Hines Performance (HPE)
Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust
Old 10-03-2009, 12:41 AM   #1
GOINGSOLO2
GOINGSOLO2's Avatar
Drives: All Models
Solo Performance- L99 Exhaust Update with Pictures and Videos
All we can say is WOW!!!!!
Here is what I can tell you right now:
Decibel readings:
Stock exhaust...90-DB
Quantum Axle Back...108-DB
Mach-X-L...118-DB
Mach-X-L
The Mach-XL exhaust kit for your 2010 Automatic Camaro has 2 ½” mandrel bent stainless steel exhaust pipes all the way from your converters back. Solo’s 14” Mach-XL muffler is used to deepen the sound (28 decibel over stock) and add responsiveness to the car. The 4 cylinder mode on the automatic Camaro’s can cause a severe drone but not with Solo’s Mach-XL exhaust kit. This is a ZERO DRONE exhaust system. The smooth deep sound is best described as “Pure American Muscle.” The sound of power stays primarily outside the car where it needs to be. You can certainly hear when the car changes from 8 cyl to 4 cyl mode but there is no drone and you can hold a conversation with absolutely no extra effort. The interior cabin sounds beautiful on acceleration and quiet while cruising. Solo’s T304 Stainless Steel 4.5” tips finish off the Mach-XL in the style befitting this retro yet futuristic, soon to be classic, automobile.
WOW
Quantum Axle Back
Just cut your stock exhaust pipes 24 ½” behind your mid-skid plate and slide on the Quantum Axle Back exhaust kit from Solo Performance. It’s just about that easy to get a wonderful sounding “NO DRONE” exhaust kit on your 2010 V8 automatic Camaro. 2 ½” T409 stainless steel mandrel bent pipe is used in conjunction wit 4 ½” T304 stainless steel exhaust tips and stainless steel polished tig welded resonators.
This zero drone exhaust kit is very well priced at $449 including shipping. All necessary hardware is included in this kit. On acceleration the sound is deep and smooth. No popping on acceleration and you can hold a conversation at any speed without raising your voice. The automatic 4 cylinder mode is no problem for these incredible resonators. Zero Drone and a Beautiful Tone!
WOW
Both kits will be in a group buy soon....prices for the L99 will be as follows:
Quantum Axle-Back- $449 shipped
Mach X-L- $775 shipped
GOINGSOLO2 is offline   Reply With Quote
Old 10-03-2009, 01:00 AM   #2
Xmicro_SS
Thank You GM
Xmicro_SS's Avatar
Drives: Sky Redline & Camaro 2SS/RS
Damnnnnnnnnnnnnn.........Ok, that sounds sick!! The slightly larger resonator is VERY DEEP.
Nice L99 owners..........pretty badass!!
DO I SMELL A GROUP BUY??? Sniff Sniff
ITS HERE! : 2010 Camaro 2SS / 6 Speed Manual (No other way) / Silver Ice Metallic / Inferno Orange Interior Accent / RS Package / Polished Wheels / SOLO MACH X CAT BACK
Xmicro_SS is offline   Reply With Quote
Old 10-03-2009, 01:04 AM   #3
GOINGSOLO2
GOINGSOLO2's Avatar
Drives: All Models
A group buy will be coming soon...we will also be posting an even better video of the L99 Mach X-L shortly!! We are planning on offering the same incentive as the LS3 kits...up to 20% off...1% per order, up to 20+ orders.
UPDATE: Another L99 Mach X-L video has been posted for you!
Old 10-03-2009, 01:07 AM   #4
Xmicro_SS
Thank You GM
Xmicro_SS's Avatar
Nice Steve, this should be well worth the 1 week wait. The video's sound killer, I can only imagine what the system sounds like in person!
Solo Rocks
Old 10-03-2009, 01:42 AM   #5
Grimelock2009
Drives: 2010 Camaro
Wow that sounds awsome...
