 427.5 RWTQ VMS Stage 2.5 Comp Cams kit, Cold Air Inductions intake, ADM race scoop, DT 1 3/4" headers, Solo cats, 3" Magnaflow catback, Pypes cutouts, HP tune, H&R SuperSport springs, Eibach sways/spacers, TexasSpeed UD pulley, LSR tensioner pulley, Barton shifter, skip shift eliminator, powder-coated calipers, R1 concept rotors, StopTech pads, Granatelli wires, Lloyds mats, tint, AAC afterburner taillamps, AAC scanner/sidemarkers, SRP pedals, custom engine cover, black bowties, Ridergraphix hood spears.... |
#13 |
![]() Drives: 2011 Camaro 2SS/RS Join Date: Jul 2011
NITTO NT420S
3 Pros: Good traction, great wet weather handling cons: Horrible lateral stability and poor handling during cornering. Sidewall is way to soft for a sports car like the Camaro.
Falken LC52 Wheels w/ 20x9 & 20x10.5 with Nitto 420S tires |
| Thread Tools | |
| Drivers Can't Rely on Summer and All-Season Tires, or Electronics for Control on Snow | KILLER74Z28 | General Automotive + Other Cars Discussion | 25 | 07-22-2011 10:51 AM |
| tire width | TFord | Wheels and Tires Talk Sponsored by The Tire Rack | 23 | 02-26-2009 09:16 AM |
| Spare tire | 2001ragtop | Off-topic Discussions | 9 | 02-08-2008 03:10 AM |
| Car Law- i.e. tire size, exhaust noise | Kyle.Gilmour | General Automotive + Other Cars Discussion | 11 | 08-06-2007 11:09 AM |
| Wheels/stance/ride height | Heelz2315 | Wheels and Tires Talk Sponsored by The Tire Rack | 72 | 07-22-2007 12:17 AM |
