| 5th Gen Camaro SS LS LT General Discussions General 5th generation Camaro topics not covered by other subforums. |
Thread Tools |
![]() Drives: 2010 Camaro SS IOM/IOM Join Date: Jun 2009
GM Bulletin HVAC system reprogram caused window problem
Probably the wrong place to post this but I am looking for as much exposure as possible and hoping someone from GM might see this and respond with some advice. My dealer has no clue. Also posted under issues and problems thread
Took my car into the dealer today to actually have the truck latch replaced due to intermittent problem of it not popping up when it is released. Dealer said there was a bulletin to replace the trunk catch. While there they performed the HVAC reprogram. Not sure how the HVAC and window indexing are connected but now my drivers side window indexes down about 2.5-3" instead of just about 1" to clear the weather stripping. It was working fine and indexing 1" prior to this reprogram. Passenger side still only indexes about 1" It goes back up when you shut the door. So it is still working but the HVAC program screwed something up. Dealer said that they did not do anything to the drivers door or window. They just downloaded the program GM provided. They are going to do some research on the reprogram but for now there is no fix because they don't know what the problem is. Anyone else have a similar situation? |
I.AM.
Drives: 2010 2SS/RS/M6 Join Date: Oct 2008
weird.
you can try resetting the window indexing...there's a page on it in your owners manual...it's easy, worth a shot.
2010 R6P-2SS/RS/LS3 - IBM w/ silver rally stripes / UNDER CONSTRUCTION.
NY5thgen.com ![]() |
![]() ![]() ![]() Drives: 1997 SS & 2010 2SS/RS Join Date: Aug 2006
I think the window indexing has to be reset, i had to do this to both my windows when they did the battery recall fix, one was messed up kinda like yours the other was ok but i reset both. i think this might be your issue i'm not for sure , but they should have know this at the dealer if it was the problem indeed
#5 | |
"El Dictator"
Drives: 08 HHR SS, 2010 Camaro SS/RS #16429 Join Date: Sep 2006
#6 |
Put the windows all the way down then up that should reset them.
#7 |
NOICE!!! ™
Yup! Like everyone else said try and reset the window indexing feature and see what happens hopefully that will fix the problem. Keep us updated
#8 |
Already tried resetting the windows per the manual long before I posted here. Amy other ideas?
#9 |
Chevy Man
new car??
#10 |
Drives a Maro
Interesting, my windows started out indexing about 3/4 of an inch when I first got my car. I never really paid much attention to it but one day I noticed they were going down twice as far. I just figured it adjusted for whatever reason. I unplugged my battery over night to try to reset the commputer before Scott called to tell me to try a fuse pull, that started a movement lol, and when I rebooked the battery and reset the indexing I went back to original. Where it's been ever since. Roll each window down all the way keeping the switch pushed down for ten seconds after it hits bottom, and them do the same back up. If it doesn't work then who knows.
#11 |
Thanks, I try disconnecting the battery and see if that fixes it.
#12 |
I apologize in advance for my ignorance - your window indexing moves the windows down 3/4 - 1"?? I have never had window indexing before, so I presumed that it was just a small movement - 1/8" or so - that you wouldn't even notice. And I have never seen mine move. This is supposed to happen every time you open the door?
2LT/RS IBM, White Rally Stripes, Gray Int, M6
Ordered 10/18/08 Delivered - 6/19/09 |
#13 |
A ***'s Headache
Drives: Everything Join Date: Aug 2009
If you disconnect the battery you will need to reset index anyways.
#14 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 1984 Honda Nighthawk 700s Join Date: Sep 2008
#15 |
Zot!
Drives: Toyota 4Runner Join Date: Feb 2009
My dealer told me sometimes this happens on the Corvette too. Roll the window all the way down and hold the down button for 3 seconds, and then roll the window back up and hold it up for 3 seconds
it will reprogram the windows program so that it knows where the top and bottom are.
#16 |
![]() Drives: Victory Red LT RS Born:3/3/09 Join Date: Sep 2009
My A/C was not blowing out of the correct place. it was coming from the defroster, and down below, when it should be flowing from the dash vents. Chevy kept my car over night to fix, cause the re boot was messing the windows up too. I love my Camaro, i hate problems!!!
#17 |
Well before I tried disconnecting the battery this morning I thought I would try to reset them one more time.
As soon as I pushed the down button the message appeared on the DIC telling me to hold down the button to reset the window. I didn't get the message at all yesterday while trying to reset them several times and several attempts at resetting them had no effect on the problem. Now all of a sudden the car thinks that it needs to be reset. I went through the process but held the button in the down and up position for 20-30 seconds in each position just for good measure. Now problem is solved. Could this just be a new car window issue or is it somehow related to the A/C reprogram. Maybe just a coincidence that it happened after the A/C reprogram. Fixed for now. Thanks for all your input and sharing in my frustration. |
| Thread Tools | |
| Tracking All Currently Known US VIN and Window Stickers - Order Tracking Thread | UCF w00t | Camaro Price | Ordering | Tracking | Dealers Discussions | 4242 | 09-19-2011 03:27 PM |
| GM bulletin: HVAC system reprogram / rear spoiler repair / engine harness inspection | Bonemaro | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 65 | 06-13-2010 05:41 AM |
| GM Bulletin HVAC system reprogram caused window problem | VegasSS | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 6 | 10-09-2009 09:05 AM |
| Problem Window Tinting? | 87irocz | Cosmetics and Lighting Modification Discussions | 23 | 06-05-2009 08:17 PM |
| Window index problem | camaroqueen | 5th Gen Camaro SS LS LT General Discussions | 33 | 04-29-2009 08:07 AM |
