10-10-2009, 04:43 PM | #29 |
ZEUSS
Don't go there. The last thread about this went way off track and got closed.
10-10-2009, 04:48 PM | #30 |
10-10-2009, 04:51 PM | #31 |
ZEUSS
10-11-2009, 08:25 AM | #32 | |
Drives: 2009 Pontiac G8 GT Join Date: Jun 2009
If GM wants to call a owner re-settable system a mileage counter, I guess that is OK. It will only show the mileage from the last user re-set. On a side note, I just replaced a ECM in a new Camaro and didn't have to re-set the oil life, it was still correct. |
10-11-2009, 11:55 AM | #33 |
Drives: GM Join Date: Oct 2009
The internet is a great place to disseminate information, this message board is no exception however there seems to be a lot of misinformation relative to our ECM family specifically the Camaro ECM so I’d like to take a minute to address some statements to allow a glimpse into how we program these controllers.
Does the E38 have a “flash counter”? Both the original E38A and E38B have support for a flash “tracking system” of sorts. While it’s not as in depth as the Bosch E35 used on the LMM trucks it does exist however current production releases have it disabled, but this could change at any time. When programmed by a GM Facility the unit already stores the programming date (as sent by the programming software) as well as the programming station or repair facility ID. OLMS/Odometer OLMS does have an Odometer? Yes it does, its used for a very small part of the OLMS system operation. “OLMS is partially in the ECM” OLMS resides in it entirety in the ECM. On this note OLMS does not read mileage from the IPC or any other module in the vehicle. “The 2009.5 G8 ECM is the same as the Camaro” While they both have the revisions for the new version 8 software they are most certainly not the same. The 2009.5 L76/LS3 G8 uses the 12625455 ECM for software rev 8.9 while the Camaro uses the 12633238 for the newer 8.10 software. In fact if you load a Camaro calibration into the G8 ECM it will render it unusable. http://www.camaro5.com/forums/showpo...3&postcount=74 AFM actually can be controlled by the transmission status bit, this is how it’s turned off in Manual mode otherwise when the ECM saw the conditions even in manual mode to enter AFM it would. The AFM enable by trans status bit can be set in the ECM. |
10-11-2009, 12:24 PM | #34 | |
10-11-2009, 12:36 PM | #35 |
Without getting into any security infringement the Odometer for OLMS is hard but there are other things that work with it and store other info relative to it.
As far as the '10 software on the 09 ECM, the only way that would work is if it was a new green unit and you loaded it and even that is short lived. The unit will load but once the MEC decrements down to 0 and turns security on the unit will be a paperweight for all intents and purposes. It will run but more than likely with a RAM error however it will be unable to be re-written past this point. This was the issue that Corvette owners have run into as of late I'm sure others in the aftermarket have encountered this as well as I've seen a lot of these units with '10 software on them from people trying to add launch control to the 2009 Corvette. |
10-12-2009, 01:42 AM | #36 |
www.Camaro5store.com
You can't lose your warranty if you don't jack with the ECM and tune your car. Simple as that. And if you tune, ....and if something breaks....., don't go crying to GM telling them to fix it. In fact, for those wanting to change out ECM's to try and hide the fact the car had been tuned, ask yourself..... Is the possibility of losing the entire 5 year/100,000 mile warranty over 20 to 30hp really worth it? |
10-12-2009, 01:32 PM | #37 |
Drives: Firehawk Join Date: Jun 2009
Shouldn't this decision be up to the people who actually are on the fence about geting tuned rather than your obviously biased opnion about tuning?
10-12-2009, 01:39 PM | #38 |
Banned
Drives: 2002 LS1 swapped into a 1994 Z Join Date: Sep 2009
I've said it before...where is the integrity among enthusiasts? Stop treating you pride and joy like you hiding your income from IRS! Do what you like (tune or no tune), don't try to HIDE it, and IF you get caught, D'up and accept the fact that you like everyone before you has to PAY TO PLAY!
10-12-2009, 01:46 PM | #39 |
Scout Sniping
I have been in for warranty work directly related to reprogramming using the diagnostic port and had no issues.
Eric
Previous Car:1SS/CGM 6MT w/ Sunroof & FACTORY BLUETOOTH!!!: New Era OTR, Steeda Short Shifter, Ported TB, Stg 2 ported intake manifold, Fasterproms, Poor man down pipes, MBRP 3" Exhaust!!! Now I drive a F150 Supercrew |
10-12-2009, 01:51 PM | #40 | |
Camaro➎ moderator
Also, don't be rude, especially towards any of our moderators, we don't take that too kindly. |
10-12-2009, 02:15 PM | #41 | |
Truthfully I have seen more warranty claims from aftermarket wheels/tires than from tunes (which I have seen none). |
10-12-2009, 02:15 PM | #42 | |
We consider the members of this board to be a well informed community and can make educated decisions on there own. |
Similar Threads | ||||
Flash drive issues | 2010CamaroOutlaw | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 1 | 09-16-2009 02:57 PM |
Driven Performance ECM Flash on a Stock SS = +20hp / +30tq | Driven Performance | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 23 | 06-14-2009 12:43 AM |
ECU Tune | derin11 | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 1 | 05-29-2009 08:07 AM |
ECU Pics? | Jonmalibuss | Camaro Photos | Spyshots | Video | Media Gallery | 8 | 05-14-2009 02:55 PM |
itunes to Flash drive question | Eighty-Six Z | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 15 | 04-27-2009 05:39 PM |
