HeadlightArmor
Old 09-26-2009, 12:21 PM   #1
joepitt
joepitt's Avatar
Drives: 2016 2SS Camaro, 2010 Enclave
Question Storing for Winter questions
I'll be garaging my Camaro for the winter, November-March. I've never done that before. Is there anything special I should do. I'm planning on cover for use in the garage.
2016 2SS, Auto, Garnet Red, Black Interior, Magnetic Ride, Performance Exhaust, and Nav.
Past highlights: 2013 2LT/RS, 2010 pre-order Camaro 2LT,1969 Chevy Malibu, 1972 Plymouth 'Cuda, 1972 Pontiac GTO, 1979 Turbo Buick Century.
'See the USA in your Chevrolet...'
Dinah Shore, 1952: http://www.youtube.com/watch?v=KGZvQoPxhNs
joepitt is offline   Reply With Quote
Old 09-26-2009, 01:27 PM   #2
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
If you're going to use a car cover and it's going to be inside the garage don't waste your money on a "weather proof" cover. The ones for inside use are much cheaper.
I'd disconnect the battery, put it on jack stands. There are also some big bags of Silica gel that you can put in side to keep the moisture down to a minimum.
I'd top it off with gas and also change the oil before you park her.
Old 09-26-2009, 01:37 PM   #3
DEW
Drives: Hoopdee
I will be doing the same thing. Ordered the Trigard cover from coverking http://www.southerncarparts.com/cove...ers-c-112.html Im just going to park it with a full tank and start it once a month,
2LT - CYBER GRAY METALLIC - BLACK RALLY STRIPES - MANUAL TRANNY - POLISHED 19" WHEELS
BUILD - 6/12/2009
Airaid V2, Flowmaster AT
DEW is offline   Reply With Quote
Old 09-26-2009, 01:40 PM   #4
RedJewelrsss32
RedJewelrsss32's Avatar
Drives: 2010 2SS/RS Red Jewel Camaro
I would use a fuel stabilizer. I plan on starting mine once a month as the battery will get drained on while setting.
WHAT IS CAMARO? A small viscious animal that EATS mustangs!!! Delivered 9/17/09
RedJewelrsss32 is offline   Reply With Quote
Old 09-26-2009, 02:01 PM   #5
67 Convertible
67 Convertible's Avatar
Drives: 67 Camaro Convertible
You'd be better off using a battery tender than starting it once a month. Starting it will do more harm than good, unless you get it up to operating temperature and actually drive it around for a while. There is no reason to start it until you're ready to drive it in the spring.
2LT/RS RJT, Blk Rally Stripes, Beige Interior, Sunroof
Placed order at dealer 4/24/09
1100 - 4/28/09
2000 - 5/01/09
2500 - 5/05/09
3000 - 5/05/09
3300 - 5/30/09
3400 - 6/05/09
3800 - 6/18/09
4000 - 6/18/09
4B00 - 6/18/09
4200 - 6/22/09
5000 - 7/01/09
6000 - 7/01/09 It's Home!!
0000 - 7/14/11 Traded in with 24,000 miles. Currently 5th Gen less
67 Convertible is offline   Reply With Quote
Old 09-26-2009, 02:15 PM   #6
DEW
Drives: Hoopdee
Yes, your probably right. I do have a battery tender.
BUILD - 6/12/2009
Old 09-26-2009, 02:43 PM   #7
Merc
In The Circle
Merc's Avatar
I assume your topping up tank to pervent rust on the inside of tank. However even if you put gas stabilizer in, your tank full of high test will be toast after a few months. Besides it looks like the Maro tank is plated .
Old 09-26-2009, 03:59 PM   #8
oachalon
Drives: 2010 Camaro 1SS
the camaro gas tank is plastic, so its not going to rust.
oachalon is offline   Reply With Quote
Old 09-26-2009, 04:15 PM   #9
Merc
In The Circle
Merc's Avatar
K That must have been a belly pan or something. Was to busy trying to fit 18" drag radials on for Street Legals. Yeah storing for several months with a full tank is not necessary in my opinion. Mine will be heading for storage in November as well.
Old 09-29-2009, 01:40 PM   #10
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
The '06 GTO I traded for the Camaro I stored in the garage every winter from Nov.-Apr. Washed, filled the tank, added fuel stabilizer, put on battery tender (Battery Sentinel Plus), covered with cheap indoor car cover. Cranked up every spring. Never had a an issue. Plan to do the Camaro the same way, except I might change the oil (only 730 miles so far in 2 months since delivery). One word of advice. Lower the rear seats in case of battery death, you can crawl through to pop the trunk.
Old 09-29-2009, 02:04 PM   #11
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
Great tip!!
V6 Questions I'd Like Answered The_Blur Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 36 07-14-2012 11:44 AM
Detailing questions answered here! Moose Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 636 06-04-2011 01:27 PM
ordering questions...how long, when should i order... etc haleyd Camaro Price | Ordering | Tracking | Dealers Discussions 10 07-25-2009 02:47 PM
so many questions about the new camaro... haleyd Camaro Price | Ordering | Tracking | Dealers Discussions 14 07-22-2009 03:23 PM
A lot of stupid questions or posts on this site. ss1129 Off-topic Discussions 49 06-12-2009 12:29 AM
