sjm autoprod
Old 09-29-2009, 09:19 AM   #1
traip93
Drives: Ralley Yellow, Black Sripes 2L
Oil Level on Dip Stick
My oil was changed yesterday. 6q was added (v6), but I think the level maybe a little high.
Should the level extend into the 'cross hairs' on the top of the dip stick ruler?, or should the level go to the bottom of the cross hairs? I believe my level is 1/2 up the top 'cross hairs'
My oil pressure gauge is jumping. ~30psi at idle and any acceleration over 2000 rpm the psi jumps to 70, or just over.
I took it real easy driving into work today.
I read many threads here about 70psi being 'normal' during acceleration, but my gauge never did this before the first oil change yesterday.
Chad 2Lt
traip93 is offline   Reply With Quote
Old 09-29-2009, 09:21 AM   #2
SSOOCH
Camaro SL,UTs
SSOOCH's Avatar
are you checking the oil after you've been driving it? If so then yes the oil level will go over the cross hairs. Check it when it's dead cold for reference.
Old 09-29-2009, 09:31 AM   #3
traip93
If it's into the cross hairs (after checking when dead cold) is that a problem? Should I drain a little out?
Chad 2Lt
Old 09-29-2009, 09:41 AM   #4
ahart04
most bang for your buck
ahart04's Avatar
Drives: 2010 2SS/RS CGM/BLK RALLYS
no the crosshairs stand for minimal, half, and full. as long as your level is anywhere in the crosshairs, you're good. if its full, it will show above the crosshairs.
2G1FT1EW8A9142133 Delivered to me 09/22/09!
ahart04 is offline   Reply With Quote
Old 09-29-2009, 11:15 AM   #5
traip93
From memory, the dip stick looks like the pic below. WHere should the oil level be? (engine cold), A,B,C,D or E?
Chad 2Lt
Old 09-29-2009, 02:41 PM   #6
tjd24
Thank you Oshawa/St.Cats!
tjd24's Avatar
Drives: 2010 2LT RS 2G1FC1EV4A9103434
...now that's "thinking with your dipstick"... good to post a picture!
http://www.hubgarage.com/mygarage/tjd24 http://ny5thgen.com/TJD_RS.htm
#3434 Born 4-15-2009, Delivered 5-22-2009 BBOMG 2/3/4 & booked for #5
tjd24 is offline   Reply With Quote
Old 09-29-2009, 02:47 PM   #7
traip93
Do you know the answer? A,B,C,D,E? I'm thinking "C", but a few posts earlier made it seem like it should be "A".
Chad 2Lt
Old 09-29-2009, 05:29 PM   #8
DEW
Drives: Hoopdee
The correct answer is "C"! Oh man, I hope I win a prize!
2LT - CYBER GRAY METALLIC - BLACK RALLY STRIPES - MANUAL TRANNY - POLISHED 19" WHEELS
BUILD - 6/12/2009
Airaid V2, Flowmaster AT
DEW is offline   Reply With Quote
Old 09-30-2009, 10:32 PM   #9
traip93
I agree "c", but what about this comment?
Chad 2Lt
Old 10-01-2009, 11:12 AM   #10
BigJoe
BigJoe's Avatar
Drives: 2010 Camaro 2SS/RS (10/17/2009)
Engine oil should be checked when the engine is COLD for the most accurate reading. The vehicle should be on a level or nearly level surface.
.....If the oil level is ABOVE the TOP hatches (A) it is OVERFILLED and could cause engine damage.
.....If the oil level is within the range of the TOP set of hatch marks (B), it is somewhat overfilled, but probably still safe range.
.....The correct range would be anywhere within the C-D-E range.
.....If the level is below (E) then the oil level is low, add oil to within the C-D-E range.
For a good visual reference of a hot oil level. (Since we are often checking when refueling.)
(1) At your first (or next) oil change, drain all the oil, change the filter. (Oil should be changed when the engine is warm/hot to remove the most possible contaminates.)
(2) Fill the engine with the correct amount of oil, run the engine for about one -two minutes. (This fills the new filter) Turn off the engine.
(3) Check the level on the dipstick, this would be aprox where the warm/hot level should be on the stick.
2SS/RS L99 A6 CGM/white rally stripe, Black interior, Polished wheels, Heritage grill w/69 "SS" emblem and Pistol grip shifter by George Carter Fabrication and Design.
Ordered 08/31/2009
Delivered 10/15/2009
Serial# 52,222
BigJoe is offline   Reply With Quote
Old 10-01-2009, 05:32 PM   #11
Dinky Toy
Drives: 2LT/RS A6 CGM/IO Zaino
Although the dipstick (see 1st picture) on the V6 is quite fancy, I do think that the old fashion "flat bar twisted end" (see 2nd picture) is much clearer to read...
The new fancy one drags too much oil up into the dipstick tube and onto the top of the solid part were it meets the wire part.
Also I believe I have seen other reports that the V6 takes closer to 5.5 qts then 6.
This may have something to do with the engine not having been properly drained but what do I know as I was kicked out of the garage when I wanted to watch...!
I would suggest to just have 5.5 qts added and keep a close check and add a little if necessary, is much easier then having to drain some yourself when you don't have a bridge.
And YES, the manual could have been written a little clearer...
Although I would like to believe BigJoe in post #10, does his C-D-E range comply with the below description???
Until somebody tells me otherwise, I am going against the manual and with BigJoe using the C-D-E range...
From the manual:
QUOTE
When to Add Engine Oil
If the oil is below the cross-hatched
area at the tip of the dipstick,
add at least one liter/quart of the
recommended oil. This section
explains what kind of oil to use.
For engine oil crankcase capacity,
see Capacities and Specifications
on page 11-2.
Notice: Do not add too much oil.
If the engine has so much oil
that the oil level gets above the
cross-hatched area that shows
the proper operating range,
the engine could be damaged.
See Engine Compartment Overview
on page 9-6
for the location of the
engine oil fill cap.
Add enough oil to put the level
somewhere in the proper operating
range. Push the dipstick all the
way back in when through.
UNQUOTE
Dinky Toy is offline   Reply With Quote
Old 02-21-2011, 09:38 PM   #12
dougpaw57
Drives: 2011 Ford F-150
Send a message via AIM to dougpaw57 Send a message via Skype™ to dougpaw57
Sorry to dig up an old post but I always wondered why there wasn't a picture of the dipstick in the manual, especially since there's no "full" or "add" line. I guess Camaro drivers supposed to know all this. The wife got a CTS with the LLT engine last weekend, they're not too proud for pictures. Here's a scan of the Cadillac manual.
dougpaw57 is offline   Reply With Quote
Old 09-29-2011, 07:45 AM   #13
metthem
metthem's Avatar
Drives: 2011 LS
I love digging up old posts, my oil is so clean I can't even read where the oil is on that dipstick. Or am I out of oil?
metthem is offline   Reply With Quote
Old 09-29-2011, 01:30 PM   #14
jtzako
Drives: 2010 IBM Camaro SS
You should be able to see some on there, it will look wet basically. If you cant see any oil at all on the stick something is probably wrong.
2010 Camaro SS Imperial Blue | CAI Inc, CAI | Solo Hi Flow Cats | X-Pipe | Backup Camera | PDIM
jtzako is offline   Reply With Quote
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 09:51 AM
synthetic motor oil? bigd1276 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 71 01-29-2009 01:28 PM
The 3,000 Mile Oil Change Myth KILLER74Z28 General Automotive + Other Cars Discussion 35 07-20-2008 10:02 PM
gas prices. Congoman775 General Automotive + Other Cars Discussion 65 05-28-2008 01:20 PM
