JDP Motorsports
Old 09-28-2009, 08:21 PM   #1
MARINE1991
MARINE1991's Avatar
Drives: COTW 8/29/11 2010 CAMARO
Issue with GM car cover
I just put on my new camaro GM car cover and I have the GM ground effects also. The Car cover will not fit over the front of the car on the bottom. You would think that GM would make provisions for the ground effects on the car cover. Anyone else run into this??
MARINE1991 is offline   Reply With Quote
Old 10-03-2009, 11:04 PM   #2
Tony's Jewel
Tony's Jewel's Avatar
Drives: 2SS RS Jewel
Yes, I just received my car yesterday. I put the cover on tonight and had the same problem as you described. I did get the cover to go on the car, but I am concerned about the amount of force that you have to apply to get it to go over. Then it does not go all the way over the lip on the front. Concerned the force applied is scratching the paint/clear coat. $350 cover and scared to use it.
Tony's Jewel is offline   Reply With Quote
Old 10-04-2009, 12:00 AM   #3
ThunderSS
ThunderSS's Avatar
Drives: 2010 CGM 2SS/RS
that is the exact reason I got rid of mine..to afraid it would scratch up the car..
2010 Camaro SS/RS HKE Forged 416 CID
http://www.fquick.com/ThunderZ28
510 HP/485 Ft. Lbs
ThunderSS is offline   Reply With Quote
Old 10-04-2009, 03:47 AM   #4
SleepWarz
Banned
Drives: 1991 New Yorker, 69 Tbird, ABM2SSRS
I got mine on just fine, went over the front splitter first, the over the back.
Another body helps too.
SleepWarz is offline   Reply With Quote
Old 12-04-2009, 08:03 AM   #5
amphi
Drives: 2SS Imperial Blue
Wow, I was having the same issue. I actually recommend pulling the cover over the back while you have the slack. Then pull itover the front ground effects. Reason is you won't scratch the paint if you pull it over the front. The rear buldges out a little which will be scraped by the cover.
Also, the cover will stretch a little with time, and, you don't want it to be too lose, or the wind will catch the underside and blow the cover up like a balloon, which will constantly rub your paint.
amphi is offline   Reply With Quote
Camaro Car Cover....by Tom Henry TAG UR IT Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 22 10-28-2009 10:53 PM
Tired of Waiting - Pics of My New Hyundai Genesis Coupe Inspector 17 5th Gen Camaro SS LS LT General Discussions 101 08-26-2009 09:31 PM
Please Think before you post 35th02ss Off-topic Discussions 35 08-02-2009 09:38 AM
#4768 - Delivered and Made Ready the Right Way! Number_9 5th Gen Camaro SS LS LT General Discussions 62 07-16-2009 02:42 AM
Putting on car cover alone, possible scratches. OHIOSS Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 15 07-01-2009 09:40 PM
