SDTW Custom Wheels & Tires
Old 02-28-2011, 11:12 PM   #113
Hendrix-Engineering
Drives: First 9 inch-12 bolt IRS Camaro
Very Nice!
Thanks for the feedback
Hendrix-Engineering is offline   Reply With Quote
Old 03-08-2011, 09:57 AM   #114
Blue70SS
Blue70SS's Avatar
Drives: 2010 LS3Camaro2SSRS IOM in/out
Originally Posted by Doc View Post
Finally got my carbon fiber driveshaft I've been wanting and trying to get for over a year.
Frank at Driveshaftshop built it and it's a work of art. Shame it has to be hidden where it can't be seen. When I received it I weighed it with all the bolts and hardware on it and it weighed 21 lbs. 5.6 oz. The stock factory driveshaft which is a 2-piece aluminum shaft weighs 24 lbs. 13.4 oz. (this is with all the hardware and bolts). The 1-piece cf shaft is about 3.5 lbs lighter.
There is a huge difference in the quality and strength of the DSS shaft versus stock. You can see the difference in the joints on both ends as well as the overall finish.
I had my car dynoed before the install and best pull out of 3 was 375.15 hp with 373.52 torque. Last year I had a dyno at this same facility which is GTR Performance in Rancho Cucamonga, California and it dynoed at 370 hp with 375 torque. Ricardo there at GTR did a great job doing the dynos and install. The only change between then and now engine-wise was I got the VMAX cnc ported throttle body which it seems added about 5 hp, although when looking at the curves it had changed the torque curve to more torque earlier which is mostly what I felt after I had installed it.
After the CF Driveshaft was installed we dynoed it again and the results were good. Best pull out of 3 was 383.3 hp with 382.89 torque. This was an increase of 8 hp and 9 torque. The biggest surprise was the torque curve; you can see in the graph I've attached how much earlier it increases which I mostly attribute to the improved efficiency of the 1-piece shaft compared to the 2-piece factory shaft.
Driving impressions: I noticed the improved smoothness of the acceleration right away; I can definitely feel the improved torque but mostly just how smooth this thing now pulls all the way up the revs. The DSS shaft is dead smooth; in fact I can put my hand on the shift lever and feel virtually no vibration at all when driving which is quite an improvement over the stock shaft.
Summary: In summary I think the fact that it's 1-piece makes more of a difference than being 3.5 lbs lighter although I know that has to have some effect; probably improves response time I'm guessing. It's hard to say since I haven't tried the aluminum shaft he makes but my guess is unless you're doing a full or mostly race build, the extra expense of the CF shaft probably isn't necessary. I'd definitely recommend the 1-piece aluminum shaft though because the difference in smoothness and pull compared to stock when you accelerate is very very nice. These stronger joints will also hold up under the higher loads of forced induction, nitrous, etc.
Now for some pics...
Here's a shot of both shafts so you can see the difference between the Driveshaftshop 1-piece and the factory 2-piece:
Attachment 209522
Here's a shot of the DSS shaft on the weight scale:
Attachment 209523
Here's a shot of the factory shaft on the weight scale:
Attachment 209524
Here's a shot of the differences between the DSS joint and factory joint on the trans end:
Attachment 209525
Here's a shot of the differences between the DSS joint and factory joint on the differential end:
Attachment 209526
And here's the dyno sheet showing the baseline run in blue before the install, and the results in red after the install:
Attachment 209527
All in all I'm very pleased with the results and I'm looking forward to adding some power now. Any of you guys that have added headers, superchargers, etc. by all means get yourself one of these 1-piece shafts from Driveshaftshops and ask for Frank; he's a vendor and posts on this forum. If you're in the Inland Empire area of southern California then Ricardo at GTR can get the job done for you if you want a dyno and install.
Thanks for a great post. Between this and talking with Frank at DSS, made my decision to get the CF shaft much easier.
LPE Brotherhood
Old 03-08-2011, 01:44 PM   #115
Doc
Dances With Mustangs
Doc's Avatar
Drives: 2010 1SS/RS MT
You're welcome. I'm guessing the more power you're pushing through, the more benefit the CF shaft will provide over the stock shaft. You can see the harmonics and inefficiency losses in the wobbly lines on my dyno chart as it climbs up the power band. And that's on a basically stock engine. Although the peak torque increase was only 9 lbs you can see a nice fat increase up to 15 lbs in the 3k-4k rpm range. That's a very usable range.
If you get this please post the dyno results; I'll be very interested to see how much of an improvement it makes when you're really pushing a lot of power through it.
Blue Angel is here!!
