Frankenstein Engine Dynamics
Old 09-28-2009, 08:28 AM   #1
metaphysician
metaphysician's Avatar
Drives: 2SSRS CGM & Harley Crossbones
Shift knob only - what is shifter diameter?
I want to swap out the stock leather knob for a ball shift knob (don't want to spend the $$ on the shifter yet). I want to make sure I'm getting the right knob. Hurst's website has this one to fit 16mm x 1.50. Is this the correct stock shifter size?
http://www.hurst-shifters.com/hurst-...R-KNOB-6-SPEED
Thanks!
metaphysician is offline   Reply With Quote
Old 09-28-2009, 08:43 AM   #2
KILLER74Z28
MOD SQUAD
KILLER74Z28's Avatar
Drives: 2G1FT1EW9A9100666
The stock shifter is pressed on; you will need to find a pressed fit knob. Unless you remove the stock shifter and have it threaded...
Who cares about the Blue Oval crowd and their little Ponys? We're getting our Camaro back-and it'll be Supercharged!-MDAII
Team LS3
KILLER74Z28 is offline   Reply With Quote
Old 09-28-2009, 08:43 AM   #3
jpsuperman81
Yep I'm back!
jpsuperman81's Avatar
Drives: 2017 Krypton Green 1SS 1LE
The stock knob is not threaded and I'm pretty sure most hurst knobs are, so just know you will have to do some tooling to the shaft and thread it. The stock knob just pulls off it doesnt screw off.
jpsuperman81 is offline   Reply With Quote
Old 09-28-2009, 09:04 AM   #4
metaphysician
Thanks for the info and pictures! Do you know what the shifter diameter is? Maybe I'll have to find one that has those small pointed hex screws that bite into the shifter.
Super Sale on Raptor Shift Lights @ KY SPEED FRCBobby Audio / Visual / Electronics/ Gauges / Nav 44 11-25-2011 10:34 AM
shift knob - removed and redone oldfart1941 Cosmetics and Lighting Modification Discussions 17 06-21-2011 02:15 PM
shifter knob. short shift kit. oldfart1941 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 3 07-16-2009 09:40 PM
6spd shifter knob removal oldfart1941 5th Gen Camaro SS LS LT General Discussions 10 07-14-2009 11:11 AM
M6 shifter knob - anyone have issues with the design? omegaman 5th Gen Camaro SS LS LT General Discussions 24 07-08-2009 03:35 PM
