SDTW Custom Wheels & Tires
Old 06-05-2008, 01:53 PM   #1
Stroker
Boost God
Drives: Black 95 Z/28
Cylinder heads
Now i bought trick flow heads and cam for my LS engine but has anyone here used other LS heads for their car/truck. such as SLP, Edelbrock, patriot, AFR, GMPP, or World Products?? if so what kind and how pleased were u??
I wanna go fast!!!
Stroker is offline   Reply With Quote
Old 06-05-2008, 02:03 PM   #2
Muscle Master
SS Lightning
Muscle Master's Avatar
Drives: An SRT8
I like Edelbrock, good quality and proformence, cousin use them in his Nova
The first rule of modding something that's not American is to not try to compete with modded V8 cars that are American. Really, they can run insane power with little investment. It's not even a fair fight.
Camaro 2SS RS, IBM, White Rally Stripes, custom fuel door: Status: going to the dealer: soon
Muscle Master is offline   Reply With Quote
Old 06-05-2008, 03:59 PM   #3
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Trick Flow have been proven to be not only popular, but flow really well on LSX engines. I can't speak from experience, just from research and what I've found on the internet, but I don't think you can go wrong with Trick Flows.
I know that ETP has great heads too, if you're in the market for top dollar, top performing heads. They have everything from 11* 3.9" bore heads to canted valve LSX heads, like big blocks have had. They're crazy expensive, but know of a couple people who run them, and they have some bad@$$ cars.
I've read a lot of articles about Livernois (?sp?) ported 243s and 317 heads and those things flow like mad for OEM cast heads. They flow nearly as much as Trick Flows (205s I think) and are like $1K less.
I've read some quality control concerns with Patriots a few months ago. I don't know how that's panned out though.
GMPP and World are working on their own 6-bolt style heads for +4.10" bores for their respective LSX-style blocks. I know that Z06 427 heads are CNC'd and flow great and that there are great things coming from L92/LS3 raw and factory CNC'd heads.
Edelbrock has a redesigned LS1 head from what I understand but doesn't quite match AFRs that I've read so far.
SLP use AFRs and GM heads and custom CNC them to my understanding. I'm not sure you'll find too much a difference above or below anyone else to has CNC programs for these heads.
Just keep in mind if you have a 3.90" LS1/LS6-style block, you'll be limited to smaller valves. The L92/LS3 heads are substiantially better but require at least a 4.00" bore. You can't bore a 3.90" bore block out to 4.00" without resleeving. I'd recommend, if you don't know or haven't been there before, to go to LS1Tech. There's a wealth of information there. If you can't find the answer there, there's probably something wrong.
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 06-05-2008, 07:13 PM   #4
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
port your stockers or contact Advance Induction
I piss excellence
and fart awesomeness
Old 06-06-2008, 12:08 AM   #5
o2camaross
o2camaross's Avatar
Drives: 2010 2SS/RS & 04 silvy
definetly get some advise from ls1tech.com There are many different combinations you can go with. What year is it and what kind of ls motor is it?
o2camaross is offline   Reply With Quote
Continued: Lutz mentions engine options for Camaro -- 4 cylinder turbo a possibility Tran Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 160 08-08-2008 05:16 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
5th Gen Camaro LS3 info from Chevy Hi-Po...READ TAG UR IT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 295 03-07-2008 11:06 AM
