Old 09-26-2009, 01:06 PM   #1
Brendon
Drives: 2010 Chevrolet Camaro 1LT
1SS V-6 OIL PLUG LOCATION ?
Sorry for the novice question but which one is the oil plug under the 1SS Camaro. Is it the one facing the ground or the one facing horizontally. The one facing the ground is about 15 cm back of the one facing horizontally. The one facing horizontally is the one located right beneath the oil filter. Also what size socket is used on the oil filter housing. I'm assuming the socket plus an extension since the cover is the way. Any help would be appreciated.
Brendon is offline   Reply With Quote
Old 09-26-2009, 01:59 PM   #2
DEW
Drives: Hoopdee
The V6 motor has a 15mm drain plug that faces the passenger wheel. I used a 15/16 - 6 point socket for the filter cartridge housing. Im assuming you mean LS
2LT - CYBER GRAY METALLIC - BLACK RALLY STRIPES - MANUAL TRANNY - POLISHED 19" WHEELS
BUILD - 6/12/2009
Airaid V2, Flowmaster AT
DEW is offline   Reply With Quote
Old 09-26-2009, 04:18 PM   #3
patriotpa
Drives: 02 Silverado, 09 Vue, 10 1SS
Location: Tired of apologizing when we should be kickin' butt!
1SS is V8
patriotpa is offline   Reply With Quote
Old 09-26-2009, 04:20 PM   #4
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
1SS V6.....
Old 09-26-2009, 05:16 PM   #5
Merc
In The Circle
Merc's Avatar
Somebody is confussed!
Old 09-26-2009, 06:39 PM   #6
5thGenCamaroChick
Hey y'all :)
5thGenCamaroChick's Avatar
Drives: Rosalee
DO NOT... I REPEAT DO NOT REMOVE THE PLUG FACING THE GROUND!!!!!!
It's imperative that you don't so that... that's the transmission fluid. I did it and had to have my car taken by rollback to have the tranny fluid put back in. It's a sealed transmission and the fluid has to be added from underneath while it's sitting on level ground. Impossible to do.
Check out this link for my adventure. http://www.camaro5.com/forums/showthread.php?t=44081
"Are you picking up what I'm laying down? Can you dig what I'm growing?"
5thGenCamaroChick is offline   Reply With Quote
Old 09-26-2009, 06:44 PM   #7
Brendon
I'm sorry, I meant ILT, must have been instinct to write SS. OK, Dew, I took the bolt facing the front passenger wheel. I just did it about 2 hours ago, you know what, be careful because the oil gushes a couple feet and than creeps back to the where the bolt is located. I had it on a hydarulic lift so next time i am going to use two oil pans. I used a crescent wrench for the filter housing but i stripped just a tad bit, it'll still fit a socket. So did you use an extension with that socket? If you did, did it come in contact with the engine cover?
Old 09-26-2009, 06:50 PM   #8
5thGenCamaroChick
Hey y'all :)
Drives: Rosalee
Whew, had me worried there for a sec. Seriously, that was a real PITA lol. You could replace the tranny fluid on a lift, I was on ramps.
Old 01-26-2010, 10:33 PM   #9
scrapn4me
scrapn4me's Avatar
Drives: 2004 Monte Carlo SS
does any one have a picture of the plug location?
2LT-Summit White, Automatic, sunroof, black rally stripes
1100, Preliminary order accepted - 11/09/09
2500, Order accepted by GM 11/25/09
3000, Order scheduled for production - 1/11/2010
3300, Order broadcast 12/17/09
3400, Order broadcast - 12/23/09
Found same car on dealers lot 12-30-09 without factory stripes
stripes painted on "69" style 1-11-10
scrapn4me is offline   Reply With Quote
Old 01-27-2010, 01:23 PM   #10
canadian ss
Psycho on day pass
canadian ss's Avatar
Drives: 2010 yellow 1ss m6 -GM tech
I see disaster happening. You spent good money for your car and you want to take a chance on a $30 oil change. If you don't know the difference between the engine oil pan and trans oil pan, DON'T TOUCH IT! Let someone do it for you properly and you'll have piece of mind.
canadian ss is offline   Reply With Quote
Old 01-27-2010, 01:24 PM   #11
canadian ss
Psycho on day pass
Next question will probably be -- "Where and how much oil do I put in it?"
Old 01-27-2010, 01:31 PM   #12
canadian ss
Psycho on day pass
Not to pick on you but, do you do your own house electrical too without experience?
Old 01-27-2010, 06:39 PM   #13
scrapn4me
scrapn4me's Avatar
canadian ss Thank You so much for all your help!!!!!!!!!!!
Old 01-27-2010, 09:48 PM   #14
Kept-a-rollin
Kept-a-rollin's Avatar
Drives: 2010 Camaro 2LT RS ABM/Grey/A6/Sunr
For those of you who are novices, this link is a good thread on oil changes - worth reading through. There is a picture of the oil plug location, but it's a pic of the V8. There are some good pics of the V6 filter on page 3, post #60. I used a 15/16" socket with a 4" extension for the filter cover and had no problems.
Order No. NQRF51 2LT RS ABM/ Gray Int/ A6/ Sunroof
1100 - preliminary order accepted 10-30-09 Best Chevrolet, Hingham, MA
XXXX- abandoned order; bought same car at Durand Chevrolet 11-10-09 Woohoo!!! 2G1FC1EVXA9159071
2500 - order preferenced 11-11-09
3000 - order accepted by production control 11-18-09 TPW 12-14-09
3300 - order scheduled for production 12-9-09
3400 - order broadcast 12-15-09
3800 - order produced 12-18-09 My orig order actually did get built! 2G1FC1EVXA9179031
Kept-a-rollin is offline   Reply With Quote
housing, location, oil, plug, socket
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 09:51 AM
synthetic motor oil? bigd1276 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 71 01-29-2009 01:28 PM
The 3,000 Mile Oil Change Myth KILLER74Z28 General Automotive + Other Cars Discussion 35 07-20-2008 10:02 PM
gas prices. Congoman775 General Automotive + Other Cars Discussion 65 05-28-2008 01:20 PM
