Camaro DIY & HOW-TO instructions & discussions All DIY projects & discussions
Old 10-03-2009, 06:21 PM   #1
MGW
Drives: 2010 CAMARO SS
STEP BY STEP VIDEO INSTALL OF MGW SHORT THROW SHIFTER>>
hey guys,
I finally finished the hd install video of our shifter for the gen 5 camaro...
it is in 2 parts up on youtube...check it out!!!
regards
george
MGW is offline   Reply With Quote
Old 10-03-2009, 06:22 PM   #2
MGW
Old 10-03-2009, 10:45 PM   #3
MGW
finally done!!!!!
whew!!!!!!!!!!!!
hope this helps!!!
Old 10-04-2009, 04:59 PM   #4
fieldgoal00
Drives: 2010 Chevy Camaro 2SS/RS
I was on the first 25 email list, when should I be receiving an email to order?
fieldgoal00 is offline   Reply With Quote
Old 10-04-2009, 06:23 PM   #5
markssylver
markssylver's Avatar
Drives: 95 bbb impala ss
i dont know if this will help anyone but if you take the exhaust loose you can pull down on the tail of the trans and pull out the stock shifter assembly as one piece i already have a ripshift but am thinking of changing to this mgw
also is there a replacement shift boot made to fit the bottom ofyour shifter knob, thats one reason why i havent changed shift knobs yet
10.56@134mph
ADM BUILT AND TUNED CGM 2SS RS
ADM/LPE 417 with ported heads/inconel vavles gt11 cam
ADM ported maggie with 14 rib rear 10 rib front pulleys
ADM fuel system and race air intake
ADM/LPE ZR1 clutch /pedalreturn spring
ADM billet aluminum valve covers /RPM LEVEL 6 TR6060
LPE HD 241mm diff with 3:45 gears HD axles and d/s
ADM widened wheels with 315nitto nt05s Bogart 17 dragwheels CTS-V front 6 piston brakes
Pedders HD subframe/differential bushings alignment kit 27/32mm sways Supercar coilovers
683RWHP/650RWTQ
markssylver is offline   Reply With Quote
Old 10-04-2009, 07:27 PM   #6
orange10s.c.
GARYS CUSTOM
orange10s.c.'s Avatar
Drives: IOM 2SS RS M6 sunroof
Nice George !! I caint wait to get it in.
Old 10-05-2009, 07:09 AM   #7
MGW
we are just waitnig on the sound plates and boots to be finished .i will be contacting you soon.
george
Old 10-05-2009, 07:11 AM   #8
MGW
the boot on your oem shifter has a plastic chrome finish top collar that is simply attach with a cable tie. if you invert the boot you will see it. you snip this off and our shifter knobs have a flared based with a groove below it to attach just like the oem one. we also include the cable tie to install it.
george
Old 10-05-2009, 08:19 AM   #9
Mod007
Mod007's Avatar
Drives: Camaro SS/RS
Wow nice how to video.
Camaro SS/RS Corsa Catback
Mod007 is offline   Reply With Quote
Old 10-05-2009, 12:14 PM   #10
caverman
caverman's Avatar
Drives: '69 SS Convertible
Great job on the video install! Need a little more light to see what you were working on in some of the videos but still having the videos will be a big +.
I'll have to watch the videos once or twice more once I actually get the shifter. In general it seems okay but I'm sure I'll run into some snags that you make look easy.
If you can get some new video of it all done and in action plus with the SS race knob that would be great.
Build Journal
Old 10-05-2009, 09:58 PM   #11
markssylver
george
so the shift boot will be attached to the shift knob not like stock where the chrome collar snaps onto the base of the kob?
10.56@134mph
683RWHP/650RWTQ
Old 10-06-2009, 04:14 AM   #12
Sick Rick
Baphomet's Wheelman
Sick Rick's Avatar
Drives: Everyone crazy.....
Really nice install....moderate to easy for the average mechanic. With these videos (and maybe a buddy to help ya) you guys should have no problem. Not as easy as changin a tire, but not as difficult as say....swappin a motor out either
Sick Rick is offline   Reply With Quote
Old 10-06-2009, 09:21 AM   #13
Sean@Phastek
PhastekPerformance.com
Sean@Phastek's Avatar
Drives: 2010 Camaro X5 Turbo
Awesome videos, thank you for taking the time! Which video shows you rowing through the gears after the shifter is installed? Didn't notice it right away...
Sean@Phastek is offline   Reply With Quote
Old 10-06-2009, 10:54 AM   #14
MGW
i have posted a few with the different knobs on but i will post another video today with our low profile gripper ball.
george
Old 10-06-2009, 12:02 PM   #15
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: THRSS #2 / CGM#1
Holy cow, man...great DIY thread!