Grimelock2009 is offline   Reply With Quote
Old 10-03-2009, 05:42 AM   #6
ZombieEatsYou
ZombieEatsYou's Avatar
Drives: "Bmblbee" 2010 RY 2SS/RS. VIN 12043
that's what I've been waiting for!
ZombieEatsYou is offline   Reply With Quote
Old 10-03-2009, 06:10 AM   #7
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
One of the biggest issues with aftermarket exhausts on the L99 is the change in exhaust tone when the engine transitions from 8cy to 4cy mode.
This change is exhaust tone is what becomes very annoying over time.
It took me a few weeks before I started getting annoyed by my GMPP axle back because of this. It's pretty much drone free, but its still quite annoying because of the change in exhaust tone around 1800 rpms due to the AFM.
So from what I'm hearing the Solo exhaust is no different (still changes tone due to AFM). And once you add headers it will make the difference even more noticeable.
I still see the only way around this is by turning off the AFM if you're planning an aftermarket exhaust setup on an L99.
Old 10-03-2009, 08:50 AM   #8
HeavyD
HeavyD's Avatar
Drives: 1SSRS RY L99
Sounds great, thankyou for posting a video!
HeavyD is offline   Reply With Quote
Old 10-03-2009, 09:05 AM   #9
jsharp
NOW CAMMED & SUPERCHARGED
jsharp's Avatar
Drives: 2010 Camaro 2SS/RS Black w/ IOM
What are we looking at power wise tune vs no tune
jsharp is offline   Reply With Quote
Old 10-03-2009, 10:11 AM   #10
GOINGSOLO2
GOINGSOLO2's Avatar
Drives: All Models
The AFM is impossible to keep as a V8 sound, simply because it only uses 4 cylinders. You could turn it off with a tune for sure. We knew it was impossible to keep a V8 sound with only 4 cylinders, but we are confident that the 4 cylinder sound is not really that bad. I mean, when you compare it to a V8, it just doesn't compare...period, but you make the best with what you have. We wanted to get an acceptable sound out of it, but more importantly make sure there was ZERO drone!
Old 10-03-2009, 10:13 AM   #11
GOINGSOLO2
GOINGSOLO2's Avatar
Drives: All Models
We have not dyno'd it, but from test driving it, you can absolutely feel a noticeable difference in throttle response and overall power. The car seems to have woken up!
Old 10-03-2009, 10:51 AM   #12
SGOS252382
SGOS252382's Avatar
I'm sure its a great exhaust (looks good and sounds good). I just want everyone to be aware of the AFM issue with the L99 and to seperate it from the word "drone".
Many have confused the AFM issues with drone. Some of the aftermarket exhausts do have drone, but many do not. But all the aftermarket exhausts have a distictive difference in sound when the AMF kicks in (and this can be very annoying to many owners).
The only way to not have the AFM issue (that I know of) is to retain the stock L99 exhaust (because its so quiet), or get the AFM tuned out.
And as mentioned, once you add longtube headers, the AFM transition noise is multiplied.
Old 10-03-2009, 11:48 AM   #13
GOINGSOLO2
GOINGSOLO2's Avatar
Drives: All Models
Correct....the drone is just one issue that sometimes has been associated with the L99 exhausts in general. The sound when the AFM kicks in is another matter. We feel that using the mufflers in our line has created an acceptable exhaust note for the AFM. Nobody is really going to like the sound of any 4 cylinder when they're used to the muscle car sound of the V8. We only hope that ours is more pleasant than what others have to offer.
Old 10-03-2009, 12:15 PM   #14
GOINGSOLO2
GOINGSOLO2's Avatar
Drives: All Models
NEW VIDEOS ADDED!!!
Old 10-03-2009, 12:23 PM   #15
Xmicro_SS
Thank You GM
Xmicro_SS's Avatar
That is a nice simple clarification!
I guess as always it is a matter of give and take...........better fuel consumption numbers = 4 cylinder traits. I wish GM would give you a choice. Has anyone with the L99 asked the dealer if they can turn it off? (I really haven't read the threads since I have the M6.
