Old 10-04-2009, 12:57 PM   #1
E85LSX
E85LSX's Avatar
Drives: 2010 Camaro
Engine Reduced Power- After Cam Install
So after fireing her up with the new cam she was running great then when I reved the engine it said "Engine Reduced Power" on the dash. Has anybody seen this before?
I am going to try a few different things like disconecting the battery and maybe reflashing the computer. . .
Mods: TVS2300, 3.2 pulley, American Racing Headers, Custom Cam, Coil Overs, Tuned for E85, 610RWHP* 570RWTQ
Follow me on Twitter
www.e85lsx.com
E85LSX is offline   Reply With Quote
Old 10-04-2009, 06:57 PM   #2
THUMPER20X
GM fix my PAINT U suck!
THUMPER20X's Avatar
Drives: 2010 Black 1SS/RS 6Spd
If I recall its the computer trying to reduce output because its seeing something really bad. You better get it checked. Its like a self preservation mode in the factory programming.
THUMPER20X is offline   Reply With Quote
Old 10-04-2009, 10:30 PM   #3
E85LSX
E85LSX's Avatar
Drives: 2010 Camaro
Still not sure why this message was displayed. It flashed when I was revving the engine in neutral, I then shut the car off, disconnected the battery and when I restarted it it was gone.
I did have a DTC P0106 which is for the MAP. With my new cam the vacuum is low at idle which caused this CEL to come on. I tuned it out and now have no problems at all. I think the reduced engine power could have had something to do with this code but I'm not sure.
I'll update this thread if it happens again. . .
www.e85lsx.com
Old 10-06-2009, 12:46 PM   #4
Matt TuneTime
Drives: 2008 G8 gt / 2010 Camaro L99
Get it tuned ... must be a choppy cam ?
Matt TuneTime is offline   Reply With Quote
Old 10-06-2009, 07:26 PM   #5
BADBLACKSS
Xtreme Horsepower
BADBLACKSS's Avatar
Drives: Black 2010 SS
Sounds like a tuning issue
BADBLACKSS is offline   Reply With Quote
Old 10-06-2009, 07:58 PM   #6
E85LSX
E85LSX's Avatar
Drives: 2010 Camaro
The problem is solved. The P0106 will throw the car into limp mode. If you guys are tuning in a big cam you may need to tune this code out. You may also have a random misfire code at idle, I had to tune my misfire tables to keep her from throwing the P0300 at idle.
www.e85lsx.com
Old 10-07-2009, 01:09 PM   #7
boostedyards86
boostedyards86's Avatar
Drives: Cummins 3500
must be a serious cam.
85 Buick TType - 5.3l GT4202r 10.86 at 126
boostedyards86 is offline   Reply With Quote
Old 10-10-2009, 03:50 PM   #8
fuffl
Drives: #3124!!!
Did you have to do anything else to tune out the problems with low vaccum? I'm having the same problem with my new cam, the MAP is reading 100 at idle. Currently it actually seems to be misfiring, but I'd be greatly encouraged if I could just adjust the misfire tables. Any help would be greatly appreciated. So far I've checked:
-Pushrod length
-Cam degree and install
-Rocker tightness
-coil packs being on the wrong side
fuffl is offline   Reply With Quote
Old 10-11-2009, 09:24 AM   #9
E85LSX
E85LSX's Avatar
Drives: 2010 Camaro
-Pushrod length
-Rocker tightness
I don't think your map should be reading 100 at idle, that is atmospheric pressure, even with a huge cam there should be some vacuum. If I remember correctly my map is 60 at idle, I think it was 30 stock. You need to check out that map sensor, maybe it needs to be reset or somthing. Does the reading ever change or is it stuck on 100?
After you figure the map situation out you will most likely have to adjust the misfire tables. I would only adjust the idle portion of the tables and I would just keep making it less sensitive little by little until you don't throw the code. This way you will still have real misfire detection.
www.e85lsx.com
Old 10-12-2009, 04:30 PM   #10
EAkrish
Scout Sniping
EAkrish's Avatar
Drives: 2010 Ford F150 Lariat SuperCrew
Send a message via AIM to EAkrish
HUM, I wonder if I cam my camaro will the warranty still be intact if i blow the motor
Eric
Previous Car:1SS/CGM 6MT w/ Sunroof & FACTORY BLUETOOTH!!!: New Era OTR, Steeda Short Shifter, Ported TB, Stg 2 ported intake manifold, Fasterproms, Poor man down pipes, MBRP 3" Exhaust!!!
Now I drive a F150 Supercrew
EAkrish is offline   Reply With Quote
Old 10-12-2009, 04:45 PM   #11
kelley@vectormotorsports
Drives: 2009 Pontiac G8 GT
The MAP should not be 100kpa at idle. It should be 100kpa with the engine off & key on.
Check you MAP wiring and make sure it is plugged in. Also make sure your MAP is seated fully into the intake.
Sometimes just deleting the code does not work, you must delete the P0106 test in the ECM.
Give me a call and send me a scan if you want.
586-790-2970
kelley@vectormotorsports is offline   Reply With Quote
Old 10-12-2009, 05:38 PM   #12
CrazyTurbo98TA
Drives: 1998 WS6 441 LSX
kirk pm sent
CrazyTurbo98TA is offline   Reply With Quote
Old 11-04-2009, 07:18 PM   #13
fuffl
Drives: #3124!!!
MAP wasn't seated. Solved that one.
...now for the new one. haha.
Now that I've got the tune nailed, it purrs (or shakes violently) like a kitten. Problem is with the rockers. I keep snapping off Intake rockers. Correctly installed, but it's not the bearing breaking. Harland Sharp rockers, so the quality isn't suspect. Did you switch valve seals when you did the spring swap? I've never had to do that before but that's the only thing I can think of that would be causing enough resistance to break them.
Old 07-05-2010, 07:22 PM   #14
playcorn99
Drives: 2010 2SS CAMARO V8 6.2L
i am getting this same error, but i dont have any major mods done. I have a new exhaust put in, cut out from the resignators on back. straight pipes to flow master mufflers. I have a k&n intake and a jet mass flow air sensor. i've been riding around for months and now i get this engine reduced power light while driving. the car starts to shake and gets weak, and so i pull over to turn the car off. after about 5 minutes i start her back up and its fine, but leaving the check engine light on. i took it to the dealer and they told me to take my throttle body spacer off and they tightened a wire leading to somewhere in the throttle body. so they cleared the light. few days later it happened again. so i park my car at home. came out later and the engine light had cleared itself. what do you guys think i should do? get an auto programmer?
playcorn99 is offline   Reply With Quote
Supercharger / Turbocharger Results (INFO) Thread radz28 Forced Induction - V8 256 11-18-2016 08:50 PM
Anybody Spray'n their SS yet - nitrous ? WeeZee Forced Induction - V8 37 12-29-2012 10:56 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
