sjm autoprod
Old 11-14-2011, 10:03 AM   #225
Kabul SS
Kabul SS's Avatar
Drives: IBM Camaro 2SS
Doc,
Great build thread and I like the way your car turned out. I'm running the same size tires as you and it's about time for coilovers. I was wondering how far did you drop the car with the coilovers (looks perfect) and have you had any ground clearance issues?
Kabul SS is offline   Reply With Quote
Old 11-16-2011, 03:42 PM   #226
CamaroFemme
CamaroFemme's Avatar
Drives: 2010 Black Camaro 2SS/RS
You've got to have the most unique cars in your neighborhood!
And just a reminder about that Basani exhaust vid!
My boyfriend don't mind it.
CamaroFemme is offline   Reply With Quote
Old 12-16-2011, 03:06 AM   #227
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
I've purchased a new twin disk clutch and flywheel from Mantic that will be going in next week along with a performance cam. The Mantic ships with a beautiful case! After spending awhile researching clutches and flywheels I chose the Mantic 9000 because it has the features and weight reduction I was looking for.
Here's the case it ships in:
Here's the flywheel which is billet steel; this whole combo of flywheel and clutch is SFI 1.1 safety rated. The bag contains the mounting hardware:
Weighing all the pieces to get a total assembly weight.
The total weight of everything including hardware is 35.1 lbs. I believe the factory flywheel and clutch weigh 57 lbs but I've been unable to find reliable info from internet research. I'll weigh the stock setup once it's off the car. If that figure is correct then I'm saving 21.9 lbs of rotational weight.
The nice thing about this setup is the Mantic designers understand the importance of not only reducing weight, but where to reduce it. Removing the weight from the outside of the flywheel has more of an impact on performance than just a lighter flywheel. The farther from the rotation center weight is, the greater the performance penalty. I was looking at aluminum flywheels because they seemed to be the only ones that could get down to the lighter weights but I'm not overly keen on the idea of aluminum for a flywheel. I was very pleased to find Mantic's 15 lb flywheel was billet steel and properly designed with weight reduction, as well as being fully SFI certified which was a very important consideration.
Next week I'll have more photos, before and after dyno charts and driving impressions. Unfortunately I won't be able to do a before and after dyno with just replacing the clutch because the shop that's doing the install is doing the clutch and cam at the same time. On an average the lighter clutch would normally allow about another 10 hp and torque to make it to the rear wheels. The bigger improvement is how fast it reaches maximum power and torque. It should get to peak levels anywhere from 2-4 seconds faster than stock. The before and after dyno comparison is going to be very interesting!
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
Old 12-16-2011, 12:20 PM   #228
IOM Black Diamond
HT5 COTW 1/21/13
IOM Black Diamond's Avatar
Drives: 2010 Camaro Inferno 2SS RS 6M
Very nice set up I will be waiting to see the numbers.
IOM Black Diamond is offline   Reply With Quote
Old 12-23-2011, 12:35 PM   #229
Padre
Only drives on Sundays
Padre's Avatar
Drives: '16 2SS A8 NPP MRC NGray
Great update Doc. Nice to have some honest dyno numbers.
What cam are you going with? I LOVE mine. I imagine you've put a lot of research into it, so I'd love to see what you come up with and share it with us.
Padre
OLD HOTNESS: The "Heretic": '11 2SS/RS L99 A6 Black/Inferno. Build Journal, Videos
D1SC GT9 JBA-LT = 720/680 | 10.330 @ 133.61, 1.546 sixty... Camaro King at ECS V, Darlington.
NEW HOTNESS: '16 2SS A8 NPP MRC. Bone Stock, 1/8th: 8.051 @ 89.44, 1.919
Padre is offline   Reply With Quote
Old 12-23-2011, 01:59 PM   #230
5thGenCamaroKid
No fat chix, car scrapes.
Drives: 2014 GMC Sierra 1500
Doc - just read through your entire build. I'm floored with your the high attention to detail you've put throughout your build process. This truly is a spectacular build.
5thGenCamaroKid is offline   Reply With Quote
Old 12-30-2011, 01:41 AM   #231
Doc
Doc's Avatar
Padre
Went with the Comp Cam XR275HR street/strip cam. It's a step above the GM Performance "hot" cam, but not too radical. Just picked the car up today and it's a blast!
Thank you.
