09-25-2009, 10:11 AM | #1 |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
18" Drag Radials
Does anybody know what 18" wheel will fit around the Brembo's, so as to fit 18" drag radials on. 03 Vette does not work.
09-25-2009, 10:46 AM | #2 |
Drives: '69 SS Convertible Join Date: May 2009
From my understanding you'll need 20" to clear the brakes. I did notice that Nitto is now making a 20" Street Slick. About $200 a piece from Jegs if I remember correctly.
Build Journal |
09-25-2009, 11:13 AM | #3 |
SST...
Drives: SST Camaro 2010 Join Date: Oct 2008
The rear Brembo's require a minimum of a 16" circumference. That would be with zero clearance. Basically, you need a rim that has no less that a 16.5" inner circumference...
09-25-2009, 11:54 AM | #4 |
Drives: 2010 Camaro 69 Nova Join Date: Oct 2008
I used a 2006 Z06 18" Front wheel.
It clears without spacers Robin
Holley Performance Products
09-25-2009, 12:33 PM | #5 |
Drives: Firebird Formula Join Date: Oct 2007
I thought the bolt patterns were different with corvettes and the new camaro.
Similar Threads | ||||
Goodyear jumps into Drag Radials | radz28 | Dragstrip and Launch Techniques Discussion | 4 | 09-30-2009 08:36 PM |
ET Drags vs ET Drag radials | TC | Dragstrip and Launch Techniques Discussion | 7 | 09-23-2009 05:33 PM |
Rims and Drag Radials | RickyTheStorm | Wheels and Tires Talk Sponsored by The Tire Rack | 17 | 09-10-2009 08:15 PM |
Drag Radials | TC | Wheels and Tires Talk Sponsored by The Tire Rack | 12 | 08-11-2009 07:38 AM |
