Emblempros
Old 09-26-2009, 08:42 AM   #1
Proroc
Proroc's Avatar
Drives: 2013 Red ZL1 Coupe
Lowering spring installation
I am goinng to install a set of lowering springs. In the past on a Impala and Mustang with the strut suspension I had to either open up the holes on the struts to make it adjust enought for the camber or use the off set bolts.
Does anyone know if it is the same for the Camaro on either the front or rear when you lower it?
Thanks
Jeff
Proroc is offline   Reply With Quote
Old 09-26-2009, 07:02 PM   #2
Proroc
Proroc's Avatar
anybody?
Old 09-27-2009, 06:41 PM   #3
mcoyote71
INSTG8R
mcoyote71's Avatar
Drives: 2010 Red Jewell Camaro RS/SS
no slotting required
The suspension is fully adjustable without having to pull out your air chisel.
I just installed the eibach pro kit springs and had aligned. Everything is adjustable by eccentric bolts.
mcoyote71 is offline   Reply With Quote
Eibach ProKit Lowering Springs in Stock | FREE S&H! AJ@ECSMotorsports Suspension / Chassis / Brakes 139 11-17-2010 03:23 PM
H&R Sport Lowering Springs IN STOCK NOW!! AJ@ECSMotorsports Suspension / Chassis / Brakes 25 10-13-2010 11:35 AM
Eibach Lowering Springs and Sway Bars Now Shipping @ BMC Performance Kris@BMCPerformance Suspension / Chassis / Brakes 6 11-14-2009 09:34 PM
Eibach V8 Lowering Spring Release NickB Suspension / Chassis / Brakes 0 08-14-2009 11:38 AM
Discussion of suspension tuning methodologies Tankrust Wheels and Tires Talk Sponsored by The Tire Rack 10 08-04-2009 07:39 PM
