Old 09-27-2009, 12:08 AM   #1
cobra 23
Drives: 03 cobra
z28 question?
if a new supercharged z28 is made, how much do you think it will weigh?
cobra 23 is offline   Reply With Quote
Old 09-27-2009, 12:09 AM   #2
ShnOmac
ShnOmac's Avatar
Who knows.... Its all guessing right now!
ShnOmac is offline   Reply With Quote
Old 09-27-2009, 12:16 AM   #3
cobra 23
Drives: 03 cobra
im thinking about 4200 with the supercharger, intercooler, and heat exchanger.
Old 09-27-2009, 12:20 AM   #4
ShnOmac
ShnOmac's Avatar
Who knows???? We dont know anything about it....
Old 09-27-2009, 10:51 AM   #5
clark17357
clark17357's Avatar
Drives: 2008 Shelby GT/SC
Perhaps the question could be, "What do you think it needs to weigh to deliver the performance of the past in today's world?"
If that is the question, would the target not be about 3,500 pounds?
Jim
2008 Shelby GT/SC Mustang, Vista Blue with Silver Stripes, 5-Speed, Coupe, Center gauge cluster, Kenne Bell supercharger, Front and rear brake ducts, AP Racing brakes (6-piston front, 4-piston rear), Fays2 Watts Link, Metco upper and lower control arms, BBR 3.5" aluminum drive shaft, BMR front drive shaft safety loop; Autopower four point roll bar, Autopower five point racing harnesses (both sides), and Camber/caster plates. Dyno results: 453 rear wheel torque, 447 rear wheel horse power @ 67 degrees F, 75% humidity @ sea level.
clark17357 is offline   Reply With Quote
Old 09-27-2009, 10:55 AM   #6
Super83Z
Super83Z's Avatar
Drives: 1999 Z28 1983 Z28
REcently a magazine stated that it would be 200-300 lbs lighter than the CTS-V. The CTS weighs almost 4300.
Current cars:
99 Z28
06 Silverado
14 Silverado
Super83Z is offline   Reply With Quote
Old 09-27-2009, 11:00 AM   #7
superstockcam
Member
superstockcam's Avatar
Drives: 2010 ABM 2SS/RS LS3
I'll opt out of the intercooler and heat exchanger if mine has a supercharger...
I was told the workbench for ordering will open in may 2010 by the fleet sales at the dealership I use, I'll be there for a Z28 first, vert second choice. Either way I'm getting a top of the line, loaded and hopefully under 10k VIN of every year in this generation.
________
Wendie 99
superstockcam is offline   Reply With Quote
Old 09-27-2009, 11:16 AM   #8
Number 3
Hail to the King baby!
Number 3's Avatar
Drives: '16 ATS 2.0T & '17 Buick LaCrose
Jim
Just curious, what do you think about the past would even come close to today's SS?
Todays SS makes 426 HP SAE Net. This is, and someone correct me if I'm wrong, approaching 500 HP gross as reported back in the 60s (which what I think you are saying). The IRS, the Brembo brakes, 6 speed transmissions are all things in the today's world that even a COPO couldn't touch. And that doesn't even come close the weakest link in the old cars..........tires.
This is a great discussion, it's like comparing athletes from different eras as to who is better, but the only thing I see in the older cars is a bit lower mass and that is made up for with the structure and safety hardware required in the modern era.
Seriously, I would like to hear what in old cars a modern Z28 would need to do/be.
Don't get me wrong, I LOVE the old cars. They just don't hold a candle to todays car other than the mystique that's great to talk about.
"Speed, it seems to me, provides the one genuinely modern pleasure." - Aldous Huxley Link to Every Camaro photo I've taken in Hi-Resolution
Old 09-27-2009, 11:31 AM   #9
clark17357
clark17357's Avatar
I was not clear in my post and, up front, I agree with you that the cars of the past, while special, are not the match for modern ones.
What I was addressing with the weight had to do with my sense that the original Z/28 was a great road course car and for that to be true today, we have to fight the weight monster. It is the reason I went with a Shelby GT (the one he builds at his plant in Las Vegas) rather than a GT500. Too much front end weight with the 5.4 motor.
Today's cars make more horse power in factory trim than we could have ever imagined in the 60's. The SS makes plenty I agree.
In my perfect world, there would be a Z/28 that was small block powered, supercharged, and weighed 3,250 pounds. Maybe that is my fantasy world, huh?
Jim
Old 09-27-2009, 02:28 PM   #10
Vega
Vega's Avatar
Drives: 91' Camaro RS
Send a message via Yahoo to Vega
This is actually a VERY big topic right now, i think the Camaro's biggest obstacle is the same as the Challenger's except GM has overcome it better, that would be having a 2-door car on a 4-door platform, you're just wasting weight in that scenario. As far as the engine goes expect an extra 150-200 pounds if its supercharged, another reason im not a big fan of supercharging the Z/28, id rather see a cammed LS7 putting near 600hp with less weight and a meaner roar If people want a good comparison of what the Z/28 would be like supercharged then look at the GT vs the GT500, the GT is like 3500lbs while the GT500 is around 3850lbs? Hopefully GM will see this as a problem and take measures to overcome it, im hoping for lots of parts swapped for lighter parts, lots of emphasis on weight savings in the new Z, otherwise you might as well just supercharge your SS right?
Vega is offline   Reply With Quote
Old 09-27-2009, 02:44 PM   #11
Super83Z
Super83Z's Avatar
The LS7 is done. GM isn't going to be putting it anything else.
Current cars:
99 Z28
06 Silverado
14 Silverado
Old 09-27-2009, 02:47 PM   #12
Vega
Vega's Avatar
Yeah yeah ive had to hear that everywhere i go, LOL
i still believe if the demand was good enough GM would put the effort into bringing it into a new generation for the Z/28, i just preffer it because its lighter than either the LSA or LS9, and with a simple cam swap can put out 580+ horsepower (as seen in the LS7 SEMA Camaro). Other than that im just a fan of N/A engines, haha, that parts more personal based than factual based
Old 09-27-2009, 04:42 PM   #13
cobra 23
Drives: 03 cobra
why? those things allow more boost. without an intercoler and heat exchanger 6lbs is prob max. not to mention compression will have to be lowered. then itll have less hp than a gt500. but still more weight?
Old 09-27-2009, 05:42 PM   #14
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
The CTS-V weighs about 4200 lbs. May I ask if anybody would not buy one of those (assuming you had 60 grand to spend) just because it was heavy?
Motortrend seems confident that an LSA-equipped Camaro will come in some 200-300 lbs less than that. We shall see....
Having said that...weight is 90% perception, imo. Look at some of the highest-regarded "supercars", and only a few of them would be considered feather weights, and nearly all of them will cost your first-born AND $100,000 dollars. With the right suspension, and adequate power, you can overcome the weight imposed by safety standards, and structural rigidity.
z28 question Ben Camaro ZL1 Forum - ZL1 Specific Topics 2 08-02-2009 10:01 AM
Bob Lutz interview radz28 5th Gen Camaro SS LS LT General Discussions 113 08-28-2008 02:30 PM
Gotta question bout my z28 lm1power Off-topic Discussions 1 09-15-2006 03:58 PM
