Old 06-10-2008, 06:00 PM   #1
Xcessive
Drives: 1997 Z28 Camaro 30th Ann.
Antifreeze
I am flushing my radiator in my 1997 LT1. Is radiator flush necessary, and do we have to use Dexcool antifreeze? Thanks for the help.
Xcessive is offline   Reply With Quote
Old 06-10-2008, 06:43 PM   #2
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
If your car started with Dexcool you can put Dexcool back into it. When I was at the dealership back when the Dexcool came out, you could not add it to a car with regular coolant unless you flushed ALL of the old coolant out of the system because it would contaminate the Dexcool and render it mostly ineffective. Nowadays, I believe there are Dexcool types out there that are compatible with the old coolant. Just check the coolant at the store to see if it will work with both.
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/Kooks 1 7/8" LTs and 3" H-pipe/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WB/ Pioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 06-10-2008, 09:02 PM   #3
XtremeBowtie
XtremeBowtie's Avatar
Drives: 2013 2SS/RS 1LE Camaro / 1963 C-10
I flushed the Dexcool out of my S-10 and Blazer, and put in good ole' green antifreeze. I'm old fashioned I guess. They do make antifreeze that is compatible for both though.
Thank you God for my Salvation! May others seek your Son, Jesus Christ!
My 63 Double Dropmember Build "Project Sub-Zero": http://67-72chevytrucks.com/vboard/s...42#post5050342
86 C10 Daily Driver "Build Thread": http://67-72chevytrucks.com/vboard/s...d.php?t=668777
XtremeBowtie is offline   Reply With Quote
Old 06-10-2008, 09:55 PM   #4
z28collection
waiting for 5th gen
z28collection's Avatar
Drives: 99 z28 6 speed, 81 z28 auto
antifreeze
ive seen coolant systems that were mixed and the stuff turns into mud
speed kills-drive a ford and live forever
http://www.myspace.com/ashleyjfowlkes
z28collection is offline   Reply With Quote
Old 06-11-2008, 11:16 AM   #5
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I'm not suggesting you mix, but I don't like mixing fluids like that.
Old 06-11-2008, 04:43 PM   #6
Xcessive
I put Dexcool in it. It is 15 dollars a gallan at Autozone. Been a while since I bought antifreeze.
Old 06-11-2008, 04:45 PM   #7
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
dexcool = deathcool. green is good.
flush the entire system, not just the rad.
I piss excellence
and fart awesomeness