But, back to the SOLO System. Steve you guys are also offering this kit with the rectangular tips for the ground effects package right? Just curious.
Old 10-03-2009, 12:52 PM   #16
GOINGSOLO2
GOINGSOLO2's Avatar
Drives: All Models
We have a solution for the ground effects kit. We will include two extra sections of straight pipe, and two rectangular tips that work well in the GFX outlets. When your shop installs the kit, the tips can we welded into place in the spot that you please. This is what the extra sections of straight pipe are for. Some people like it farther in, and others farther out. This gives you the option of either.
The tips we would include look like this:
Old 10-03-2009, 01:15 PM   #17
GOINGSOLO2
GOINGSOLO2's Avatar
Drives: All Models
GROUP BUY HAS BEEN POSTED!! GET YOUR ORDERS IN!!!
http://www.camaro5.com/forums/showth...05#post1000205
Old 10-03-2009, 08:07 PM   #18
Alfieboy
Madman
Alfieboy's Avatar
Drives: Black 2010 2SS 6sp man w/IOM stripe
Totally awesome...glad i have mine
I like the ground effects kit //Nice!
Dont have the GE but for those that do..
Rick
Alfieboy is offline   Reply With Quote
Old 10-03-2009, 11:32 PM   #19
third1
speed freak
third1's Avatar
Drives: 2012 Cadillac Escalade,10 IOM 2ss
Thanks for helping us L99 owners. I have an 07 Tahoe with AFM and a Gibson cat back dual exhaust. The Afm doesn't kick in and out as much as the Camaro but it is noticeable.That being said it's not bad at all, it actually seems to be a bit deeper in 4cyl mode. I hope the Camaro acts the same witch I can live with.
Current:2012 Cadilac Escalade.2011 CVO StreetGlide cammed,tuned&loud. 2010 IMO/IO,custom stripes,GFX,sunrf,solo exhaust,JBA shorties,rotofab,Jannetty tune,Pfadt,JLw6 Audison&Hertz,7/4/09 2GIFKIEJ6A9123779Del 7/10/09 Former Camaros 72 LT1 Z28, 86 z28
third1 is offline   Reply With Quote
Old 10-04-2009, 12:43 AM   #20
DON GIOVANNI
DON GIOVANNI's Avatar
Drives: BLACK/BLACK 2SS RS GFX
What about axle-back for GFX? That pic posted looks to be cat back
DON GIOVANNI is offline   Reply With Quote
Old 10-04-2009, 12:45 AM   #21
nyny69
nyny69's Avatar
Drives: 2010 IOM SS
I don't think you'll be disappointed. It was my IOM used for the design and final fitting of both kits. If anyone has questions I'll answer to the best of my ability
nyny69 is offline   Reply With Quote
Old 10-04-2009, 12:49 AM   #22
Xmicro_SS
Thank You GM
Xmicro_SS's Avatar
They will also delete the tips from the axle back and supply you with the square tips for your installer to weld on, this way they can fit them perfect. Steve would have to tell you if there is any charge or not for that, but I do not think so!
Old 10-04-2009, 05:28 AM   #23
GOINGSOLO2
GOINGSOLO2's Avatar
Drives: All Models
Absolutely..we can assure you that the L99 kit sounds awesome. We were really happy with the results!! We are currently running a group buy on the L99 kits.
Old 10-04-2009, 05:30 AM   #24
GOINGSOLO2
GOINGSOLO2's Avatar
Drives: All Models
We can send you the same tips as posted (rectangular), along with some extra straight pipe. You can have your shop weld on the tips as far in or out as you would like in the GFX outlets. There is no extra charge for this. We simply do not weld on the original tips for the kit, as the rectangular ones are supplied in their place.
Old 10-04-2009, 10:26 AM   #25
okie2
okie2's Avatar
Drives: RJT 2SS
Is the cat-back system (non GFX) bolt-on for us do-it-yourself folks? No welding required?
okie2 is offline   Reply With Quote
