Solo Performance
Old 10-03-2009, 09:14 PM   #1
bcbuckl
Drives: 2006 C6 Corvette Machine Silve
Hurst / M6 install and tranny noise
Just installed Hurst shifter and took for firs ride! Went from 1st to 2nd @ about 4k rpm and developed shake in shifter and noise !! Anyone elese experienced this?
Brian
bcbuckl is offline   Reply With Quote
Old 10-03-2009, 09:33 PM   #2
DMAX
DMAX's Avatar
Drives: 01 silverado 2010 2SS/RS Sim
It's normal for the hurst shifter to make some noise I get some noise sometimes .
DMAX is offline   Reply With Quote
Old 10-04-2009, 09:19 AM   #3
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: To many to list
Brian
Hi Brian if you want you can do this.
http://www.camaro5.com/forums/showpo...&postcount=315
Old 10-04-2009, 11:05 AM   #4
bcbuckl
Thanks for the info very helpful,
I may have understated my problem, shake and vibration is quite severe also sounds like something is broke in trans, almoat like it is between gears. Bad enough that I cannot drive car.
Thanks
Brian
Old 10-04-2009, 12:05 PM   #5
2SSRS@Gen5diy
No disrespect but read this from "Banshee" on this thread.
http://www.camaro5.com/forums/showth...t=32963&page=9
I think you have the same problem I had. I installed mine yesterday in the rain and cold and was running short on time and was trying to get Brians shifter done because he didn't have a way home if not done. I forgot to torque one hex bolt (out of 2) and it was grinding, vibrating and chattering. We are talking 1 bolt not torqued a total of 360 to 480 degrees. Thats a turn and a half. I removed, reapplied loctite and torqued and the shifter is PERFECT.
The 1-2 are exactly the same as 3-4 and 5-6 for me. I can not tell the difference in shift travel.
However, initially, my reverse was chattering. Then after 1/2 mile, the 1-2 gate started up, then all went to hell. Like I said, I only drove her 1/2 mile but forgot to tighten 1 bolt.
Today. drove her 40 miles..the shifter is perfect. I have well over 200k with Hurst shifters in my Tremec/LS cars..There is no change with this one. In fact, I prefer this one over the others because this is one sexy car.
Old 10-04-2009, 01:13 PM   #6
bcbuckl
None taken, any input is helpful in thinking process!!
I did find the source of the problem, the dust boot was not attached properly and was hitting ujount causing vibration in shifter! Easy fix as long as I get secured properly this time, tough location to get at and only able to get one hand up there, at least for me.
Thanks for your help
Brian
Old 10-25-2009, 10:27 AM   #7
2SSjack
2SSjack's Avatar
Drives: 2010 2SS Camaro;
I just took mine for a 30 mile ride, mostly highway. I do get a little noise under acceleration but steady cruise and light accel are OK! I guess hot rods do make a little noise now and then!
2SSjack is offline   Reply With Quote