1SS/RS LS3 M6 IBM
Doc is offline   Reply With Quote
Old 03-08-2011, 03:14 PM   #116
Blue70SS
Blue70SS's Avatar
I'll see if I can make that happen. Curious to see dyno changes anyway after 3.70 gears and Pfadt solid subframe bushes anyway.
Thanks again!
LPE Brotherhood
Old 03-09-2011, 06:38 AM   #117
10spokess
Wild and Cammed
Drives: 2002 Camaro SS
Man that is some serious crud lol, great looking car and build I must say. I'm going to be watching this thread for a while
10spokess is offline   Reply With Quote
Old 03-09-2011, 04:11 PM   #118
10camaross
10camaross's Avatar
Drives: 2010 camaro ss/rs 6spd manual
How does the cf drive shaft hold up for daily driving, i heard that a cf shaft is very strong but can break or shatter if something hits it or something to that effect. Any input on this??
10camaross is offline   Reply With Quote
Old 03-09-2011, 04:32 PM   #119
Doc
Doc's Avatar
Nothing short of getting hit by a big rig would threaten the integrity of this driveshaft. If that happens the condition of the driveshaft is the least of your problems.
It's tucked up and out of the way and the exhaust pipes below it provide protection too. You'd have to be running brutal amounts of horsepower, in excess of 1000 hp before you'd get close to causing this to break and by that time I suspect you'd have broken gears or joints first already.
For daily driving on the street this shaft is actually overkill but it's great!
1SS/RS LS3 M6 IBM
Old 03-09-2011, 05:37 PM   #120
10spokess
Wild and Cammed
Woah I almost thought you were me for a second and I was like I didn't post that. Anyways sorry for thread jacking and get back to look at the beautiful blue angel
Old 03-17-2011, 06:56 PM   #121
SirMike
Inland Empire Camaro Club
SirMike's Avatar
Drives: 2011 Camaro 2LT RS, 2015 Challenger
Doc, great thread, great write ups and super cool ride. Keep it up
SirMike is offline   Reply With Quote
Old 03-29-2011, 12:39 AM   #122
Doc
Doc's Avatar
Sneak Peek.
Finally getting paint mods done. Here's a sneek peek at some of the pieces...
First is the hood. First pic shows the hood spears sanded and masked, second pic shows it being painted, third pic shows it done.
Then we have the lower front. First pic shows it sanded and masked, second pic shows it being painted, third pic shows it done.
Last we have the rear spoiler. First pic shows it sanded and masked, second pic shows it being painted, third pic shows it done.
Name:  Rear Spoiler 1.JPG
Name:  Rear Spoiler 2.JPG
Name:  Rear Spoiler 3.JPG
I'm hoping everything will be ready tomorrow so I can pick the car up. Or Wednesday at the latest. Can't wait to see it finished!
1SS/RS LS3 M6 IBM
Old 03-29-2011, 05:21 AM   #123
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
Very cool Doc.
That is going to look incredible live !!!
Old 03-31-2011, 03:14 PM   #124
CamaroFemme
CamaroFemme's Avatar
Drives: 2010 Black Camaro 2SS/RS
Subscribed and rated 5 stars.
My boyfriend don't mind it.
CamaroFemme is offline   Reply With Quote
Old 03-31-2011, 03:47 PM   #125
Edge.128
Edge.128's Avatar
Drives: 2010 Camaro LS
i've been following on and off but maybe i missed it somewhere so sorry if asked already, but currently what is your total weight savings? thanks. great build!!
2010 Summit White Camaro LS / M6
MRT V2.0
Edge.128 is offline   Reply With Quote
Old 03-31-2011, 05:44 PM   #126
Doc
Doc's Avatar
I should be able to pick up the car on Tuesday and I plan on getting it weighed then. Should be around 3735 I'm guessing.
1SS/RS LS3 M6 IBM
camaro of the week
Jetstream blue vs. aqua blue rayhawk Cosmetics and Lighting Modification Discussions 45 05-31-2013 09:33 PM
[COTW: 9/6/10]: maxpower5's Imperial Blue L99 maxpower5 Camaro Photos | Spyshots | Video | Media Gallery 82 11-11-2010 12:51 PM
Raise our voices!! We need a 2nd Blue in 2011!! SS22 5th Gen Camaro SS LS LT General Discussions 51 01-04-2010 10:14 PM
Pic request: Imperial Blue Metallic / Aqua Blue Metallic JameSS Camaro Photos | Spyshots | Video | Media Gallery 38 11-08-2009 03:20 PM
Will there be anything Blue for the interior??? JeanBond21 Cosmetics and Lighting Modification Discussions 4 09-30-2008 01:53 AM