The build of THRSS #2
Old 10-15-2009, 12:52 PM   #16
MGW
GUYS !!!!
i know some of you guys are going to be installing these shifters i just wanted to make sure you guys take special note of the LAST steps...
when you are tightening the 2 bolts coonecting the support arms and push the shifter up level make sure you you run finger between the tranny linakge rod and that round sensor sticking out of the tranny near the driveshaft coupling. you want to make sure you have plenty of clearance there.
REFER TO STEPS 28 AND 28B IN THE VIDEO INSTALL!!!!
george
Old 10-19-2009, 09:49 PM   #17
adk46r
PROUD MARINE DAD! OORAH!!
adk46r's Avatar
Drives: 2010 IOM 2SS/RS,1967 Murina Blue RS
George,
Thanks for the updated vids and all the LITTLE heads ups!! I would also like to add that my shifter arrived today just as you had stated and I'm really impressed; with the quality of the parts and the great job packing and shipping!! I hope to get it installed this weekend.....can't wait!! Thanks again George for a job well done!!!
Delivered 6/12/09 VIN#2G1FT1EW3A9112635!!!
adk46r is offline   Reply With Quote
Old 10-20-2009, 02:53 PM   #18
MGW
Originally Posted by adk46r View Post
George,
SOUNDS GOOD LET ME KNOW WHEN YOU DO!!!!
Old 10-23-2009, 05:05 PM   #19
MGW
OK GUYS I MADE A BIGGGGGGG GOOOFFFFBALLL MISTAKE ON THE LAST STEPS OF HTIS INSTALL!!!!
WHEN YOU TIGHTEN THE 2 HEX BOLTS HOLDING THE SUPPORT ARMS TO THE SHIFTER BODY YOU WANT TO MAKE SURE THEY ARE NOT FULLY TIGHT UNTIL YOU RAISE THE TRANNY BACK UP.
IF YOU DONT YOU WILL HAVE THE SHIFTER NOT LEVEL WITH THE SUPPORT PINS.
YOU WANT TO LOCK DOWN THE BAC K BRACKET AFTER YOU PUT THE BOOT IN.. THEN PUT THE TRANNY SUPPORT MOUNT BACK ON THE CAR AND THENNNNNNN FULLY TIGHTEN THE 2 HEX BOLTS ON THE SUPPORT ARMS AFTER YOU MAKE SURE THE SHIFTER IS LEVEL!!!
SORRY FOR THE GOOF
GEORGE
Old 10-24-2009, 12:04 PM   #20
Li0nel1234
What should I name my car
Li0nel1234's Avatar
Drives: 2010 Camaro 2SS RS IOM
Send a message via AIM to Li0nel1234
You are the Man... THat is soo awesome that you would give us a step by step VIDEO tutorial...
It must have taken some time. Thanks!
Performance: ARH 2"/"3 headers + ARH 3" HF catback system, SS brake lines, hawk HP+ pads, motul RBF 600 fluid, K&N CAI (w/custom insulation), plug wires, air scoop, Hurst STS, Pedders Track II suspension, 18x10 wheels, 295/45/18 Nitto NT05s
Looks: powder coated iom calipers, LED foglights w/ always on harness, custom painted bowties, window tint, smoke tinted tail lights etc, oem gfx w/ custom outlets, painted taillight bezels, all weather trunk mat
Li0nel1234 is offline   Reply With Quote
Old 10-25-2009, 04:33 PM   #21
adk46r
adk46r's Avatar
Hey George!! I thought the install was a piece of cake (except for those DARN bushings! ) Just kidding, although they were a pain in the butt!! Took me a little over 2 hours.. I love it, you did a great job! Took her for a quick run up and down the road; night and day difference IMHO! Here are a few quick pics...enjoy!!
Old 10-25-2009, 05:54 PM   #22
Jeanius
Jeanius's Avatar
Drives: Blk/Blk LS3 SS
Hey George any chance of that knob coming in a black face with red SS letters?
Jeanius is offline   Reply With Quote
Old 10-26-2009, 08:30 AM   #23
MGW
i dont have a way to do that right now as these are laser etched anodized disks. i tried that special laminate plastic sheet that has black and red laminated and you cut thru one layer for a 2 tone but that crap is pretty cheesy in feel and looks. makes it look cheap
george
Old 10-31-2009, 01:59 PM   #24
2010CamaroOutlaw
Drives: CGM 2SS/RS
f a whole bunch of that LMAO, the shifter is all ready short enough for me, good work though.
2010CamaroOutlaw is offline   Reply With Quote
Old 10-31-2009, 11:44 PM   #25
bpoirier
bpoirier's Avatar
Drives: 2SS/RS IOM CGM Stripes
Installed my MGW shifter today. It works absolutely fantastic. The install wasn't too bad at all. The passenger side pin removal was the hardest part. Got the job done in about 2 hours. George, thanks for a great product.
bpoirier is offline   Reply With Quote
