Homepage | Garage | Wiki | Register | Members List | Social Groups | Calendar | Search | Today's Posts | Mark Forums Read |
Thread Tools |
#155 |
Dances With Mustangs
Got the billet aluminum pedal covers installed. They look nice and work well. They grip so well I may take a bit of sandpaper and smooth down the very top surface so they don't chew up the bottom of my shoes.
Blue Angel is here!! ![]() 1SS/RS LS3 M6 IBM |
#156 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Black Camaro 2SS/RS Join Date: Aug 2009
My boyfriend don't mind it. |
#157 | |
#158 |
just can't seem to leave
man, i wish you could've been at our Vettes & Jets show here on base a couple weeks ago... the Naval Aviation Museum set up one of the old Angel F18s for us out back :(
#159 | |
#160 |
They would probably take you on some kind of tour (maybe even in the plane! maybe even FLYING in the plane!) if they saw your car!
#161 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro LS Join Date: Sep 2009
2010 Summit White Camaro LS / M6 MRT V2.0 ![]() |
#162 | |
#163 | ||
![]() Quote:
#164 | |
SoCal Race Team #13
One thing on my list that I haven't seen on yours is an electric water pump. (Link below)... Just be careful with your lower capacity battery the amperage draw may be too much. The way I see it the less drag on the engine the more power to the wheels! Meziere Camaro LS3/L99 Electric Water Pump It was a pleasure to see your ride and meet you (however briefly) at camarofest2.
A.K.A - Diarmadhi (old handle) - So much to do.. So little money
Owner : Fast-Stache Industries LLC |
#165 | |
At this point the car is so good I really just want to start running track events....spend my money on tires and brake pads cause I'm out having fun. ![]()
#166 |
Just a follow-up on previous issues. As some of you know, I had a problem at C5FII with the CF driveshaft which Frank at DSS has been first-class helping get sorted out. He sent a replacement aluminum shaft for me to use in the meantime so I weighed it and had it dynoed for comparison.
Here's the weight of the CF shaft without the endplates or bolts. Here's the weight of the aluminum shaft without the endplates or bolts. As you can see the CF shaft is only 2 lbs lighter. I'm working with Frank on some ideas to reduce some more weight on the CF shaft. Hopefully they'll work and we can pull another few pounds off. Functionally I can't tell any difference between the two; the aluminum is just as quiet as the CF. Putting it on the dyno there was only a 4 hp difference compared to the CF which, considering this dyno run is almost a month after the previous one with the CF shaft, the results are certainly within the margin of normal variance so basically the aluminum shaft is performing the same as the CF. This means it's the improved efficiency of the 1-piece versus the factory 2-piece that's making the difference. The 2 lbs less weight on the CF shaft doesn't appear to make any appreciable difference. If we can remove another 3-6 lbs though, that may change things. Right now I'd recommend anyone considering one of these shafts to go with the aluminum one; it's $500 cheaper than the CF shaft and is definitely worthwhile. Here's the dyno with the aluminum shaft. The other thing that's apparent is the gains shown in the previous dyno are for real. The Bassani LT headers with high-flow cats and a tune really do make the power. This car just flat-out gets up and moves when you push the pedal. ![]()
#167 |
Prefer to be blown!
Drives: 2010 Silver/Black 2SS/RS Manual Join Date: Mar 2010
Nice looking ride, I love the two colors you went with.
#168 |
Its all about the U
Drives: 2010 SGM Join Date: Mar 2010
great build and journal, your car is definitely one to be admired . Thanks for all the detailed info and description, very helpful
Tags |
camaro of the week |
Thread Tools | |
Jetstream blue vs. aqua blue | rayhawk | Cosmetics and Lighting Modification Discussions | 45 | 05-31-2013 09:33 PM |
[COTW: 9/6/10]: maxpower5's Imperial Blue L99 | maxpower5 | Camaro Photos | Spyshots | Video | Media Gallery | 82 | 11-11-2010 12:51 PM |
Raise our voices!! We need a 2nd Blue in 2011!! | SS22 | 5th Gen Camaro SS LS LT General Discussions | 51 | 01-04-2010 10:14 PM |
Pic request: Imperial Blue Metallic / Aqua Blue Metallic | JameSS | Camaro Photos | Spyshots | Video | Media Gallery | 38 | 11-08-2009 03:20 PM |
Will there be anything Blue for the interior??? | JeanBond21 | Cosmetics and Lighting Modification Discussions | 4 | 09-30-2008 01:53 AM |