1SS/RS LS3 M6 IBM
Old 12-30-2011, 02:02 AM   #232
Doc
Doc's Avatar
Got the car back today and the final dyno:
Name:  Cam Dyno 12-29-11.jpg
The bottom line in light purple is the "before" run with the hood closed. The light green line just above it is the "before" run with the hood open; it shows 414.1 rwhp and 421 lbs of torque. That's the number of importance in this instance because the dyno tune and final number was run with the hood open.
The top line in red is the final run; 468.6 rwhp and 448.3 lbs of torque. That's a gain of 54.5 rwhp, and 27.3 lbs of torque. As you can see from the curve though the torque is MUCH improved and kicks in a lot earlier than the stock cam did and boy can I feel it. Between 4500 and 5500 rpm the Comp cam really produces above and beyond the factory cam.
Overall I am quite pleased with the result. The car now sounds even better than before with a mild lope; not too much but enough to know "it ain't stock". The new Mantic clutch is terrific. I was very surprised at how smooth it is. It takes less pedal effort than the stock clutch and the engagement is smooth, clean and precise. Although I drove home in bumper-to-bumper, stop-and-go traffic and wasn't able to really push the car at all, I could still tell it wants to GO. I need to go easy on the clutch for the first 500 miles to break it in but already I can tell the improvement in acceleration; throttle response is instant.
Tomorrow I'll weigh the stock clutch, flywheel and bolts to get an accurate number and post the results. I did take videos of the before and after dyno runs so you can hear the difference; just need to figure out how to post up videos lol.
1SS/RS LS3 M6 IBM
Old 12-30-2011, 01:55 PM   #233
Doc
Doc's Avatar
Just weighed the stock clutch and flywheel bolted together and they weigh 57 lbs 2.2 oz or 57.13 lbs.
So with the stock setup weighing 57.1 and the Mantic setup I replaced it with weighing 35.1 I've saved a clean 22 lbs of static and rotating weight. Since my car weighed 3740 lbs with a full tank before I did these mods, theoretically it should now weigh 3718 lbs. I'll take it to a truck scale to get it weighed. But assuming the weight of 3718 and the new power of 468 rwhp my power-to-weight ratio is now 7.94-1 beating my target goal of 8-1.
1SS/RS LS3 M6 IBM
Old 12-30-2011, 02:19 PM   #234
Padre
Padre's Avatar
Most excellent Doc!
Looks like the Comp Cam will fit nice with your goals. What a great driver's car!
Padre
Old 12-30-2011, 04:33 PM   #235
4thGen427CI
5th Gen
4thGen427CI's Avatar
Drives: 10 SS
If you have, how much of an increase have you seen in mpg? I'm sure stop and go traffic doesn't help but then again rpms are always low
4thGen427CI is offline   Reply With Quote
Old 12-30-2011, 09:54 PM   #236
Doc
Doc's Avatar
I just got the car back yesterday and haven't had time to check the mpg but that's something I'll check once the clutch is properly broken-in.
1SS/RS LS3 M6 IBM
Old 12-30-2011, 09:57 PM   #237
Doc
Doc's Avatar
Here's an updated snapshot of the upgrade list. Only a couple of things left unless I discover something else . I need to dig up the weight info on a few of those items but what's there so far is accurate. (This is a newly revised list from the one on 12-30-11; I've added some suspension component weights on items 16 and 17).
1SS/RS LS3 M6 IBM
Old 01-04-2012, 04:42 PM   #238
CamaroFemme
Hey Doc! Awesome job as usual. Did I miss the exhaust video? I urge you to put one up because I wanna hear it! Dare you bite the bullet and put a price beside each of those components??? (But seriously, genuinely curious.)
camaro of the week
Jetstream blue vs. aqua blue rayhawk Cosmetics and Lighting Modification Discussions 45 05-31-2013 10:33 PM
[COTW: 9/6/10]: maxpower5's Imperial Blue L99 maxpower5 Camaro Photos | Spyshots | Video | Media Gallery 82 11-11-2010 01:51 PM
Raise our voices!! We need a 2nd Blue in 2011!! SS22 5th Gen Camaro SS LS LT General Discussions 51 01-04-2010 11:14 PM
Pic request: Imperial Blue Metallic / Aqua Blue Metallic JameSS Camaro Photos | Spyshots | Video | Media Gallery 38 11-08-2009 04:20 PM
Will there be anything Blue for the interior??? JeanBond21 Cosmetics and Lighting Modification Discussions 4 09-30-2008 02:53 AM
