SDPC
Old 09-25-2009, 12:42 AM   #1
hot ss
hot ss's Avatar
Drives: aqua 2ss l99
getting a brake booster cuircut cel after maggie install.
anyone else?
hot ss is offline   Reply With Quote
Old 09-25-2009, 08:31 AM   #2
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
Nothing here ... did you do the install yourself or have a shop do it? Have you reached out to anyone else?
Crowley
Crowley is offline   Reply With Quote
Old 09-25-2009, 09:56 AM   #3
LJo
LJo's Avatar
Drives: 2008 G8
This seems to be happening alot lately. That code just needs to be turned off in the tune.
Why GM put a vacuum warning sensor in the brake booster is beyond me.
LJo is offline   Reply With Quote
Old 09-25-2009, 12:22 PM   #4
carfansince73
carfansince73's Avatar
Drives: Carefully
Is it throwing the code because it's showing boost instead of vacuum?
2010 1SS RS, LS3, SIM/Black, painted rally stripes, AAC sidemarkers, Sunroof, B.A. sound sys; 20x9.5 & 20x11 SV1-C5's; Hotchkis Track Pack; Corsa catback; Kooks 1 7/8"; ADM Street; Magnacharger TVS2300 - 548rwhp/512rwtq
1100- 2/18/09; 3800- 6/15/09 VIN#18308; Delivered 6/29/09!!!!! I wonder if the state would allow this vanity plate---> KISSMYSS
carfansince73 is offline   Reply With Quote
Old 09-27-2009, 07:32 PM   #5
hot ss
hot ss's Avatar
i wonder if a guy can coffee can it and check valve it?
Old 09-28-2009, 11:12 AM   #6
LJo
LJo's Avatar
Drives: 2008 G8
It throws the code because it sees a "lack" of vacuum, or in our case boost.
You could run a check valve, but you would need to find a large check valve that is the same size as the factory line.
Old 09-28-2009, 08:04 PM   #7
hot ss
hot ss's Avatar
ill hunt for something, but for now, i unchecked the ses code, and cleared the code.
Old 09-28-2009, 08:19 PM   #8
JTinFL
JTinFL's Avatar
Drives: Fast ones
You can find check valves in that size at any local auto parts store. That should do the trick.
JTinFL is offline   Reply With Quote
Hawk Performance Brake Pad "Updated" KILLER74Z28 Suspension / Brakes / Chassis 34 05-04-2016 12:11 PM
DBA Brake Rotors, Hawk Brake Pads, and Motul Fluids! AJ@ECSMotorsports Suspension / Chassis / Brakes 49 11-13-2010 04:57 PM
Brake upgrade 96CAMaro Wheels and Tires Talk Sponsored by The Tire Rack 28 06-03-2009 02:44 PM
'04 Silverado Brake Booster Line? Ject Off-topic Discussions 3 04-04-2009 09:18 PM
