BeckyD @ James Martin Chevy
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Other Generations > 1st & 2nd Generation Camaros
Old 09-24-2009, 08:27 AM   #1
RMGee
Clap Clap
RMGee's Avatar
Drives: 2SS/RS LS3
Off Center Shifter
My dads trying to buy a 69 Camaro and I think weve found one we like but it has something weird... an off center shifter. Ive never seen this before and I dont know if he or I would like it. What do you guys think about this and can it be changed?
edit:
also, when I see a picture of a car like this
Is thetransmission here a previous automatic and just changed into a maual?
RMGee is offline   Reply With Quote
Old 09-24-2009, 09:44 AM   #2
chevy454
chevy454's Avatar
Drives: '69 Yenko Camaro - 11.73 @ 118
Have you guys pulled the carpet back and looked at the hump? I'm wondering if it wasn't an automatic car originally, and someone just stuck the 4-speed shifter where they wanted it during the conversion? Does it have an auto or stick column?? My Camaro assumbly manual shows all of the shifter humps coming straight up...
chevy454 is offline   Reply With Quote
Old 09-24-2009, 10:21 AM   #3
Stingr69
'69 Owned Since '79
Stingr69's Avatar
It's not a '69 Camaro shifter. The '69 Camaro shifter is a unique setup and does not use "universal" shifter parts like that. It looks like it would function fine but it is probably designed to fit some other vehicle.
-Mark.
Old 09-24-2009, 04:48 PM   #4
RMGee
Clap Clap
RMGee's Avatar
Drives: 2SS/RS LS3
I emailed him and he told me this
stock shifter had a off set handle, this car has a competition plus Hurst shifter in it with a straight handle
What do you guys think?
Old 09-24-2009, 06:59 PM   #5
chevy454
chevy454's Avatar
Well, the stock shifter was offset just a tad I believe, but that had nothing to do with the location of the hole/boot/ring. Our big block Nova has the stock hump & shifter setup, maybe I can grab a picture...I'm gonna say they added a new hole/shifter to an automatic car, or just made a new hole alltogether on a 4-speed hump. The shifter came up through the same location, whether it was a standard setup or had a console, so that tells you the hole can't be offset to one side...
Also, I'm not sure what you're asking with the second picture in your original poast?
Old 09-24-2009, 07:03 PM   #6
tones2SS
tones2SS's Avatar
Thumbs up
edit:
No. What you see there is the center console option, which I prefer instead of just the shifter on the floor in your first pic. All the automatics have the center console, but in case of the manuals, it was an option. It also holds the 4 gauge cluster pack as well. Similar to the 4 gauge cluster pack in the 2010. Hope that helps.
(Although, the 4 gauge cluster pack in the pic you provided, looks modified.)
Old 09-24-2009, 07:22 PM   #7
anthonybyram
anthonybyram's Avatar
Drives: 1972 Z28, torch red,454
The shifter on this car has been changed. This could be a manual car, the fastest way to check is put it on a lift and see if the original hole has been enlarged. But the original factory shifter would not have this offset. Nice looking car by the way. Good luck!
anthonybyram is offline   Reply With Quote
Old 09-24-2009, 07:22 PM   #8
chevy454
chevy454's Avatar
That's not right...if you didn't order the D55 (console) with an automatic, then it was on the column...our Yenko started out as a column shift automatic car, then Yenko added the Hurst Dual Gate shifter on the floor, and simply knocked the pin out of the shift arm and removed it from the collar.
Old 09-25-2009, 11:33 AM   #9
tones2SS
tones2SS's Avatar
Thumbs up
I thought the only '69 Camaros that were V6 cars, had the column shift and all the V8 Camaros were on the floor with the console as far as automatics are concerned??
Very cool. Learn something new every day. Thank you!
V6 Camaro Performance Upgrades rtcat600man Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 380 11-06-2017 05:38 PM
MTI Racings new 2010 Camaro short shifter MTI Racing V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 24 08-23-2009 09:07 PM
noise from under center shifter? francone13 Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 6 07-24-2009 01:35 PM
The BEST upgrade for your new Camaro - Camaro Six Shooter shifter MTI Racing V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 19 07-23-2009 03:52 PM
Short Throw Shifter Constrained?? josh1147 Camaro Price | Ordering | Tracking | Dealers Discussions 75 02-19-2009 01:51 PM
