| Forced Induction - V8 V8 Supercharger, turbo, nitrous discussions |
Thread Tools |
![]() Drives: 2010 RS SS Join Date: Aug 2009
how you get your power, do the parts care?
Do the components in an engine "care" (for lack of a better word) how power is created? In other words, if I can make the same HP/torque curve either by forced induction or by freeing up the airflow (headers, CAI, high flow heads, cam, etc.) or with nitrous, will the components be more prone to failure in one versus another?
The reason I ask, is because I was doing the math on a turbo kit and considered opening up the entire exhaust with 3" pipes to make it flow better and let out more HP. Then I was thinking, well, that would make more power, but so would more boost with very little effort (and cost). If the engine doesn't "care", why go to the trouble of doing the exhaust? I could understand if you were trying to push the limits totally, but as far as a dependable driver (my application), you kinda have a certain HP/torque number you are just shooting for that you will not exceed without upgrading the bottom end. Why got to all the trouble of certain add-ons, when all you need is to turn up the boost? |
#2 | |
![]() Drives: Fast ones Join Date: Jul 2009
If you have any questions, feel free to pm me or call us at the shop. |
LVL 50 Troll Stomper
Drives: 2010 Camaro Join Date: Feb 2008
It seems that you're asking more-so about engine efficiency rather than total output. Yes they go hand in hand (a more efficient will make more power- or at least power in the form you can "use"), but that isn't always taking cost effectiveness into consideration.
For example, if you don't want to get a better set of heads for $1500 you could always up your boost- but this puts stress on other parts of the engine. In the end- I would say a good balance of cost effectiveness and efficiency make for some real mean/reliable engines. EDIT: Forgot to add, in boosted applications some things (like exhaust) can be bottlenecks for further power gain- so yes, the exhaust is a good preliminary modification.
Exactly, in a turbo application, you need the exhaust as free flowing as you can stand (loudness). This will provide "free" horsepower per boost level. If it was my car, I would have a true dual straight through muffler with 3 inch piping.
How about when considering a piston rod? If a rod is going to fail at XXX HP/tq, for example, does it matter how I get to XXX HP/tq?
OR, are you saying it would take more HP/tq to fail such a component if my engine were more efficient? I can see both sides: 1. Torque is torque. However you make it, components will fail at their torque limit. The force on the crank is the same. 2. Efficiency should make some components last longer. I think the answer is a mix of the two...some things will last longer due to efficiency, but some components are going to fail due to simple torque limitations regardless of the mechanism to get there. I think this might be what you guys were saying... |
#6 |
![]() ![]() ![]() Drives: Maggie blown LS3 vette Join Date: Aug 2009
In a boosted app, boost makes heat. You can run a stock exhaust and get say 550 to 600 at 8psi. You can make the same power on less boost with an open exhaust. Which is better?
I'll vote for the enhanced exhaust version. The intake air temps will be cooler under less boost and allow for more timing which makes as much power as more boost. Make the engine more effecient (make it a better air pump) and you can make power easier and more reliably. Yes, you can make some pretty good numbers on a stock motor with 10+psi and meth injection to add octane and cool things down a bit. Is it a good idea?......not in my book. |
#7 | |
Moderator.ca
__________________ Quote: In 2014 the camaro will have ... a twin turbo v6 ... around 350 to 360HP No. Let me repeat that. No. FbodFather __________________ Camaro5 Fest III Information Camaro5 Fest III pre-registration |
| Thread Tools | |
| Anybody Spray'n their SS yet - nitrous ? | WeeZee | Forced Induction - V8 | 38 | 12-29-2012 09:56 PM |
| 2010 SMS Mustang | TFord | General Automotive + Other Cars Discussion | 19 | 01-22-2009 11:00 AM |
| And Another Car Crash... | GTAHVIT | Off-topic Discussions | 73 | 01-12-2009 11:43 AM |
| Hardcore racers rejoice!! GM Performance Parts to offer new Camaro body in white | radz28 | 5th Gen Camaro SS LS LT General Discussions | 23 | 12-22-2008 09:57 AM |
